Question about Sharp AL 1631 Copier
Sharp al-1631 copier. drum error code
Hello i have a sharp al-1631 copier. is there a way to by pass the drum cartridge error to see if the copier works. I got this item free my work was going to trow it out.dont want to waste $50 to get get new drum to find out something else is wrong also.
  • iam2trickey Nov 17, 2009
    Still has error coming up it is for the toner cartridge not the drum. its looks like a triangle with red circles on it. i tried it 5+ times. is there a way to bypass or a manual paper feed.
    thanks
  • 1,110 Answers
You can reset this indicator by pressing these keys in sequence:
Press "C" then press "Exposure Mode" then "C" again then "Exposure Mode" again.
Note that the Exposure Mode key is the far left key on the panel.
One you press these 4 keys in sequence the display should go blank. Then key in 24 as if to make 24 copies. Then press Print (Green Button)
Then key in 7 as if to make 7 copies.
Press print again. You should now get flashing 000.
Turn machine off then back on and the light should be gone.
Here it is in a short version:
C, far left, C, far left, 24, print, 7, print,
then power off and back on.
Posted on Nov 16, 2009
Testimonial: "Ok sorry thank u. I am new sorry i will be better in the future."
  • Edwin Martens
    Edwin Martens Nov 17, 2009
    Why in the world would you give me a no help rating when your original question said you had a drum light on? And I gave you the solution. NOW you say it is a toner cartridge? That is just not right for you to negatively impact my rating like that.
    If your toner light is on there is no reset other that to refill or replace the cartridge.
  • Edwin Martens
    Thank You sir....sorry if I was too harsh.
My sharp al-1631 has dark 1/4" vertical line on right side only. drum replace lite or cart. replace are not on. i've cleaned transfer wire many times. still have line. help??
Posted on Apr 16, 2010
Toner cartridge spreads toner all over inside
If the toner cartridge is dumping toner it is defective and needs to be replaced.
Dec 08, 2014 | Sharp AL-1631 Drum Unit - 18000 Pages...
I do I remove the old drum in a sharp AL 1631 copier?
You have to open the door on the right side of the machine first, then you can open the front door. Remove the toner cartridge and then you can remove the drum unit.
Jun 02, 2011 | Sharp AL 1631 Copier
Sharp al 1631 need drum roller reset code
enter code 42 start 1 start.
(press C auto C auto 42 copy1 copy)
Apr 28, 2010 | Sharp AL 1631 Copier
On a Sharp AL-1631 copier I installed a new TD Cartridge and ????
That must be the drum cartridge symbol anyway do this; Press C, Exposure, C , Exposure in that sequence.The display will go out. Enter 24 press print 07 print. Then press C twice and you are done.
Nov 12, 2009 | Sharp AL 1631 Copier
Sharp AL 1631 Drum Icon only blinking
Hello sir; After install drum unit you need to reset, the procedure as follow;
1, press "#", "*", "clear", "*",keys.
2, enter 24 press start enter 07 press start.
3, turn power off and back on.
Jan 31, 2009 | Sharp AL 1631 Copier
Sharp AL-1631 coper - toner problem
the problem in your machine is on the drum unit there is a arching on the mc unit.located in the upper portion of the drum unit.if you have an old drum unit try to install it again just for testing.and check if ther is a dumping toner again.
Nov 05, 2008 | Sharp AL 1631 Copier
Sharp AL-1631
Several things can cause this problem; The drum cartridge is not being cleaned properly or there is a problem with the toner cartridge . Take out the drum cartridge and inspect it for any signs of the defective image. If that doesnot solve the problem, then Call a tech.
Apr 20, 2007 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
433 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
