Question about Whirlpool Duet GHW9150P Front Load Washer
When i hold the start button, the machine will not begin the cycle
  • 4 Answers
Get a chair look behind the washer and unplug the electric cord and then wait a few seconds and plug it back up then do a drain and spin to get the washer to finish gettting the water out so you can get the door open or just rewash the clothes. You may have to try this a few times. My wife has had the same problem and this is what I do to get the washer going again.
Posted on Nov 16, 2009
Whirlpool adp 4404 5 - how to do a RESET?
It is probably stuck in the dry cycle.
Press and hold the start button to clear it.
You should hear it pump put while it resets from memory.
May 27, 2014 | Dishwashers
ERROR CODE 61
If you have Zanussi washing mashine
To enter diagnostics:
  1. Switch off the appliance
  2. Press and hold down START/PAUSE and any one of the option buttons simultaneously
  3. Holding down both buttons switch the appliance on by turning the programme selector one position to the right (clockwise)
  4. Continue to hold down the START/PAUSE and option buttons until the LED begins to flash (at least 2 seconds)
In the first selector position, the operation of the buttons and the relative Led's is checked; turning the selector knob clockwise activates the diagnostics cycle for the operation of the various components and displays any alarm conditions.
Apr 21, 2014 | Washing Machines
Whirlpool adp 9411
If this is the machine with just a knob for the wash cycles, and one button to start the wash cycle, you will have to replace the timer. There is no reset that I know of.
Dec 16, 2013 | Dishwashers
I have a Breville Fresca BES860 2Cup Coffee Maker and I've lost my manual. The Clean light is on and I can't remember what to press to start the clean process on my machine. Can you please...
Turn your machine off, then push and hold the 1 and 2 cup buttons and then while still holding them push and hold the power button. Wait until the clean cycle begins.
Sep 07, 2011 | Breville Fresca BES860 2Cup Coffee Maker
My machine keeps bleeping to tell me the cycle is finished but will not begin another programme ?
1. Set the cycle knob to any "X" (reset) position
2. Press and hold the Pre-wash and the Start buttons at the same time. While still holding these buttons, turn the unit on by pressing the On/Off button
3. Keep holding the Pre-wash and the Start buttons until the digital display comes on (about 5 seconds)
The digital display will show 00 for no faults or will show a fault code.
To end the test program turn the washer off at any time
Let me know what error codes come up, if any.
Nov 25, 2010 | Bosch Washing Machines
Need to know buttons to press to self clean.
Taken from the Use and Care guide:
To clean and freshen the washer, perform the System Clean Cycle. For best results use the System Clean Cycle once a month. To begin the cycle, press and hold the Spin Speed and Options buttons simultaneously for 10 seconds until the display changes to "CLn".
IMPORTANT
Items left in washer while performing the System Clean Cycle will cause a severe out-of-balance situation that could damage the washing machine.
REMOVE ALL ITEMS FROM WASH DRUM before filling the detergent chamber with one (1) cup of liquid chlorine bleach OR one (1) pouch of TIDE® WASHING MACHINE CLEANER. DO NOT use both. Press Start/Pause to begin.
If the System Clean Cycle is canceled or paused during the cycle, the washer will go through 2 rinse cycles to clean the drum of any residual bleach before unlocking the door.
Cheers!
Oct 29, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Ariston A1436 The machine begins to fill then empties and fails
Make sure that the top of the waste water pipe is at the correct height for the machine, typically around 30-34 inches from the floor (see your installation instructions). If it is any lower then it will start a siphoning action as soon as the water reaches the same level in the machine and never actually fill up and hence the cycle will not start. If the machine detects that insufficient water has entered the machine within a given time, typically 8 minutes, then if flags an error to the on board controller. If the error persists after the waste pipe height is corrected then check out the pressure switch for correct operation as if this is not triggered then the cycle will also not start or will halt almost immediately.
Oct 25, 2009 | Washing Machines
Lights on Washer Machine flash but Washer doesn't work
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 31, 2009 | Kenmore Washing Machines
Reset wash cycle
Changing Cycles, Options and Modifiers
Not all Options and Modifiers are available with all cycles. Cycles,
Options and Modifiers can be changed anytime before HOLD TO
START is selected.
Options and Modifiers can be changed anytime after HOLD TO
START is selected and before the start of the selected Option or
Modifier.
To cancel a cycle and select a new cycle
1.
Select PAUSE/CANCEL twice.
2. Select desired cycle.
3. Select the desired OPTIONS.
4. Select HOLD TO START (for approximately 1 second) to
restart the washer at the beginning of the new cycle.
To cancel a cycle
1.
2. The washer powers down, the door unlocks, and clothes can
be removed.
NOTE: If the water level or the temperature is too high, the
washer will drain automatically before the door unlocks.
To change Options or Modifiers after the cycle has started
1.
Select PAUSE/CANCEL.
2. Select the desired OPTIONS or MODIFIERS.
3. Select HOLD TO START (for approximately 1 second) to
continue the cycle.
To drain the washer manually
1.
2. Select DRAIN/SPIN.
begin the drain.
4. When the spin is complete, the door unlocks. Items can be
removed from the washer.
Nov 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bosch washer spin only
Had a repair man here for the same issue. Learned two things:
1. Too much detergent causes 'soap lock.' The electronics will get confused when there's too many suds left after a rinse and shut the spin cycle down. That's why re-running the entire cycle without more detergent solves the problem. Use less detergent.
2. There is a way to manually get the spin cycle to run using diagnostics codes. Here's what my guy did:
a. Washer selection knob in OFF position.
b. Hold the 'Spin Selection' and 'Delay Start' buttons down at the same time.
c. While holding those two buttons, turn the Washing selector knob to Permanent Press-Cold.
d. Keep the buttons held down until the LCD control panel reads 'P:01'
d. Release buttons.
e. Use the 'Spin Selection' button to cycle thru the codes. Stop when it reads 'P:04' which is the spin cycle.
f. Press 'Start/Pause' button to begin the spin cycle.
I don't know what the other codes do but this should save you from having to run the entire wash cycle.
Hope that helps! Tim
Apr 17, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Whirlpool Duet GHW9150P Front Load Washer Logo
65 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
