Question about Motorola Mobility CLIQ Cell Phone
My speaker is distorted and i need to change the volume every time to make it sound good. Should I tek it back and get a new one?
Speakers have a crackle in the sound also rear speakers not working
can mean several things. The crackle is subjective and can mean distortion. Distortion most of the time comes out of the amplifier. Could be you have blown a capacitor in the power supply of the amplifier, making it work with quasi half the voltage. There is no need to change the polarity on a speaker, because when one is not working infuse, it won't distort the music. You only could have difficulty with the stereo sound. It could be a bit unclear where the sound is coming from and could sound a little less powerful.Check the speakers on a different amplifier, to hear if I'm right. Only if you switched on sound while the amp was giving full power, you could have blown the speakers, but most of the time they don't give any noise after that.
Jan 16, 2015 | Ranger Communications 1998 1999 2000 Ford...
I have a sony MP# player, same range as listed but the 8GB model. I can only turn volume up to 16 before it starts distorting and giving a really bad and weak signal though the headset, when the stereo...
Headphones are not designed to have the volume levels run at maximum. At this level the sounds from the headphones will distort.
Speakers have a much larger voice coil and therefore will not distort at higher volume levels.
Also when the speakers are connected to the MP3 player the sound level may appear lower because speakers require more energy to drive (produce sounds). In this case you need to connect powered (amplified) speakers to the MP3 player.
Mar 10, 2011 | Sony Network Walkman NWZ-S545 Digital...
Hercules XPS 210 sub problem. distorted sound
I think you've just answered your own question. It sounds as if you've coned the sub woofer. Meaning you've fractured the bond between the edge of the speaker body with the speaker cone. Or overheated the voice coil and it's distorted and not getting free movement. Excuse the Pun but it "sounds" like you need a new speaker as a replacement. If it's a particularly expensive speaker it can be reconed. A check of the Net for someone close to you will find a company who recones them. If it's a cheaper one then a replacement would be in order.
Apr 21, 2010 | Audio Players & Recorders
I have to have the voume at 30 to get good sound
Try going into the menu and selecting the sound menu and resetting the sound to factory default..If this doesnt help matters you can change the sound preferences to custom settings..As long as the sound isnt distorted at low volume then this solution will apply..If the sound is distorted at low volume then your speakers may be faulty..sometimes caused by listening to the tv at full volume over long term which strains the speakers and prematurely ages them
Oct 17, 2009 | Samsung HP-T5044 50 in. Plasma TV
Asus A8N32 SLI Deluxe Motherboard audio problem
The new boards multiplex the connectors on the back panel to maximize use. Open the Realtek control panel and configure for sterio 2.1. Also, these new boards do not provide any power drive, so to get decent volume, you will need amplified speakers.
Oct 09, 2009 | ASUS A8N-SLI Premium Motherboard
GK 1001 rb speaker overload, is my guess
This problem is not likely to be a volume control problem. There is a transistor inside that is failing (getting noisy) when heated up. If you have no experience with amp repairs, do not attempt this as it is not simple to locate the defective part. Continued use in this condition can cause problems with the speakers. Please have this serviced by a repair shop with experience with GK gear.
Dan
Jul 29, 2009 | Crown CE1000 2-Channel Amplifier
Playback distortion
Good day sir, distortion can be caused by several factors, 1. overdriven audio source, try tuning down the volume to half. 2. the speakers are defective due to driver's coil scratching the magnet. need to replace the speakers, better swap first any good known speakers. hope this may help. if you may have any more questions, feel free to ask again. thanks
Jul 18, 2009 | EMC Zotac GF6100-C-E MCP61P GeForce 6100...
JVC DVD player plays with distorted sound
Have you tryed a differant audio input on another set or on that same set. Are the audio cables good?? If all this is ok then the D/A converter inside the unit is defective and most likely it wont pay to repai sorry
May 25, 2006 | JVC XV-N40BK DVD Player
Z-2300 noisy speaker
ur speaker is bad probebly torn membrane try replacing it (or disconnecting) this speaker there is a special kind of glue for membranes .... try it good luck windman
Oct 26, 2005 | Logitech Z-2300 Computer Speakers
Motorola Mobility CLIQ Cell Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
