Question about Sony Handycam DCR-TRV27 Mini DV Digital Camcorder
On the DCR-TRV27 I don't see a black roller on Error C:31:23 on Sony trv27
  • 405 Answers
It probably fail off,which is very common problem, roller should be still inside of the camcorder. You also have to look for small white, lake tubing part that hold pinch roller on the shaft.
Posted on Nov 16, 2009
Blank screen no image in camera mode is it an image sensor and can it be fixed
Mostly. image sensor causes the blank screen, but especially the Iris is the problem in this model.
Example:
Sony CCD TRV68
Oct 17, 2014 | Sony Handycam DCR-TRV27 Mini DV Digital...
What does a c32:11 error code mean on a dcr ip55
cek your mechanism by ejecting, and look for pinchroll (looks like black tire a bit right before head, is it there?,if it's on its place try pooling up if it's to easy to pool you need like straw small enough to slip it in the middle pinchroll, perhaps you can use container tint pen.
hope this solve your problem
Oct 23, 2013 | Sony Handycam DCR-TRV27 Mini DV Digital...
Have c31:23 error code. Researched and think I am missing black rubber roller inside tape compartment. Does anyone know where I can get one, or what it is called?
I actually once got the same issue on my TRV27s. Double check inside the tape compartment, and make sure the roller is really gone (mine had just slid out of position). If it truly is gone, eBay is about the best bet for locating a new one.
Jun 01, 2011 | Sony Handycam DCR-TRV27 Mini DV Digital...
I JUST BOUGHT A USED SONY HANDYCAM DCR-TRV27 MINI
Congratulations! Please use the following link to download Manual, Operation Guide and other things.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DCRTRV27
Aug 14, 2009 | Sony Handycam DCR-TRV27 Mini DV Digital...
Can NOT copy aN original DVD made from Sony Camcorder DCR-TRV27
Try Finalizing the DVD disc on the Camcorder or the DVD Recorder before trying to copy the DVD on the Computer.
Jun 16, 2009 | Sony Handycam DCR-TRV27 Mini DV Digital...
This is one of the most common problems on sony camcorders. It is caused by the loosening or loss of the rubber roller inside the tape drive mechanism. Try tapping the top of the cam when the tape is inside. If this doesnt work, open the tape deck and look inside to see if you can spot a single rubber roller inside. If not, then the roller has worked itself loose or gone AWOL missing..:(( However, fear not...the solution for this is to go to an office supply store and obtain one of those compressed air cans used for dusting off keyboards and such. Amazingly, the plastic tip on the compressed air can (where the air comes out) can be used as a replacement for this rubber roller. It fits the metal spindle that formerly held the roller perfectly and allows the cam to function without the rubber roller and without the dreaded C31:23 "your camera is dead and useless and will no longer function" evil Sony message... Check out this link for a discussion of this problem: http://wvstephens.blogspot.com/2008/05/sony-handycam-c3123-3123-error-easy-fix.html
Jun 12, 2009 | Sony Handycam DCR-TRV27 Mini DV Digital...
No sound download from DCR-TRV27 Sony Mini
All I needed was the correct software for downloading video and sound. And that happens to be the software that came with the camera.
Thanks...
Feb 03, 2009 | Sony Handycam DCR-TRV27 Mini DV Digital...
My Sony MiniDV TRV27
The moisture that got inside has probably begun to corrode the connections to the control panel. Your best solution is to get the camcorder to a qualified technician and get it cleaned (the circuit boards cleaned) as soon as possible. If you want to try opening up the unit yourself (I don't recommend this because the units are fragile inside and easy to damage) you will be looking for the ribbon cable and the connector where the control panel connects to the main board. You will likely see either a white crystalline substance or perhaps a black substance on the connector or the ribbon cable (this is the corrosion ) which you can clean off with a toothbrush and perhaps some Caig Labs R5 (available from Amazon, a type of contact cleaner). Be sure to rate this solution. Thanks!
Nov 08, 2008 | Sony Handycam DCR-TRV27 Mini DV Digital...
Sony DCR-TRV27
i have (or probably had) the same problem. Try this - there is a small reset button on the left side panel of the camcorder. While the set is on VCR model press this and keep pressed for 30 seconds or so. The corrected image should return and probably the problem would go away. I tried this by chance and the problem doesn't seem to recur.
good luck.
I have another problem though:
In my Sony DCR-TRV27 - A part of the left side console buttons do not work - the tape controls (REW, FF, STOP, PAUSE, PLAY) work alright. The Memory Stick controls seem to work alright. But, pressing the Menu button does not bring any menu display on the screen. Similarly, the scrolling wheel on the front seems not working. A couple of years back the moisture went inside (I went to Niagara falls!). For few weeks whole of the panel wasn't working but now most of it works. But I cannot get the Menu option work. I would be glad to hear if you have any other suggestions / advises. thanks for your time,
Nov 06, 2007 | Sony Handycam DCR-TRV27 Mini DV Digital...
Sony Handycam DCR-TRV27 Mini DV Digital Camcorder Logo
304 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
