Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftsman Garage Opener intermittently not closing
I have a craftsman garage door opener. Has always worked fine. Suddenly, it will close about a foot, and then retract. But not all the time. In order to make sure it closes, we have to either hold the remote button, or hold enter on the keypad for about 10 seconds. Then it will close all the way. I checked the track, the chain, everything seems clear. And now, suddenly today the light doesn't work anymore (yes, I replaced the bulb). The opener was installed by previous owner, and I had the actual door replaced when I moved in four years ago.
A couple of other notes. It will always open just fine. My wife tried to manually close it when this started to happen, and the pull string came off, but that should have no effect(?). This was the first time anything happened.
Any idea what might be causing this abnormal behaviour?
  • Rob Pettigrew Nov 16, 2009
    This was fairly helpful. The bulb works now. The sensors appear to be aligned, and I even slightly adjusted one...but there's more to the story now. One of the sensors has a green light on it, and it goes out when I block it. The other sensor is street-light amber, and does not go out when blocked. I think that will be my issue, but not sure if the sensor is shot, or if this means the wire is faulty... Any thoughts?
    President:
  • 3,197 Answers
A couple things to check and do. If the main light flashes 10 times when the door reverses to the open position it is a door sensor problem. Make sure they are pointed at one another and that the small light on each one is lit and not flickering. Tweak them a bit if necessary.
If the main light isn't flashing it may just be a simple adjustment. Locate the 'down force' adjustment on the rear of the motor unit near where all those white wires go. Increase this about 1/4 turn and try.
For the light you should unplug the unit and then using a small screwdriver pull out on the center contact in the light socket.
Posted on Nov 16, 2009
I need to know how to reingage a Craftsman garage door opener
All you need to do is cycle the door open and then closed.
Mar 15, 2017 | Building Materials
Why would a Craftsman model 139.53985DM garage door opener not open when it is cold outside?
Safety light issue. Blocked beam. Misaligned beam. Or broken wire.
Mar 03, 2015 | Building Materials
Craftsman 1/2 H/P garage door opener door goes closed but then opens
Try adjusting the "closed switch" forward a little in case the door is going too far when trying to close.
Sep 03, 2014 | Building Materials
My craftsman garage door opener gets stuck when closing and always goes back up
Release the door from the opener by pulling down on the rope. Then you can operate the door by hand and see what is binding.
Sep 29, 2011 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Door Opener Intermittent
Yes your receiver is bad and it is part of the logic board.
Jul 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't close with remotes
Yeh, read manual. Do both sensors have led lit. try aligning. you have safety beam problem,
Jan 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door Opener Intermittingly Reversing
try adjusted the sensor controls on the sode of the unit other wise replace the logic board
http://www.chamberlain-garage-door-openers.com/circuitboardcompatibilitychart.htm
Dec 24, 2007 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
275 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
