Question about IBM NetVista PC Desktop
CMOS battery, where to find it and replace it
  • 4,281 Answers
Open the cpu cabinet cover.
Then you can see motherbord on its surface.
There is cmos cell on motherbord.
You can see image of cmos from below link.
click here
Posted on Nov 16, 2009
Testimonial: "Thank you this led me directly to he position I needed. Battery was changed using a ground strap. All is well again. Thanks"
  • 2,359 Answers
Depending on the model,it can be a coin size cell in silver color.
It's sitting on a socket that is soldered on the motherboard.
POWER OFF NetVista,use a gounding strap before open up the casing.
The part number is starting with CR____.
The battery CR number may be block by the battery hold down tab.
Take your time to locate and replace it.
This is also a good time to blow out any dust inside the casing and fan(s).
After replacing the battery then reconnect all cables and power on the NetVista.
Enter the CMOS and set time,data,drive information (auto) and boot order.
    Brigadier General:
  • 10,406 Answers
Turn the computer off.
Disconnect the power-cable.
Remove the side-cover.
Look on the motherboard (peeking around all the cables & wires) for a shiny circle, about the size of US $0.25 piece -- that is the battery.
Note that there will be some engraving on the "top" of the battery.
Gently pry the battery out of its "socket".
Remember which side of the battery has the engraving!!!!!
Take the battery to a Battery Store, and buy a replacement.
Insert the new battery, remembering which side has the engraving.
Reconnect the AC power.
Replace the side-cover.
Turn the computer on, and press DELETE to enter "BIOS-setup".
Select "Load Defaults", and then "Save&Exit".
How do i replace the cmos battery
any generic replacement CMOS battery with the same specifications and size measurement as the original battery will do, I am not to familiar with the battery used on your laptop, for it may be installed with retaining clips, it may be soldered to the main board, or via sockets with wires, if you are not to savvy with electronics soldering , have someone who knows how , to do it for you. Replacing cmos battery is actually easy once you have secured the replacement part. refer to your computer manual for the location of the cmos battery on your laptop.
Oct 19, 2014 | Battery Biz CMOS Battery for Acer Compaq...
Replace cmos battery and case openning
Asus motherboards usually use a lithium CR2032 battery for CMOS. Also, on the top of the old CMOS battery you took out there should be the exact battery type engraved on the surface.
Batteries Plus in Wichita, KS has a good online store for purchasing your replacement battery.
Dec 12, 2013 | ASUS CS5111-AP007
How do i replace a cmos battery in my hp compaq nc2400
I was unable to locate your specific laptop this might ge you some in sight in what to look for and how to remove cmos battery remember some cmos batteries are soldered in
RTC battery replacement procedure on Compaq HP Mini 110 netbook & clear CMOS http://www.youtube.com/watch?v=P_cxAireIsw
Feb 26, 2013 | HP Compaq nc2400 Notebook
Location of cmos battery
These are the most basic signs your CMOS battery is going dead and will be your ultimate test of the battery
http://www.bing.com/images/search?q=cmos+battery+images&qpvt=cmos+battery+images&FORM=IGRE Bios setting are saved in cmos batteries
make cmos battery has charge and is not loose
cmos battery images
How to replace the CMOS battery in your laptop http://www.youtube.com/watch?v=MTg8qhWKNpA
Feb 19, 2013 | Computers & Internet
Reset cmos
Removing the CMOS battery for 15 mins will reset the CMOS.
The CMOS failure most likely is caused by a flay CMOS battery. replace the CMOS battery will fix this problem.
Oct 24, 2012 | IBM ThinkPad T41 Notebook
Got message "CMOS battery low" What steps are
Assuming you know how to get into your computer and identify the CMOS battery, you just need a pair of tweezers or similar to remove the battery. Once it has removed, take it into a drug store or pharmacy and find the exact same battery, and replace it in the motherboard. If you can't identify the CMOS battery, please let me know and I can help you with that.
Jul 19, 2011 | Computers & Internet
BIOS reset
By resetting the CMOS battery all you need to do is to teardown your laptop and have to remove and reinstall the CMOS battery. And for the replacement of the CMOS battery of your Samsung laptop just call SAmsung technical support so that they can give you the exact model of the CMOS battery and where you can have the battery. Thank you.
Oct 10, 2009 | Samsung X05 Notebook
Bypassing password
short out the jumper pins labeled CMOS
Jul 09, 2008 | Fujitsu Siemens Celsius R610 PC Desktop
Where is the CMOS battery?
Yes that was the cmos battery, I'll see if I can find a better solution for this issue for you.
Feb 13, 2008 | Compaq Armada M700 Notebook
Cmos battery?
Computer CMOS information CMOS is an on-board semiconductor chip powered by a CMOS battery inside IBM compatible computers that stores information such as the system time
How to replace the CMOS battery. Information about why time may be lost or decreasing rapidly and how to replace your computer cmos battery
Computer Battery Help The first type of battery is the backup battery, which is commonly referred to as the "CMOS battery".
Good Luck, Please dont for get to Vote/Thank You
Dec 19, 2007 | HP Pavilion N3390 Notebook
IBM NetVista PC Desktop Logo
397 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
