Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
Shuts off a couple of times and then it's ok the rest of thr day
  • 566 Answers
You probably have a few capacitors that are getting weak in the power supply board(very common nowadays).You can find the p.supply at the end of the power cord connector, it usually is all plug ins and easy to remove,then take it to a shop to get those caps replaced. Or if you are handy with a soldering iron you can replace them yourself, they look like small metal cans standing up, the bad ones often have a rounded top with some leakage showing up, they`ll have values like 330mfd/35v written on them. Before removing the caps note the polarity and make sure the set is unplugged. hope this will help. good luck
Posted on Nov 16, 2009
  • 11,361 Answers
Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Why does my 2000 Ford Lynx shut down (engine died) at random. It happens more frequently on a hot summer day.
Classic IGN Module problem.. Could be Fuel filter.. but i would check the module
May 26, 2014 | 2006 Ford Laser
Jenn-Air refrigerator, top freezer, older model, frost-free. Ice has started forming on the "ledge" at the back wall where the lowest shelf rests. Then the ice melts and water pools at the...
There is probably a little sediment in the ice maker shut off valve. It's electrically operated whenever the icemaker starts a new batch.
You can try cleaning the valve, but it's typically not worth the trouble. I'd just install a new one. It's easy, typically just a couple screws, an electrical connection and the water connection. To prevent it from happening again, add an in-line filter BEFORE the ice maker.
Jan 31, 2011 | Refrigerators
InFocus IN72 shuts off after 20 min.
internal error. if the lamp looks ok and it doesn't have many hours on it, it might be the power supply. the capacitors dry out and do not supply sufficient voltage. the in72s do have that problem.
Aug 27, 2009 | InFocus IN72 Multimedia Projector
Television shuts itself off
i had the same problem with my set shutting off and was told it may be the ballast so i changed that but it still would start up and shut down after a few mins, then i was asked if the bulb had been changed and i had not, so i did change the bulb and have not had it shut down yet. :) (so try a new bulb)
Jun 01, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
My blackberry 8110 will not charge
this happened to me and i just shut the phone down took out the battery waited 3-4 mins put battery back in do not turn on phone but put it on charge and it should be ok.
Jan 25, 2009 | RIM BlackBerry Pearl 8100
Laptop intermittently turns off
I think this the virus problem have youantivirus with you otherwise please download free avg and scan your system
Thanks
T.Boopathy
Sep 15, 2008 | Computers & Internet
Ok super weird
you just nailed it down to the TIF moduel this is a solid state moduel make sure the wires have a good connection inside the dist also. sometimes in the dist the pickup coil rubber will go bad and cause problems if the rubber in the dist pickup where it connects to thr TIF module is weak (needs to be in good solid shape) check this out i think your close.bafac7a.gif
Aug 25, 2008 | 1995 Ford Bronco
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
189 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
