Question about Acer Aspire™ T180 PC Desktop
Acer Aspire T180-UB72 does not boot
Hi
My Acer T180 has all of a sudden stopped booting up. Every time I switch it on all that happens is the ACER start screen appears.  I am given the option to press DEL to Enter Setup or F12 for Boot Menu, but when I press either button nothing happens.
Any advice on what the problem maybe will be greatfully received.
Thanks Dave
  • 11 more comments
  • dvmurray Jan 09, 2008
    tom19511, thanks for the reply.
    I don't think it gets that far during the boot sequence.  I turn the computer on,  get a black screen which lasts for about 2 seconds then the screen with the ACER logo and DEL and F12 button options appear.  I have tried pressing F8 when the black screen appears but nothing happens.
    Could it be the motherboard that has broken?
    Thanks
    Dave
  • dvmurray Jan 10, 2008
    tom19511, the hard drive has seemed to be working ok when I last used my PC. The last process to run was to install some microsoft updates when it was closing down.
    Dionnow, i'll try the F12/DEL button on the black screen when I get home from work tonight and let you know how I get on.
    Thanks
    Dave
    tom19511, I Have tried all the solutions mentioned without any success.  Typically the warranty ran out last week.
    Thanks for all your help,
    Dave
  • ed1983 Mar 01, 2008
    I am having the same problem, when I turn on the PC, I see the ACER logo and the option to press DEL to Enter Setup or F12 for Boot Menu but I cannot enter either. Not had any previous problems with the PC.
    Thanks,
  • Anonymous May 04, 2008
    i have the sm problem
    Mustapha
  • Anonymous Aug 08, 2008
    We have the same problem and we are going to
    exchange the Motherboard, because nothing will help.
    And I treied a lot.
    Tobias, Germany
  • Anonymous Sep 05, 2008
    will not boot up just goes to the start screen but nothing happens
  • Anonymous Oct 21, 2008
    im trying to reboot my acer computer it wont work
  • Anonymous Oct 22, 2008
    i have acer aspire l320 10 days out of warranty same thing happened
  • mikecbarber Oct 22, 2008
    I turn the computer on after a few seconds it turns it self off! i have tried to press reboot option 12 but it trys to restart as if there is a power problem
  • borsdane59 Nov 17, 2008
    I have an Acer Aspire L320 mine failed to boot up 12 months to the day that I bought it! Curry's are being very ruluctant to do much to help me! Is this a common problem, I think I may contact Watchdog.
    Tabs 59 of Southport
  • James1977-UK Nov 24, 2008
    I have the same problem, computer rebooted and then when it came back on it shows me these two options and when i option DEL or/and F12 it shows the same thing.
    I have taken out the bois battery, I have tried to switch the jumper from 1+2 to 2+3 then back to 1+2 none of that was successful. There is nothing I can do... please help!!!
  • judyneric Dec 29, 2008
    I booted up my acer T180 for the first time in several weeks or a couple months. I downloaded some Microsoft updates, and then told my computer to restart.
    The computer never restarted. The fans came on, but the monitor never gave any indication that the computer was in operation.
    1. Fans came on.
    2. The green power light on computer front did not turn on.
    3. Nothing showed up on monitor.
    4. DVD Drive lights were on, and tray could be opened/shut.
    5. When I held in power button, other fans would power up.
    I disconnected hard drive, this had no effect.
    I disconnected DVD drive, this had no effect.
    I removed motherboard CR2032 battery for several minutes, no effect.
    Basically, the computer acts as if it is dead, except that the fans will operate and the DVD drive is powered and can open/close.
    The computer is not reaching a stage where it is outputting to the monitor.
I have the same model and had the same problem. Fortunately there is a simple fix - unplug all your USB devices (mouses, printers etc). It should now boot!
Assuming that fixed it, it was trying to boot from a USB drive for some unknown reason. I think it was due to the latest windows XP update. Wierd. Hit F12 next time you reboot and make sure it is booting from hard disk first.
Posted on Jan 18, 2008
HI, i had the same problem and it turned out to be a faulty hard drive cost me £85.00 to have replaced incl labour and now works ok.
Posted on Jan 21, 2009
I had the same problem as above. I tried disconnecting everything one by one till I got the the front panel connector (2 USB and Audio sockets at the front). The machine booted with it disconnected. I reconnected and tried again, and it worked. Still working as we speak. Dunno if this is the ultimate solution but give it a go!!
Hi
we had the same problem and our acer was just out of warranty..... I had this on an older comp and found that a virus had hit the ram and would stop the comp from loading up... I have had to reinstall windows xp and all the settings if possible take the hard drive out and have it checked (a decent local pc repair shop will help) try your back up disc or get your local pc shop to reinstall the factory setting ( you`ll need to make sure you have your windows serial number still attached to the side of the case.) cost around £40 .
regards rod
Posted on Jan 13, 2008
  • 61 Answers
Yea, If you get stuck at the ACER screen then you defiantially arent getting far enough to get to the windows boot menu. DEL or F12 should allow you to access your BIOS settings. You want hit f12 / del while at the black screen / acer screen. This should UNCONDITIONALLY take you to the bios screen. If it does not, you might be correct in your last assumption
Hope this helps!
Posted on Jan 09, 2008
    Genius:
  • 1,601 Answers
Press F8 during the black screen/white words screen to access the advanced startup menu. Choose to use the last known good configuration that worked
  • 1 more comment
  • Thomas Christopher
    Thomas Christopher Jan 09, 2008
    dvmurray, You have a hardware problem. What it is is difficult to tell. My guess would be the hard drive. Has it been noisy or acted crummy before this happened?
    Thomas Christopher Jan 10, 2008
    Did you get this resolved. If so please rerate as FIXYA. If not please let me know so I can help you further.
    Thanks
    Thomas Christopher Jan 15, 2008
    1 more thing, try replacing the bios battery..
Acer aspire t180 stuck on logo screen
try booting in safe mode by tapping f8 during boot
Oct 09, 2012 | Acer Aspire T180 PC Desktop
My acer t180 freez in screen acer
Mine had the same problem. I left it on for 30 mins and it finally booted.
Have you tried the step of removing battery and unpluging power supply for at least ten minutes ?
Apr 21, 2012 | Acer Aspire™ T180 PC Desktop
Acer aspire T180 UB72... looking to bring data D disc into use as data is almost full..need help to do so!
Acer Aspire computer has a recovery partition so called D drive. I am sorry to say that you will not be able to access this drive.
But you can try this, open D drive and go to My Documents or Documents and then try to save any file. Hope this should take care of the issue
Thanks and regards,
Jitha
Nov 23, 2010 | Acer Aspire T180 PC Desktop
Hi. When I turn on my Acer aspire t180, only the red button light up, but the green button does not light up . And then nothing happens. Please help me as im having the same problem for months already.
Im guessing the PC starts up flashes the lights turns off and repeats?
If so the hard drive boot sector is gone or damaged. Try to boot from the Windows disk.
Nov 03, 2010 | Acer Aspire™ T180 PC Desktop
The Acer X1700 desktop suddenly stopped booting.
i would check your power supply. take it to a local computer shop. or call acer for warranty support.
or if you are running on a backup ups, plug the computer directly into the wall and try it again
Sep 23, 2009 | Acer Aspire™ T180 PC Desktop
Trying to start up an acer aspire T180
can you tap F8 while it is booting and start in safemode or select boot with last good know configuration?
Jun 11, 2009 | Acer Aspire™ T180 PC Desktop
ACER T180 does not boot up
check the fan of your cpu is it working fine also check the RAM, do it by putting some other RAM which is working
Sep 10, 2008 | Acer Aspire™ T180 PC Desktop
My ACer T180 does not boot boot up
sound like the hard drive. do you hear the drive spinning?? you may need replace or reformat.
what OS are you running....?
ACER ASPIRE T180 problems with keyboard
Fixed it by booting without any USB devices. Once booted, plug your USB mouse...
Worked for me. I hope it helps
May 14, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire™ T180 PC Desktop Logo
4,663 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
