Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
We had a power outage, when the power came back on the airconditioner was just making a clicking sound and flashing PF. I tried unplugging the unit etc. Things light up but nothing happens..Help...
  • 2 more comments
  • nerr Nov 16, 2009
    When you say 'remove cover'....where exactly is this cover ? There does not seem to be anything to un-do on the bottom of the unit....Do you unscrew a panel on the side of the unit or the top of the unit ?
  • nerr Nov 16, 2009
    We are dealing with a Pinguino Pac CT90....
  • nerr Nov 16, 2009
    What cover ? The top of the machine ? The sides of the machine ? There isn't anything to open on the bottom of the air conditioner AND...to make it even more fun the screws are stripping....N
  • nerr Nov 17, 2009
    When you say remove cover...which cover ? Top of unit, side of unit ?
  • 10,515 Answers
It refers to PROBE FAILURE.
The probe is damaged and needs to be replaced.
You need to cal professional on site to fix this.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 17, 2009
    Scholar:
  • 111 Answers
Leave the unit unplugged for at least 15 minutes, It may have overheated the compressor and tried to start up again.
If you have a reset button in the back of the unit, reset it(Usualy close by the power cord)
Also You want to dump any excess water from the unit at this time, so you have a fresh start.
Once the compressor cools down 90% of the time your error code will clear itself out and reset back to normal.
Keep me posted.
FlaTech.
Thank you for Using FixYa!
  • 1,986 Answers
This code means that the probe has failed.
The probe is located under the main board low inside the only silver metallic box on the bottom with the circuit board under it. Remove cover and you will immediaetly you see a 4 inch black wire connected to the main board tucked under and mounted. Unplug the white connector from board, power on, then carefully plug the white connector back on, turn unit off and back on, you should see all 3 mode lights now on steady , no pf error and it doesnt turn off, and you can change modes and temps.
Posted on Nov 16, 2009
  • super_guy Nov 17, 2009
    PAC CT90?? no wonder you can't find the cover then... I've only worked on a PACL90 which was what I thought yours was based on the category it was filed under.
    When I say cover for the PACL90, I mean the entire front and back cover piece. The front and back cover should be held together by a couple of screws. Once you get the screws off, then the cover pieces should pop off from the base. Then you will be able to access the main board which is located near the exhaust vent.
    I haven't done this in a really long time, but I believe it takes around 30 mins to dismantle to get to the board
Our telephone and answering machine quit working after a power outage. Pushed reset button but nothing changed. The letter E is in the window of the base unit. When unplugged the power supply and...
it sounds like the unit has taken a surge, which is a common side effect of power outages. unplugging and replugging make fix the issue but since you have already tried this, i would reccomend contacting the manufacturer. See if a replacement can be given or if you have warranty on the unit.
The E is most likly a refrence to general error. the main board for teh unit was probably damaged by the power outage.
Mar 07, 2011 | Uniden EXAI 918 Cordless Phone
Screen shoes PF after power outage
PF = power failure such as an outage from a storm.  mfg reccomends you unplug for a period of time.  i would suggest about 15 minutes.  then try it again
Jul 30, 2010 | Whirlpool Calypso GVM9959K Top Load Washer
I have a Kenmore Ultra Bake Stove, we had a power outage and neither the oven nor burners works. The code on top reads PF 5Ab. What can i do to reset the stove?
PF is usually power failure.
If "PF" appears at any other time, a power failure occurred. To remove "PF"and to reset the clock, press STOP/CLEAR.
Unplug the unit for half an hour or so to see if it will reset.
If not try to get into the diagnostics so you can see if there is a stored
error code
Feb 15, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I have a ' Firenzi ' electric oven which has ceased to function after a recent power cut. The word ' STOP ' appears on the display. Can you help? Regards Norman Dayton
HI. This will occur when a surge has entered the unit, due to the power outage. Normally, there will be a power surge when the power is re-introduced to the home circuits after a brief outage. This will damage most unprotected electronics in this situation. The most vulnerable area in the unit will be the main control board. I would advise to try a hard rest. You can initiate this by simply shutting down the appropriate circuit breaker, or unplugging the unit for 5 minutes. Once the 5 minutes have passed, kindly re- introduce power to the unit, and try to run a baking cycle. If the word stop, or PF illuminates on the display, this will confirm that the surge has damaged the board. It must be replaced, in this case.
Nov 13, 2009 | Ovens
PF Flashes? Any ideas?
PF simply means your Power Failed sometime since the last use.
Power off and Power on to remove the PF Code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
May 10, 2009 | Kenmore Elite 45986 Front Load Washer
Flashing pf
pf indicates power failure, even a slight glitch in the power can cause this. If stop/clear does not clear the fault, unplug the unit for a few mins. and plug back in. pf may reappear, again press stop/clear, this should clear the error at this point if it had reappeared. if not then further investigation will need to be done.
Thanks for using Fix Ya, please take the time to rate this solution
Feb 01, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Won't start
is the light going off when the door is closed, and on when opened??? sounds as if you having ansd issue withthe door switch, notthinkin the door is closed, try manually pushing the buton in, you should hear it "click", if it doesnt, i would unplug hte unit, nad witha screrwdriver you can pry the switch out from the side of switch. Dont ask me why buit for somereason afetr removing from the unit, it then will"click". somply prerss back inot place.Never actually had to replace teh switch, perhaps it gets stuck!
Jan 11, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Pf code on frigidaire professional series free standing range
"PF" indicates the electronic control detected a Power Failure.
This could have been caused a brief power outage OR may be an indication that the connections to the oven, either at the stove or at the plug are loose.
Jun 09, 2008 | Ovens
Heating & Cooling Logo
130 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
