Question about Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive
WD external Hard drive 320 GB hangs my computer everytime connect
I have a WD external Hard drive 320 GB I format it using the disk management tool in windows vista, and I moved some data from my laptop, then suddenly it when ever I connect the drive to any PC or laptop and try to go to windows explorer to see the contents of the hard drive that machine hangs until I remove the hard drive. please help
All solutions are not helpful, if u just use safe mode then there is no problem with hard disk, its a problem of some services, u just try with safe mode.30-40% people has same problem.
girish
Posted on Feb 05, 2010
    Scholar:
  • 54 Answers
I'm not sure if you had any progress on this, but try the drive on another PC. This should determine whether the problem is related to the drive or your PC. If the same thing happens on the other PC, try another USB cable.If all else fails, try WD's diagnostic software for any fatalities.
http://support.wdc.com/product/download.asp?groupid=301&sid=3&lang=en
Posted on Jan 20, 2010
    Brigadier General:
  • 10,406 Answers
Try the external hard-drive in some other computer.
If it still causes problems, then it is the external hard-drive, not your laptop, that has the problem.
If the warranty on the external hard-drive is still valid,
exercise the warranty to get a replacement.
If the warranty has expired, you could try to "disassemble" the casing, to remove the "internal" hard-drive that is "inside" the casing.
Then, connect that hard-drive to a desktop computer,
and copy your data to the 'C:' drive (or burn your data to CD/DVD disks), if you can -- it's possible that the "electronics" that convert the USB-interface to the hard-drive interface is the problem, and that your data on the hard-drive is perfectly OK.
Posted on Nov 16, 2009
I attempted to install this in my computer using a SATA to IDE converter cable. Dos picks up the harddive, but windows doesn't seem to show it anywhere. I attempted to use the WD format program, but it...
  1. When you install a hard drive, it must be activated, partitioned, and formatted. Open your Start Menu, then open the Control Panel.
  2. Open the Administrative Tools control panel.
  3. Open Computer Management.
  4. Select Storage > Disk Management.
  5. Find your new drive, right click on the drive and partition and format your drive to see it in Explorer.
Aug 05, 2011 | Western Digital WD Scorpio WD3200BEVT hard...
WD elements hard-drive not working, powering up fine + PC is making the noise associated with a USB port connecting to an external source, but the Hard-drive is not showing up on My Computer and is...
Try on any other computer first.
Download Hirens Boot. Place burned CD and reboot with it. Run Norton Ghost (bundled with Hirens Boot) and select USB option. Do a disk check.
Mar 06, 2011 | Western Digital Elements powered by WD 320...
My new WD 320 GB external drive won't detect in my pc and laptop? pls help....
Hello there,
Please try to plug it into another USB port. There is a chance that your port could be faulty. If its not with the port, try to assign the drive letter if you are using windows. You have to right click on the My Computer icon, select Manage. Once on Computer Management, select Disk Management. Locate your WD drive and right click again. Finally, click on the Assign Drive Letter and follow the wizard.
Dec 26, 2010 | Western Digital Elements powered by WD 320...
My wd elements external hd is not recognized under windows 7. The pc diagnostics say that the device is working properly and the correct drivers are installed?
Go to Administrative Tools in Control Panel. Computer Management then Storage, Disk Management. You'll probably have to recognise it and assign a drive number.
Jun 18, 2010 | Western Digital Elements powered by WD 320...
Internal 320 hard drive into external
If you got a USB casing for that, it would have come with a USB and power cable. Yes, power too!
Plug the power, and make sure you have a USB 2.0 hi-speed port. Also check "computer management" and check the hard disk works.
May 24, 2010 | Western Digital (WD3200JS) 320 GB Hard...
External Disk WD Elements problem
did u format the wd 320 gb already
you have to format it first to work from it
Apr 06, 2010 | Western Digital Elements powered by WD 320...
My computer hangs when I start it up until I remove the WD 320 GB External USB connection - then it will restart ok. I have to then reconnect the hd. - what can I do about this?
It sounds like it is trying to boot from the external drive, go into the BIOS settings and disable boot from external device and see if that cures it.
Mar 30, 2010 | Western Digital Elements powered by WD 320...
Black
Try to go through disk management and see if it works?
Open control panel then select administrative tools then disk management. Then in left column click disk management.
If you locate it may be it must be initialise by the system or need to create partition by formatting.
You can also check all the cables , the power cables the adapter , try to change the Usb cable also..
ok
Good luck !!
Jan 22, 2010 | SimpleTech 320GB SimpleDrive External by...
WD 1TB Hard-drive, worked perfectly now it won't :'(
If you go into Administrative Tools, Computer Management, you will see a tree for disk management. It should be listed there - probably without a drive letter..
You can partition and format there.
To get to administrative tools: Go into your control panel - click on classic view and it is one of the top options.
Jul 12, 2009 | Western Digital Elements powered by WD 320...
Format external hard drive to NFTS
Assuming you are running Windows XP or Vista, the easiest is through the Disk Manager.
Open the administrative tools from the Start menu and select Computer Management. Then select Disk Management in the console.
Now you can right-click the disk and select Format. Chose NTFS and wait for it to finish (which will take some time!).
Do realize that this will erase your data on the disk. If you do not want that, you need to use the CONVERT command from the command prompt. type CONVERT /? to find out about its usage.
Jules
Apr 04, 2009 | Western Digital Elements powered by WD 320...
Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive Logo
1,304 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
