Question about Cozy (W352E) Heater
Where would you find a regulator for the cozy purchased at ACE
  • 59 Answers
Would go to a local heating wholesaler, look on last page of heating and a/c contractors and there will list distributors, take valve with you or write down all number off valve so they can match one up for you.
Posted on Nov 24, 2010
I'm planning to buy and use the cozy toes heating mat on 220-240 v electricity. Would that work fine with one purchased from the USA?
you will have to check the voltage before purchase because the usa voltages are different from ours they use 110v 60hz we use 230v 50hz
you would have to by a transformer if it was 110v 60hz but some exported usa appliances are 220v and will be ok you will have to check before you buy i
Dec 01, 2011 | Comfort Products Foot Warmer Mat - Cozy...
I purchased a 7990 and some of the parts were missing that attaches to the bicycle. I need a parts listing and manual to see what is missing and how to order the parts.
Contact Cozy Cruiser and request a replacement manual. May be able to download one online. Parts are available through online like Amazon, eBay or Icycles.
Jul 02, 2011 | Little Tikes Cozy Cruiser 7990
Hi there where can we purchase a new wheel and shaft for our cozy coupe also a new horn. in New Zealand.Thanks Lorraine.
check this website:
http://www.littletikes.com/consumerservice/ReplacementParts-detail.aspx?Product_ID=2555&
Mar 10, 2011 | Little Tikes Cozy Coupe
Hi. I have a Cozy CDV255B wall-mount heater. The burner stopped working suddenly. The pilot is on. I jumped the two wires connected to thermostat and that did not help. Then I replaced the thermostat and...
Did someone possibly turn the control knob from ON position to the Pilot Position. If that's the case, the burner won't come on.
Another thing that might cause your problem is low gas pressure. If you have LP Gas, the regulator on the gas tank may be frozen or the tank may be almost empty.. This happens frequently when temperatures remain well below freezing. To test this theory, soak a bath towel in hot water, ring it out and quickly place it around the LP tank's regulator. This will thaw the regulator and allow gas to flow smoothly to your heater. Remove the wet towel from the regulator once it has thawed.
If the freezing continues to occur, wrap insulation around and inside the bonnet of the tank. You may also want to contact your propane provider about this. As they may need to add some ethanol to your tank.
Jan 27, 2011 | Cozy Heating & Cooling
My furnace man has told me that they don't make themocouples like they used to. The one one the Cozy Heater has to be replaced almost each year. Is it possible to get one that will last? Is it too...
Not at all it is fairly easy and unfortunatly they are made in korea and the really dont make one that last that long .You can purchase one for under 10 bucks and spending 30 or 40 bucks is better than 100 + per service call .
Dec 09, 2010 | Cozy (W352E) Heater
Cosy coupe wheel.
If you have the newer style Cozy Coupe, you can purchase replacement wheels with capnut from Little Tikes.
http://www.littletikes.com/consumerservice/ReplacementParts-detail.aspx?Product_ID=2823&
Hope this helps!
The Grand Toy Wizard
www.thegrandtoywizard.com/store
Jun 26, 2009 | Little Tikes Cozy Coupe
Pilot goes out
Remove the pilot gas assembly and clean the pilot jet. They can carbon up and partially obstruct the jet after a few years in service. If you can remove the jet altogether, clean it with a good quality automotive fuel injector cleaner or carburetor cleaner. Try not to use abrasives.
If equipped, check the pilot gas regulator - it may be on it's way out and need replacement.
Mar 27, 2009 | Cozy (W352E) Heater
My Cozy heater does not respond on the thermostat control
Make sure you have a stat that is for a millivolt system, if the stat you have has 24v on it wrong one, need to purchase at a heating wholesaler home depot lowes do not carry them.The stat should have mv for millivolts on the box or stat.
Nov 23, 2008 | Cozy (W352E) Heater
Cozy (W352E) Heater Logo
67 people viewed this question
Top Cozy Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
jdthefixer
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
