Question about Sharp AL-1641CS All-In-One Laser Printer
Sharp AL-1641CS printer/copier
Right side of paper is covered with toner. Changed toner cartridge, but problem started again after a while.Inspected cartridge and drum and gave copier, cartridge and drum thorough cleaning without resolving the problem/
  • 1 more comment
  • crazywvlady Aug 27, 2008
    I, too, am experiencing the toner splash on the right hand side of the printouts. Will try the vacuum solution and let you know.
  • Anonymous Mar 13, 2014
    LD016 reset toner cartridge on coier
  • Anonymous Mar 17, 2014
    change toner cartridge sharp copier
    President:
  • 2,072 Answers
Most likely you had a toner cartridge failuer leaving some of the ink and developer in the crevices above the paper feeder and its just trickling onto the paper.
It pretty much needs to have the cartrides taken out and thouroghly vaccumed.
Just takes patience and time to get it all removed.
Dont vacuum the cartridges, but the inside of the machine.
Pull your paper tray out and see if there is toner and developer trickling into it.
Posted on Jan 11, 2008
Tip
Sharp AL-1641CS Copier Manual Download
Free Sharp AL-1641CS Copier Manual Download
Models: Sharp AL-1632 / Sharp AL-1641CS
Would you like to review the features of the Sharp AL-1641CS Copier?
Have you lost your Sharp AL-1641CS Copier Owner's Guide?
Would you like a free digital, searchable, pdf version of the Sharp AL-1641CS Copier Manual?
Follow this link
(& click FREE) to download a pdf version of the Sharp AL-1641CS Copier documentation.
I hope that helps.
___________________________________________________
on Jul 24, 2010 | Sharp AL-1641CS Laser Digital Copier
We have a Sharp 1641CS copier will not feed or copy
Well one reason the Cartirdge is spilling is due to the cartridge backing up with toner everytime it tries to print, it misfeeds cause the paper feed tires need to be replaced,
May 29, 2009 | Sharp AL-1641CS Copier
My Sharp AL-1641cs won't print. Just keeps flashing red drum.
SOUNDS LIKE YOU NEED TO REPLACE THE TONER CARTRIDGE, THEY GO THRU LONGER WARM-UP PERIODS WHEN THE TONER GETS LOW AND IF YOU LET IT RUN YOU WILL SEE RED LIGHTS LIKE STACKED CANNON BALLS, WHICH MEANS ITS OUT OF TONER
Feb 18, 2009 | Sharp AL-1641CS Laser Digital Copier
Right side of paper is faded
remove the cartridge out, you can see a piece glass on the bottom inside the machine. clean up by acohol both side.
Dec 09, 2008 | Sharp AL-1641CS Laser Digital Copier
All of my copies have toner on the right edge. How do I fix this?
If it keeps coming back on the drum then replace drum.
Very unlikely that the toner is bad.
Oct 14, 2008 | Sharp AL-1641CS Laser Digital Copier
No Copies
It could possibly be your main charge assembly. If there is no charge on your drum, it can lead to blank copies.
May 20, 2008 | Sharp AL-1641CS All-In-One Laser Printer
Sharp AL-1340
Try this: make a copy from the table and then one from the document feeder. compare the two. If the copy from the table looks good and the document feeder one is bad then clean the glass on the document feeder. If both are bad remove the top glass and clean the mirrors using rubbing alcohol and a lint free cloth. you can also clean the wheels on the feeder and in the tray with rubbing alcohol if you ever have feeding problems
Hope this helps
Apr 12, 2008 | Sharp AL-1641CS Laser Digital Copier
Sharp AL-1641CS All-In-One Laser Printer Logo
184 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
