Question about Motorola Mobility i776 Cell Phone
I can only use the speaker on my motorola i776, there in no sound from the earpiece on phone?
Cant hear out of earpiece, only speaker
two possible causes. either your earpiece is faulty or the flex cable is faulty. because the earpiece is on the upper side, it is linked through the flex cable and if there is a cut on the flex cable, then that may affect the earpiece lines. also, poor contact of the earpiece may cause that. open unit, ensure the earpiece has contact, check the earpiece itself and finally the flex cable.
Regards
Aug 18, 2010 | Motorola Mobility i776 Cell Phone
I have a i776w i must puy callers on speaker phone to hear them what can i do please help me this is becomming very irritating for me
The problem with your phone is that the earpiece on your phone is bad that is why you cannot hear the party calling you or hear anything while you call.
All you need to do is to replace the earpiece on your phone and you will see that you can hear whoever you are talking to on your phone.
Change the earpiece on your phone and you will see that the problem is solved. meanwhile, you can keep using the headset pending the time you will replace the earpiece.
Take care.
Aug 11, 2010 | Motorola Mobility i776 Cell Phone
I have a Motorola i776w i must put the caller on Speakerphone or use an earpiece to get audio.
Hi, when you start using a phone with speaker and earpiece,it means that the earpiece inside the phone that allows you to hear others when they call you is faulty,and you will need to replace it,for you to stop using the speaker.
Take care.
Jul 02, 2010 | Motorola Mobility i776 Cell Phone
Cell Phone i776 no audio or any sound through the earpiece
You will need to replace your phone ear piece these can be done by a local repair man
Apr 29, 2010 | Motorola Mobility i776 Cell Phone
Its a common ailment of the 776. They have display issues, charger issues, speaker issues, and the camera is horrible. Motorola is planning a recall/buy back, with gift cards to purchase another phone.
Nov 17, 2009 | Motorola Mobility i776 Cell Phone
My I776 cell phone does not operate in a normal fashion I can only hear or speak when in use in spkr on mode or bluetooth and earpiece.
get a new phone there buddy or take it intop a place like rogers and they may be able to fix it for u even if your not setup with them
Nov 11, 2009 | Motorola Mobility i776 Cell Phone
The earpiece does not work
99% of a non working earpiece is in the earpiece itself.,in the wire,in the part of Jack's root.Due to a regular movement when you are using it there is the risk to cut or detach the very thin wire on it..But,on the other hand,check your earpiece to use it on other cellphone,and if it works,then the problem is on your fon itself.
Nov 05, 2009 | Motorola Mobility i776 Cell Phone
When I make a phone call I cannot hear anything.
check and replace the earpiece speaker
if not try to rework the UEM
Oct 15, 2009 | Motorola Mobility i776 Cell Phone
I cant hear anything on my i776 unless it is on speakerphone... i'm pretty good at tinkering with phones but i just got this one
There is a defect with the i776 phone. I called 611 on phone using speaker and that is what they told me. Your phone has a year warrenty and motorola has to replace it call motorola at 1-800-453-0920 or they can fix it
Sep 02, 2009 | Motorola Mobility i776 Cell Phone
Motorola Mobility i776 Cell Phone Logo
270 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
