Question about HP Office Equipment & Supplies
Need to clean the under side of the glass. Need
Need to clean the under side of the glass. Need to know how to remove the glass assembly for cleaning
I found a service manual on-line that showed the method for removing the glass on the scanner.
Posted on Nov 18, 2009
Why are there brown/white streaks inside oven door glass after using self cleaner 1 time?
Thank you for your post, friend!
From my understanding after you used the self-clean feature on your Frigidaire range you now have brown and white streaks on the indoor glass. Typically streaks can be removed by cleaning the interior glass. Normally it is recommended to have a professional clean the inside glass but a consumer can do it as well. Use caution when following the steps some pieces can have sharp edges. You will need to have a Phillips head screwdriver or small quad bit driver.
A. Refer to owners guide for instructions on how to remove oven door.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner.
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Hopefully this is helpful. -Matt
Aug 23, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
How to clean between glass oven doors on whirlpool oven?
You need to remove the inner door panel, Usually a few screws holding it on. On some models the handle screws also need to be removed. Do it slowly and carefully as the door may want to swing up quickly, once the weight on it is removed. Pay close attention to each step so all screws etc go back in the same place. Make a diagram as you take them out to be sure.
Aug 10, 2014 | Whirlpool RBD305PD Electric Double Oven
How do I take off the outer glass on oven door on a frigidaire oven model FEFL74ASG
Good Afternoon clynns108 - Thank you for your question. Here are some generics steps to help you remove the door to your range or you may reach out to a professional directly to further assist you:
Tools needed: Phillips head screwdriver or small quad bit driver.
CAUTION: Edges of door may pose a cut hazard, use gloves or heavy cloth when grabbing edges.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
I hope this information helps to some degree.
Jun 26, 2013 | Frigidaire Ovens
Frigidaire oven door glass clean inside
Good Morning Suzi - Generally, qualified technicians often perform complicated part replacement such as this, however this may or may not be specifically for your model. Below are generic instructions that I found on how to take your oven door apart to remove any stains that may be caught down in the door vents.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. Refer to owners guide with door in broil stop position lift door assembly off hinges.
May 24, 2013 | Frigidaire 27 in. Electric Double...
HOW TO CLEAN THE GLASS DOORS
Hello larryjkelly - This may or may not be specifically for you model, however below are generic instructions that I found on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: good Phillips head screwdriver or small quad bit driver.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side.
I. Lift out center clear glass from wool shield, this glass just lies onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc.
I do hope this proves to be helpful.
Feb 25, 2013 | Electrolux ICON Designer E30SO75ESS Oven
On my frigidaire gallery series oven, how do you clean the glass of the oven door window (between the inside and outside)?
Below are instructions on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Aug 16, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Ihave a hp all in one printer scanner and copier, there is dust under side of glass how do I clean it the model is b110, been like it from new don't seem to be able to get hold off hp
HP says below that for your printer it can't be cleaned except by an authorized dealer. I know from experience that flat bed scanners/all-in-one's have small holes in and around the tray that houses the scanner assembly. If you take canned air and use the long straw that comes with it, you can usually do a fairly decent job cleaning the underside of the glass. It won't necessarily be perfect, but I've found that it's better than what I had before.
You may be able to find several spots to feed the straw through to blow air at the glass.
PLEASE....DO NOT TURN THE CAN UPSIDE DOWN AND SPRAY. You'll inject liquid into the scanner assembly tray and onto the glass. Have someone help you turn the printer upside down or on it's side if you need to get the angle to spray.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu01831&cc=us&lc=en&dlc=en&product=79499&tmp_track_link=ot_search#N89
Flatbed products have a large scanner glass under the top cover.
NOTE:
The underneath side of the scanner glass cannot be cleaned on any product. This is unlikely to be necessary and should only be done by an authorized service provider.
Regards
Apr 07, 2011 | HP PSC 2210 All-In-One InkJet Printer
Sharp al 1000, the scanner is on and goes right and left all time
The simple fix is to clean the reference strip under the glass. There is a white strip under the left edge of the glass that the scanner reflects off of in order to set up the scanner bulb intensity. When this strip gets dirty the the machine just keeps trying. I would remove the cover on the left side glass area with the 4 screws. On the bottom side you will see the white strip. Clean this with glass cleaner. While your in there I would go ahead and remove the large glass. Turn off the main power and pull out the scanner bar and clean 3 mirrors. One is the "slot" in the main scanner bar and then the 2 in the assembly to the left that trails the main scanner bar. Once cleaned put it all back together and this scanner bar "referencing" issue wil go away. If it does not (which is rare) then there is a problem with the scanner/ccd unit and the machine is really not worth repairing at this point.
Good Luck and Thank You for using Fixya.
We are having a contest this month based on positive testimonials. If my solution is helpful to you, please take a moment to leave a short testimonial.
Thanks!
Oct 05, 2010 | Office Equipment & Supplies
Glass panel unstuck
if product is beocenter 9000/8000/8500/9300/9500 remove screw under l/h side of panel, push panel to side and remove.careful to note position of plastic attachments and metal screw socket.lay face down on bench and apply thin ribbon of epoxy resin where double sided tape is,do not clean off old tape.apply glue over top.assemble plastic parts on top and leave to set.refit to machine and refit screw.
Oct 14, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Scanner faulty
you can't, this is a famous problem on all of these HP machines, however, its relatively easy to solve: you need t remove the keypad, then remove the scanner glass - under the scanner glass is a white strip that need to be cleaned with glass cleaner. You should also clean the mirrors on the scanner assembly. I have repaired about 50 of these machines, both inkjet, laser and scanner only in this way
May 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
237 people viewed this question
Seeker5211
Seeker5211
