Question about Vehicle Parts & Accessories
Ive installed a Bulldog RS82 remote starter on a 2008 toyota camry. The remote starter works fine, the problem I'm having is that the keyless entry remote on the Toyota key does not unlock the doors after the car starts via the remote starter. Any fixs for this?
  • whitetm Dec 09, 2009
    I found out that the 2008 toyota disables the keylees entry after the car starts. The only way to bypass this is to install a remote starter with its own keyless entry and not use the factory one.
  • 344 Answers
There is no solution to this, it is factory setup to prevent you from locking your keys in the car when it's running and so the trunk can not be opened by accident
Posted on Jan 04, 2010
Some cars will not operate locks when remote started. if you start the car with the key, check if the oem remote will still operate the locks or not. there is a way to make the locks work with the aftermarket remotes, so long as the equipment supports that function. in some cases it requires you to run wires into the driver door, or into the output wires on the lock relays.
you will be better off hooking up the locks to the new system.
Posted on Dec 24, 2009
I have the same problem on a 1999 Honda Civic, did you find a solution?
Posted on Dec 09, 2009
I installed a bulldog remote starter with keyless entry and the doors won't unlock or lock with remote, why?
Were the lock and unlock wires connected to the system?
Lock: Gray/White (-) @ 40 PIN CONN OF BCM PIN 27
Unlock: Gray/Red (-) @ 40 PIN CONN OF BCM PIN 26
Do you have a Smartpass key or a regular key? What bypass are you using for the remote start system?
Jan 09, 2013 | Remote Starter with Keyless Entry
My heater fan won't work when car remotely started with Bulldog remote starter
The yellow wire at the ignition switch is not connected to the remote start system. Once it is connected to the accessory output of the remote start, it should work properly.
Jan 08, 2013 | Remote Starter with Keyless Entry
Put an rs82 bulldog remote starter in my 2005 town and country, and after 11 seconds it stops and re engages the remote starter and stops after 11 seconds and stops completely
It sounds like the RS82 is not getting a proper tach signal. If you are using tachless mode, the 12 volt constants may not be providing the desired signal. Recheck your connections to ensure that they are solid. The high amperage wires should be soldered. You will need to connect the tach wire if the connections are good. The tach wire can be connected to the negative side of the ignition coil's blue/brown wire or the blue/green wire at the PCM or you can use any one of the uncommon colored wire at a fuel injector.
Oct 10, 2012 | Remote Starter with Keyless Entry
Bulldog m200 just stoped working
If it is the same brand and model you will not have to rewire anything
Jun 09, 2009 | Remote Starter with Keyless Entry
Vehicle Parts & Accessories Logo
734 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
