Question about Diamond Audio D7401 Car Audio Amplifier
D7401 doesnt work
A light beside the fan comes on then goes right back off
cant find a place for a fuse either
    Scholar:
  • 80 Answers
There is no fuse on this amp. It requires EXTERNAL fusing, as it is a PRO amp.
There are diagnostic LED's on the board if you look inside. They may point you to a problem, but the odds are the amp is shutting down because it is detecting a problem. You need to take it to a repair shop for an good tech to fix. Unless you are VERY into electronics, and very knowledgeable about the operation and repair of car amps, I would not attempt to repair it yourself. It is a very nice, expensive, high power old school amp. The power wiring needs to be sufficient as well. This amp will draw ALOT of current at full power. (80 amps or so I think) there's manuals for it floating around the net with the exact specs needed for the external fuse).
Posted on Jun 12, 2009
Cruise control doesnt work the light doesnt even come on
Fuses are a great place to start, if not fuses the actual cruise control switch may be to fault. Rear heater do you get heat out the front and if so is there a fuse for a rear fan maybe a blower.. Let me know
Mar 28, 2014 | 2003 Dodge Durango
The fan on my 06 gxsr 600 comes on when i crank it but then goes right back off an will not cool my engine I have checked the fuzes and they work what else could be the problem
The fan should not actually come on untill the engine goes over a temprature set by a thermostat,
when riding around normally the fan doesnt normally come on except when you are waiting at traffic lights or staying still,
You can test the thermostat just start the bike and let it idle the fan should start between 80degC and 90 degC if the engine temp goes over 110 -120degC and does not kick in there is definately a issue there with the thermostat, it doesnt sound like the wiring, fuses or relay as it runs for you sometimes.
Hope this helps:)
Brad
Aug 01, 2011 | Suzuki GSX-R 600 Motorcycles
Fan motor doesnt come on looking for wich fuse it is
Hi:) I have a 1997 SW1 Saturn the fuses for the Rad fan are in the black box on the drivers side inner fender beside the battery along with the fan relay
Apr 12, 2011 | 1996 Saturn SW
My 2006 honda accord has a cigarette lighter in the arm rest that doesnt work but i dont know what fuse to change for it. do you know?? It doesnt say in my owner's manuel or the fuse cover.
hi there is a two fuse box one under the bonnet and one beside the drivers right leg thats for australia maybe different to your country check the one beside the driver leg it should be 15 amp put when reading the cover put back of the cover against fuses thats how you readit good luck
Mar 23, 2011 | 2006 Honda Accord
Where is the headlight sensor or fuse?
the light sensor is located up under the black plastic cover around the rear view mirror mount. from the outside of the vehicle, look at the rear view mirror area. you should see a purple / blue square (2" x 3") that is the rain sensor, right beside it should be a small clear round circle this is you light sensor. in the day light with the car running, place a dark piece of tape over it and you lights should come on. as far as the fuse goes...sorry don't know.
hope this helps
Mar 09, 2010 | 2004 BMW 5 Series
Heater fan isnt working. cant find where the fuse
Look in the fuse/relay box under the hood,on drivers side,if the fuse is not blown,check for a bad relay near the blower motor,or in th relay box.If all this checks out,it can be the control head,it is a system with sensors all over the place,and any of them can cause the problem.But it does sound like the control head.
Jan 19, 2010 | 1997 Cadillac DeVille
Dashboard lights wont come on,cant visually see speedometer,shift position etc. cant find the fuse to see if its blown.turned the headlight knob,still doesnt come on
buy a test light ground test light turn key on and check all fuses touch the top of each side ofer ever fuse ,if only one side of fuse light up then it is blown,,,,could be inhead light switch
Jul 02, 2009 | 1996 Cadillac DeVille
Ac quit running,compressor doesnt run,fan doesnt run,no bad fuses or relays that i can find,replaced controls
It may be your ignition switch. Bang on the bottom of your steering column with the key in the "on" position and see if the fan will fire up. My car is doing the exact same thing right now, but I can basically rub the bottom of the trim under the steering column and it comes on. It will also start when I hit a good bump on the road.
May 27, 2009 | 1994 Oldsmobile 88
Cooling fan won't come on, have tested fan and replaced temperature sensor.
First question to you is.. Have you checked the wiring or ECU codes?
check the cooling fan switch on the back of the block, unplug the connector and jumper.
2 wires, turn ignition on and fan should come on...
if it does-----replace the cooling fan switch
if it doesnt----- go to the cooling fan relay on the pass side inner fender
panel behind the headlight and check it, besides the fan itself and the fuse, those are the only things in the system.
May 11, 2009 | 1987 Chevrolet Cavalier 4 Door
Possible PSU problem?
sounds like a bad power supply to me.
Oct 21, 2007 | Gateway GT4016 Desktop PC
Diamond Audio D7401 Car Audio Amplifier Logo
95 people viewed this question
Top Diamond Audio Car Audio & Video Experts
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
jeff5may32
Are you a Diamond Audio Car Audio and Video Expert? Answer questions, earn points and help others
