Just replaced projection bulb on my hitatchi lcd tv model55vf820 and in have blue spots all over screen
  • 5,138 Answers
Blue spots mean Bad light engine Call these 2 companys for Parts Encompass Parts Distr. 1-800-638-3328 and UED 1-800-648-6657 you can also visit their websites and try E-Bay under Electronics & Parts for TVs. Ok Encompass Has 2 Price is 857.00 and 50.00 off for your old one But try other companys you might find one cheapeer on E-Bay or UED! Part # UX25302 Optical Engine assy.
Posted on Nov 16, 2009
    President:
  • 1,779 Answers
Defective Light Engine, very costly.
My Hitachi 60VG825 projection TV is 3 years old. For the past several months the screen has been turning blue around the outer edges & this past week a large yellowish green spot the size of a...
Sounds like Calibration is needed on the projection internals. Your TV uses a rear-projection system and the problem is either in the imaging LCD Unit or the light filter. I see in a previous thread you have changed the bulb. You can invest in a voltage regulator to keep the hardware in factory condition.
Also you can burn a DVD of a stuck pixel remedy video and run it on the screen with full brightness and full contrast. This is used for plasma burns and stuck pixels on conventional Flat panel TVs but can repair color issues with projection systems. This therapy is focused on the imaging unit between the projector and the main drop of your tv.
please feel free to post a more in-depth description or any changes
Nov 06, 2009 | Hitachi 60VG825 60 in. LCD Television
Hitatchi 52" rear projection TV has blue spot in middle of screen
Hello :
I suggest u retrace you the steps u took to replace your lamp make sure no foriegn objects got on the prism where the light shines throung the optics engine, if you remove the lamp compartment througly. If you had a perfect picture prior to replacing the lamp, then retracing your steps you might find something that does not belone. One final note: Did you purchase the right lamp 120watts anything higher than this wattage could damage your optics engine. I suggest never vacuuming the compartment because particals fly around from the suction and could get on the glass of the color wheel asembly.
Sep 25, 2009 | Zenith D52WLCD 52" Rear Projection...
Blue spot on screen center. Peoples faces and show blue tint
if you have a Sony LCD projection ..Theres good chance optical block needs replacing .This spot will get bigger and will eventually cover most of screen the longer you use it .needs repair.If there is no warranty on this unit..I would estimate repair around 6- 8 hundred dollars ..
Aug 06, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Blue & green star like spots on Panasonic rear projection LCD TV
The EEPROM needs to be reprogrammed. You should contact Panasonic customer care as they may fix this at no charge to you.
Jul 07, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Sony Grand Wega 60WF655 TV blue tint/spots
sounds like your optical block lenses has melted due to heat.
( common problem) here is the light engine/optical block number
A-1084-658-A
Mar 18, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Hitachi projector model CP X260 projects yellow spot on screen
This is probably the polarizing filter. It will need to be replaced. It should not cost very much to fix.
Jan 07, 2009 | Office Equipment & Supplies
Blue dots and blue screen on Hitatchi 50"
Bad Light Engine Call UED for rebulit one 1-800-648-6657 They are not cheap.
Dec 26, 2008 | LG RU-44SZ51D 44" Rear Projection...
Pink and Blue Spots
Sony guarantee the consumer to replace the optical block assembly for thousands of dollars in parts and labor every four years or when the pink and blue spots appear every time. Then replace the optical block assembly again and again every time the spots appear.
Aug 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Blue spot
the model number KP-51WS510 deosnt use a bulb or lamp. and touching the face of the lamp will not cause color problems in the picture. if your tv is an LCD projection then i would suspect the optical engine as the culprit. to check when you turn the tv off do you still see the blue distortion? if so then you have a bad optical engine.......as long as it is an LCD projection.
Apr 04, 2008 | Sony KP-51WS510 51" Rear Projection...
Televison & Video Logo
298 people viewed this question
Top Televison & Video Experts
Electro Med Services...
