Question about Optoma TX770 DLP Projector
My projector does not see my computer. what can I
My projector does not see my computer. what can I do?
  • 2,237 Answers
If you are using a laptop, you have to activate the external monitor port (vga out).
Posted on Nov 16, 2009
No signal from computer to projector
That might be because of the weak or bad connection of computer or the projector. Also you should check whether the projector is out of order or not.
http://mhelpdesk.com/field-service-management-software/
Dec 25, 2013 | HP Compaq Presario SR5130NX PC Desktop
I changed my desktop background and now my projector will not display
I would start by cycling this through the f4 option again first. Next I would connect the projector to the computer and then booting up the computer. Next I would disconnect the projector...turn it off, connect the projector again and then power up the projector. Try every combination of sequencing to get the computer and projector to talk to each other. It would not be a bad idea to change out the cable and try a new one as well. If it is a ceiling mounted projector then connect straight to the projector and try that.
Jan 07, 2013 | Hitachi Office Equipment & Supplies
Infocus 5000 won't recognize my computer
How about a little more information?
Does the projector turn on?
has it ever worked?
What type of interface (VGA, DVI, HDMI, RCA)
What type of computer (notebook or desktop)
That being said, double check your cable connections and make sure you tell your computer to look for the projector (Dell laptops used to use FN+F8 to switch from laptop to projector). Windows 7 has a menu choice "Connect to Projector". Mac computers - check system preferences and make sure the projector is ON before you plug it into the Mac.
Nov 25, 2012 | InFocus ScreenPlay 5000 Multimedia...
Tutorial
Hi Connect your computer monitor out VGA connector to Computer input VGA connector of projector. Select source in projector (with remote) as computer/RGB/VGA as terminology used on the projector..
The projector will work as large screen projection monitor for the projector.
If you want to use monitor and projector both, you can use 1IN-2 OUT VGA distribution amplifier (Commonly called as "VGA Splitter"
Jun 26, 2012 | NEC Np13lp - Projector Lamp - 180 Watt -...
HOW TO USE DAYLIGHT PROJECTOR IN STEP BY STEP
Hi LCD projectors have revolutionized the audiovisual industry. With a few clicks of the mouse and strokes of the keyboard, whatever you type on your computer appears instantly on a projection screen in real time. If you have never experimented with an LCD projector, however, do not worry. You can learn how to use an LCD projector.
  • Plug the LCD projector in to a power outlet. Completely plug the power cord in to the back of the LCD projector.
  • Step 2Use a VGA cable (usually a 15-pin male to male) to connect your computer to the LCD projector. Insert one end of the cable into the VGA connector (sometimes this connector is blue) in the back of your computer and do the same in the back of your LCD projector. If the LCD projector has more than one VGA connector, choose the one that says something like "line in" or "in from computer."
  • Step 3Power on your laptop. Turn on the LCD projector. It may take a couple of minutes to warm up. Open the computer file or document you wish to display. When you are ready to project your image, press "Function" (Fn) plus "F8." This combination of keys sends your computer's display to the LCD projector.
  • Aug 03, 2010 | BenQ (200NSH-LAMP) Projector Lamp for...
    Projector will not detect a Dell computer
    Computers do not generally send an RGB signal, you should be connected via a VGA cable between the projector and the computer. The input menu on the projector should be set to VGA. The output of the computer should be equal or lower to the maximum resolution of the projector.
    Jan 29, 2010 | ViewSonic PJ551 Multimedia Projector
    What button do I push on my toshiba to connect to InFocus proje
    on the projector, computer. on the computer, it depends on the computer. also, make sure the computer resolution matches what the projector can handle (max 1024x768)
    Mar 12, 2009 | InFocus X1 Multimedia Projector
    Computer used to work with projector, and now doesn't?
    Have you tried pressing Fn F5? On my system (HP), by computer monitor goes dark when I connect the projector. Pressing (Function) FN F5 toggles the video between Computer Monitor, Projector, or Both.
    Check the function settings for your computer. On my Compaq laptop at home, the video function is F4, so there may be different settings for your computer.
    Jan 10, 2009 | Office Equipment & Supplies
    Blue patch
    you didn't state how many hours are on the unit, but I'm guessing close to 3,000 hours, that is when most brands have LCD panel failures, due to the heat over time the coating on the lcd panels burns off, the panels start to burn up, and it gets worse with time, and you notice it more when you put a fresh bright lamp in. if it is low hours then you could have a bad lamp, that casts a bad tint, but it sounds like fried LcD panels, a sure way to tell, is put up a white back-ground screen and see if you see discolored "BLOB" in the center of the screen.
    keeping the filters clean, and the projector cool is the best way to prevent this.
    Nov 09, 2007 | Hitachi PJTX100 Multimedia Projector
    Optoma TX770 DLP Projector Logo
    46 people viewed this question
    Top Optoma Office Equipment & Supplies Experts
    jasbo
    jasbo
    color wheel light...
    Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
