Water leaking from bottom Sears Model
Major water leaking from bottom of unit. Sears Model 110.84670100 serial no C71118240 repairable? parts avail?
    Genius:
  • Washing Mach... Master
  • 1,474 Answers
1st you need to find out where leak is..Is i t just a hose ? or major like hole in drum/ if hole in drum forget repair...
Posted on Nov 16, 2009
  • 3,600 Answers
Most likely the water pump go to this web sitte to get the parts price and break down on the macine for repairing. you need to raise the washer to be able to see exactly where it's commming from I use a 2x4 to or 2x6 to raise the front of the waser up far enoght to see where the water is comming from and use a flash light. be sure to stay out of the water while it is running or unplug it altogether if it leaks plugged in or not, then use the flashlight to find the leak. be arare it could be the hose or the tub seal as well and that water travels. Use you hand to feel excatly where the wter is comming from. the web site is http://www.applinacepros.com. If you need more help just post to this answer to get more help.
Need a replacement fan motor
In the United States, we type "Sears Parts Direct" into the computer to get parts for U.S. appliances. If you are in the US, try this. If you are not, perhaps you can type the equivalent in to your computer for the part you need. Be sure to have the model number and the serial number available.
God bless your efforts.
Jan 18, 2016 | Liebherr CS2062 Bottom Freezer French Door...
Side by side whirlpool refrigerator leaking water puddle in front on floor no loose connections and no signs of water from any part of refrigerator
Hello;
My name is Peter. I am a retired field service refrigeration technician.
There are several areas where you may have a leak.
Let's check it out:
You are going to have to pull the unit out so you can inspect what is going on.
Turn the leveling screws counter clock wise to raise them. Pull the unit out so you may get behind it.
25576703-vzgcvxho43azc0x10cxafhpi-5-0.jpg 1.) Observe the plastic tubing going to the water dispenser.
The plastic tubing after time get dry rot. Have someone push the water dispenser and observe the tubing for leaks. But before this put a paper towel under the bottom hinge of the freezer door.
So, if you observe water coming from the tubing that is your problem.
Or if the paper towel in the front is wet, then you have a major problem. There is a leak in the door tubing which is only repairable by replacing the door, which is several hundred dollars plus service - $600.00. You can disconnect the contacts on the larger tubing valve and not use the water dispenser.
Ok, no leaks. Then you have a drain pain leak. Un-plug the unit. Remove the lower bottom cover in the back. Just several screws. Inspect the drain pan. Is there a water line from the pan to the front of your unit.? Repair the drain pan with duct tape and a silicone adhesive.
Inspect the bottom of your freezer. If there is ice then you have a different problem.
Keep me informed. Glen Burnie, MD., Email goodwinpeg@aol.com, Phone: 414-306-1362.
Mar 15, 2015 | Whirlpool Refrigerators
Source for gear for fellowes 301101 DS-1 paper shredder
Replacement Parts - Paper Shredders Can I get my Fellowes paper shredder repaired or purchase parts for it?
The majority of Fellowes personal shredders (small shredders that can fit under a desk) are repairable and will have parts available. If you would like to check your model shredder to determine if parts are available, please click the "Ask a Question" tab above, and advise the model of shredder, the shredder's serial number and a description of the part needed. The serial number will be located on the bottom side of the shredder head below the bar code.
*** Please note: If your shredder is still within the warranty period, we ask that you do not open your shredder until speaking with a Fellowes Representative, as opening the unit may void your warranty.***
Fellowes office/commercial shredders (large shredders that cannot fit under a desk) are repairable and parts will most likely be available. Please do not try to repair the shredder yourself or you will void your warranty. Models included in the office shredder line are 125i Series, 225i series, 325i series, 380 series, 420 Series, and 480 series.
If you would prefer to have a local servicing dealer provide repair service to your office shredder, and would like to find a dealer in your area, please see the below link to search for a dealer by zip code.
http://www.fellowes.com/Fellowes/site/support/support_authorizeddealers.aspx
To order replacement parts, or if your model shredder is not listed, please click the "Ask a Question" tab above to ask us about your shredder. *** Please be sure to include your serial number from your shredder for the fastest service ***
Our office hours are 7:00 AM to 7:00 PM, Monday through Friday Central Standard time.
Jan 22, 2015 | Fellowes Office Equipment & Supplies
Spare parts for a fellows p45-c shredder
Can I get my Fellowes paper shredder repaired or purchase parts for it? The majority of Fellowes personal shredders (small shredders that can fit under a desk) are repairable and will have parts available. If you would like to check your model shredder to determine if parts are available, please click the "Ask a Question" tab above, and advise the model of shredder, the shredder's serial number and a description of the part needed. The serial number will be located on the bottom side of the shredder head below the bar code.
Go to
http://www.fixya.com/answer/answerpageslideview.aspx?ctg=176&fml=0&brd=mine&thid=24364827
and 'Ask a Question' give personal details, and that will give you details if spares are available
May 08, 2014 | Fellowes PS8C Shredder
Ice in bottom of freezer and leak
There are drainage paths to provide a way for water to exit to the pan located under the cabinet, during the defrost cycle in all 'automatic' defrost units. Depending on their construction, these can become clogged with solid detritus or mold.
Unfortunately, some of these will be sandwiched between the inner and outer shells making them very difficult to access.
You might try entering your make and model number on the page at the link below to see if Sears has a line-drawing illustration of your unit; these can often be helpful in determining how tough a given job might be.
Sears Parts Direct
They offer parts for 1000s of appliances other than Kenmore.
Jul 01, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
Leaking door seal. The rubber seal at along the bottom of the door appears to be leaking. Is it easy to repair?
make sure you take the model and serial #'s to an appliance parts house to ensure the proiper replacement part. Also if you will soak the gasket in hot water for an hour it will make it more plyable to install onto unit. If you pull back gently on the current gasket you will see the connection screws and how to remove them.
Hope this helped you
Dave
Mar 03, 2010 | Siemens 24 in. SE53200 Built-In Dishwasher
Water is leaking from the bottom. Is it still
This model wasn't really intended to be repaired. Some replacement parts (mounting flange, etc.) are available, but the low cost makes it uneconomical to put labor and parts into repairs. No parts are available for the enclosure, so even if the source of the leak can be found there won't be much you can do to fix it.
Feb 20, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
MOdel 110.92579110 leaking water out bottom of
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.92579110
LEAKING:
See the Sears site sub-components for the agitator, basket and tub. It's possible that one of the gaskets or seals has worn over time.
I'd also pull off the cabinet and check the hoses leading to and from the pump. It's also possible that the pump is leaking.
See the following for how to remove the cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
The illustrations also show how to remove the transmission.
OIL
The black oil / fluid that you see is likely coming from the transmission.
Since it seems to be "spraying" around the inside of the cabinet, I'd assume that it is leaking from the top seal between the transmission and clutch.
See the following for a parts breakdown of Whirlpool top load direct drive washers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
If you look at page 15, you'll see a Seal, Gearcase Cover. It is possible that that is the cause of your transmission leak.
The rust on the bottom of the transmission may (hopefully) be simply caused by the water leak.
I'd remove the gearcase cover (8 bolts) in order to check the gearcase cover seal, and to check the oil level. The Whirlpool transmission takes about 15oz or 80-90 weight oil.
Oct 17, 2009 | Kenmore Washing Machines
Water leak from my Kenmore refrigerator
Your problem is most likely a clogged drain line. Which is located in the back bottom of the freezer a little hole. Run some hot water down it with a spray bottom and it should resolve your issue. Also yes a Tech will be able to fix this problem
Jun 01, 2009 | Refrigerators
Washing Machines Logo
Top Washing Machines Experts
