Question about HP Compaq Presario SR2013WM (RE468AA#ABA) PC Desktop
When I turn on the computer I can't see anything. I take off the RAM and turn on the cpu and does not happend anything. What should I do next ?
  • richard simpler
    richard simpler May 11, 2010
    hello there i will suggest first. checking power supply to c if it's working. next i would open up the computer case and i would diconnect the hard drive and the cd rom from the motherborad. and then try to reboot. and now stilll nothing where your power supply hoooks to your mortherborad diconnect and then press in the power button for the computer and hold 30 sec. and do the same thing to your reset button. then reconnect everything again. let me know how this work there's more we can do. ty richard
  • 4,281 Answers
Eset motherbord settings to defaults you can reset with 2 methods.
(1)Pull cmos cell from motherbord for 10 minutes so all settings defaults.
(2) Find jumper on motherbord named "Clear cmos" It has 1-2-3 pins.Put jumper in 2-3 position and thne power up then again put pin in 1-2 position thne all settings defualts.
Refix RAM memory.Clean dust from all parts.
Open processor and processor fan.
Remove pci cards from motherbord then check.
Make sure motherbord not ground with cabinet.
Let me know if you need further assistance.
Posted on Nov 16, 2009
  • 74 Answers
Clean the mother board, processor and check ide
How much ram and what kind of ram
If you are referring to computer RAM always put the largest ram module closest the CPU central processing unit
try to keep the same brand and type of ram the same ie: ddr ddr3.......
you will be able to read the ram type on the ram already inside
make sure you secure the ram modules by pressing the levers down firmly at both ends of of there sockets
make sure your computer is turned of before you attempt this
be sure to wear an earth strap before touching anything inside your computer
the ram modules sockets are located near your cpu
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
hope this helps you
Apr 07, 2012 | Computers & Internet
Sx280 upgrade 2mb ram blank screen
hope this helps you
Mar 09, 2012 | Dell Computers & Internet
Need to install memory
be sure to wear an earth strap before toudhing anything inside your computer
images?q=tbn:and9gcq9t3-tizq_ocdyjdr3jm_7ne5ygw4opkreacbpjb_njv8n4zrdnq
hope it helps
Jan 09, 2012 | Gateway Emachine Bestec ATX-250-12E PS...
As soon as i turn on my computer it turns blue and it will automatically shut down it wont turn back on im not sure what happend to it nothing was wrong with it.
This isssue was System RAM, to resolve this follow the below steps,
1. open your CPU cabinet, and remove the RAM and wipe the insert portion in the slot and replace again in to same or other slot and power on the PC.
2. it should work fine, if the issue remains same replace a new RAM.
3. to confirm the ram problem, remove the RAM from the slot and power on your PC, you will here a continuous beep.
Thanks.
Dec 05, 2010 | Computers & Internet
The monitor is not displaying anything and the
Make sure the vga cable is connected to CPU and the CPU is on if it is giving the beeps then remove the ram clean it and fix it again.try with removing the cmos battery also.
Have a nice day and do not forget to rate please...!
Feb 15, 2010 | Computers & Internet
I installed the motherboard with the cpu 3500+
There could be many things that could stop the board from turning on, Determining what is wrong is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or otherwise) the CPU, and one bank of memory. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Also, if your going to load a ide drive, make sure you set your pin setting correctly on it. Now, you should get the power supply on, and the cpu. If those don't power up, it's then either one of the five elements. The CPU, Power supply, Ram, Drive, or the motherboard. The next step is to replace each one of the first four with another to see if you get any change. Also, on the drive, try a different cable to make sure it's not that, If no change, then I usually get another board that I can test the first four, and make sure that they work. If after that and you have tested all of the components and they all work, then it's save to say you have a Dead Board
Good Luck and don't forget to leave a rating.
Thanks
Mark
Dec 12, 2009 | MSI K9VGM-V Motherboard
Fails to boot, fans and lights on, no bios or anything
My recommendations would be to remove all connections to the board.
Remove the CMOS battery.
Remove the CPU fan and CPU.
Look at the top of the CPU, if you have a crust over the top of the CPU, you will need to remove it to a clean surface.
Next, your CPU fan should be a 3 wire connection on the motherboard, within two inchs of the CPU holder.
After cleaning the CPU, re-inseart and apply a heat sink lub for good heat transfer.
Re-install CPU fan and plug in to board connection.
Re-install your CMOS battery and power up unit.
With the CMOS battery removed, the time and date will need to be reset.
Also, in the BIOS for that board, you should be able to see temps. and rpm readings. ??
Hope the CPU has not taken a dump on you.!
Before you plug in the drives and other devices, check temps. rpm and voltages.
Have fun, hope this has helped you.
Oct 06, 2009 | ASUS P5GD1-VM Motherboard
PC stays in Sleep Mode and Keyboard and Mouse doesn't work
Well that's kind of a loaded question.
There is several things that can cause this to happen.
1. The CPU died because the cpu fan just died and burnt it out.
2. The Ram is bad which I doubt.
3. Somthing happend and burnt out the motherboard sometimes we get insects that climb inside our computer and go onto things and alot of stuff in the computer that can be grounded by a bug or whatever and burn out our computer I've had it happen before.
The monitor is fine it's just blinking because it's not getting a signal from the P.C.
You can try to unplug the PC and plug it back in and try again or even check in the back on the power supply there is a I/O switch make sure it's on.
Dec 24, 2008 | Computers & Internet
The Computer doesn't start, and the Aux Power light is on.
remove the ram from mboard ok
then stsrt the computer if u listning beep sound power off computer and put the ram in slot nicely again start computer
if computer dont start change ur RAM
Jan 05, 2008 | Dell OptiPlex GX260 PC Desktop
HP Compaq Presario SR2013WM (RE468AA#ABA) PC Desktop Logo
188 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
