Printer/fax problem the screen says sc551 functional problems
  • Dale Richards
    Dale Richards May 11, 2010
    What model number?
    Problem Solver:
I have the same problem with an Infotec 2220D after moving it to a new office.
I understand this error stands for : "Pressure roller thermistor open"
Does anybody have any idea where it is exactaly inside the copier and how it looks so i can close it?
please email me.
Posted on Mar 11, 2008
Whats the make of the copier ie: Ricoh, Canon
Posted on Mar 08, 2008
WHAT IS THE CODE SC551?
Symptom]
SC551 (thermistor disconnect: thermistor2) or SC561 (thermistor disconnect: thermistor3) is displayed.
[Cause]
The drawer connector surface is partially corroded.
A foreign object or debris has adhered to the surface of the fusing unit drawer connector contact and, when the adhered moisture melts due to condensation, it causes part of the surface of the drawer connector to corrode. It becomes clear that SC551/SC561 occur because of faulty contact with the image fusing unit.
[Resolution]
Replace the drawer connector on the device.
Apr 25, 2016 | Office Equipment & Supplies
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
Sc551 error in Ricoh aficio 1013
SC551 - Standby overheat
Symptom: Temperature during standby or
low-power mode remained too
high for a specified interval (10
seconds or 25 seconds,
depending on the mode).
Possible Cause: TRIAC short
Mar 09, 2011 | Ricoh Aficio 2016 All-In-One Laser Printer
Panasonic uf 4000 fax not answering
Sounds as if your Fax is set to Tel Mode.Change to Fax as follows.
Function 7,then no 4.
Will show fax parameters? on screen.Press Start arrow up to recieve mode.Arrow across to change to Fax or Fax Tel.Press start to lock in.Press cancel button to return to raedy screen.
Sep 01, 2009 | Panasonic PanaFax UF-490 All-In-One Laser...
Printer shows error CH551
Is this actually a Ricoh Aficio 1013F, or another model, because "CH551" is not a ricoh service code?Do you mean "SC551"
If so, this is a fuser "triac" problem (basically a fuse in the heater unit). It can only be reset in service mode after the problem is fixed...and will require a tech.
May 21, 2009 | Ricoh Aficio 1013F Copier
The printer prints from the PC but will not copy without the PC
Please reset your printer to factory defaults form on screen printer menu > > >
Dec 31, 2008 | Brother Multi-Function Center MFC-240C...
Fax noise
-utiliy/counter
- Admin (pass 12345678)
- fax settings
SCREEN 2 (see at the right bottom of the screen), u ll have an option to turn off or lowwer the noise of your fax)
Oct 31, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Fax receive problem
hi
i had same prblom, now it fixed
1-press(set up)3 times you will see on the screen(basic fax set up)
2- press enter
3- Click the right arrow utill you find (ringe to ansure)
4- press enter
5-than chose how many rings
6- press enter
7- good luck
Apr 25, 2008 | HP PSC 2210 All-In-One InkJet Printer
Infotec IS 2220D Copier (same as aficio 1022 i think) SC551 Error
Start by pressing clear modes, 1, 0, 7, and press and hold clear/stop. enter copy sp, select 7 fot data log, scroll to 7807, and execute. exit all the way out, and recycle the power. See if that does not fix your problem.
Mar 25, 2008 | Ricoh Aficio 1022 All-In-One Laser Printer
217 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
