Question about Lexmark T632 Laser Printer
Continues to say paperjam in tray 1 but we find no paper!!
  • 555 Answers
"Paper jam" error is activated by a switch. Perhaps the switch sensor is the issue. Be sure the sensor is not blocked or out of place. It is usually a small black plastic piece that usually moves freely.
Posted on Nov 16, 2009
T652n 202.03 paperjam
1Open the upper-front cover and remove the toner cartridge.2
Look into the printer. Remove any jammed sheets of paper that you find there.
  • If the print job only consisted of this one page, reinstall the toner cartridge and close the front cover. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If the print job consisted of more than one page, confirm the entire paper path is clear before printing again. Do the following:
    1. Remove the top paper tray ('Tray 1').
    2. Remove any jammed or partially-fed sheets of paper you find here, then reinstall the tray.
    3. Go around to the back of the machine and open the upper-rear cover. Remove any jammed sheets of paper you find, then close the cover.
    4. Once you have confirmed that the entire paper path is clear, reinstall the toner cartridge and close the front cover.
    5. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If you cannot locate any jammed paper under the toner cartridge, then check the rest of the printer for any jammed paper. Do the following:
    • Remove the top paper tray ('Tray 1') and look for any jammed or partially-fed sheets of paper.
    • If you do not find any jammed pages there, reinstall the tray and go around to the back of the machine. Open the upper-rear cover and look there.
    • If the entire paper path appears to be clear, close the rear cover and power off the printer. Reinstall the toner cartridge and close the front cover. Power the printer back on. If a 200 error continues on power up, a sensor in the printer may be malfunctioning. This will require a service call to correct the issue. Please contact Lexmark Technical Support for additional information (see Contacting Lexmark Technical Supportbelow for details).
Aug 28, 2012 | Lexmark T652N PRINTER OPPENHEIMER SPECIAL...
The amber light with the triangle next to it is flashing please help!!!
That is the ATTENTION state. Four things can cause it to flash.
1) empty paper tray
2) door open
3) paper jam
4) misfeed from tray.
Press the GO button(the diamond). If it still doesn't work, check for a paperjam.. Also try printing from the manual feed tray.
Aug 21, 2010 | HP LaserJet 1160 Printer
Getting the message "241 Paperjam Check Tray 1" I've checked tray 1 and have not found a paper jam
Turn the printer upside down and shake to find any paper jam as in most cases you will find some paper or dust falling out and then try.
Jan 26, 2010 | Lexmark T630 Laser Printer
Says paper jam but NO paper is in the machine
One problem i found with those printers is that over time the casting around the paper tray is wearing off and printers starts to show paperjams when there is no paperjam.
One way to fix is try and positions the paper tray better or perhaps raising it a bit with piece of wood or paper.
Cast unfortenately is too expensive to replace so if this doesnt work and you are sure there is no paperjam and nothing obstructing the sensor then replace the printer.
Nov 02, 2009 | HP LaserJet 2200D Printer
CLX 2160 - paperjam
There is probably a jam in the paper feed area. Pull the paper tray out and stick your hand in to find and remove any paper stuck there. Then reinstall the paper tray and open and close the front door of the printer. The jam should be cleared.
If it is still showing paper jam, pull the tray out again and look to make sure you didn't miss any paper, then check the other areas of the printer (starting with the exit area) for paper.
Oct 24, 2009 | Samsung CLX-2160N All-In-One Printer
My printer says there is a paperjam but I don't see a paperjam.
its a mechanical problem ...
check the rollers of the printer ..and the paper pick mechanism ..maybe it can't caught the paper in the tray that why it display an error of jammed..
May 24, 2009 | HP DeskJet 3653 InkJet Printer
Paperjam tray 1 error code 201.52
If you remove tray 1, is there a jam? When the printer is starting to print, does it sound like it is trying to pick up paper from the tray a few times, and then changes to the jam error? If so, then the pickup rollers are worn. You can confirm this by removing tray 1 and feeling the rollers which are located in the top of the tray in the front. If they feel smooth, then they need to be replaced.
Feb 22, 2009 | IBM Infoprint 1572n Laser Printer
Paper jam - cannot get the paper tray to open
open back side paperjam clear cover. simply push the paperfeedroller towards the inside and pull the paper tray carefully out at the same moment ;-)
Feb 21, 2008 | Brother MFC 420CN All-In-One InkJet...
Paperjams
Sounds like the pick up rollers are worn or dirty.
You can try to clean them with alcohol.
When you pull the tray out the rollers
should be towards the front of the printer.
Nov 21, 2007 | HP Color Laserjet 3550 Printer
Lexmark T632 Laser Printer Logo
110 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
