Question about HP Pavilion Laptop
I have an hp Laptop DV3515ee works fine. One day i started it up and it shows me the manufacture logo at boot up and shows the Microsoft boot Screen Looks fine from that point. after the boot screen ends the screen turns into black to show the vista logo but doesn't show and it freezes. (((My second problem in this PC))) HP Pavilion dv3515ee 3GB RAM Nvidia Notebook graphics 9300M Intel Core 2 Duo 2.20 GHz
    Problem Solver:
  • 17 Answers
The problem could be a damage to the MB by excessive heat produced by Nvidia GPU. The only way to fix this permanently is to take out the MB and reflow the GPU with heat. You can find a video on youtube how to do it. You must take out the piece of gel between GPU and cooling unit and replace it with copper bar or penny made prior 1983 - still made out of copper. Also clean the fan. Use heat transfer paste like arctic cool - not a glue, on both sides of the penny. Install win7. Win7 does not use the coprocessor and will help to ran the notebook cooler. Install speedFan 4.40 - free utility to see what the temp is of your GPU and CPU. If you did good job it will stay around 55C. If your HP notebook is still running check the temp. If the GPU is running 80C or more it will melt the connections on the MB and quit working sooner or later.
Posted on Apr 21, 2010
Acer laptop display goes off after some second
Try booting into safe mode. Chances are that you have set the screen resolution and refresh rate to some value that the LCD cannot handle. That is why it works until Windows takes over. Once you are in Safe Mode you can get things under control.
Jul 20, 2014 | Acer Computers & Internet
Acer 5920g, nvidia 8600m gs. the problem is that when I connect hdmi cable from tv to laptop, laptop screen freezes, and tv screen display hdmi logo, but without picture, If I disconnect cable, tv starts...
check windows optional updates....or try booting up with tv already linked....ooo check the display settings for dpi and Hz some tvs wont go above 60Hz
Nov 19, 2012 | Computers & Internet
My laptop was working fine Fri night and sat it was black when I went to turn it on and it has stayed that way all wkend~! I have taken the battery out and shut it off and on and still nothing. The little...
The little "stack of CD's" is a hard disk activity light.
In an ACER, if it blinks on boot, you may need to pop the PC open and bridge the BIOS jumper to reset the BIOS... Not fun nor easy, but possible.
Because you didn't state you added RAM, changed a BIOS setting, etc, we'll continue as a regular user:
First to check:
When you power on, do you get a BIOS screen? Meaning quick text showing pc info, RAM, or a splash screen (picture) saying the manufacturer, HP, Acer, ASUS, Toshiba, etc... Can you tap F2 (Acer), F10 (HP/Compaq) and enter the BIOS?
If NO,
your motherboard may be to blame, the timing of the flashing lights indicating an error, or your hard disk has died and a poor BIOS could not translate that error to the user in text format.
If YES,
Does it continue on to show a Microsoft Windows Logo, or logo depecting your operating system (os), Ubuntu, Xandros, etc?
If NO: your hard disk may be failing, physically loose, completely dead, OR your os may be corrupted. You can unplug it, pull the battery, hold power on for 10 sec, flip it over, unscrew the hard drive cover, re-seat the hard disk (pull it out, put it back). Repeat for the RAM. Add the battery, plug it in and retry.
If YES,
And the pc starts loading Windows, Ubuntu, etc, but HANGS with the hard drive light flashing, you may have a simple driver conflict issue. You can try repeatedly tapping F8 while booting and select "last known good configuration" (windows only). It may help, or you may need help.
:) Sorry!
Oct 03, 2010 | Computers & Internet
Starting problem
Immediately after seeing the Dell logo, keep tapping the 'F8' key,
until you see a "menu" (white text over a black background)
giving "startup" options for Windows XP.
Select "Safe Mode" and see if you can start in that mode.
Then, use "System Restore" to go "back" in time, to the most-recent checkpoint (date/time) where your computer _DID_ work.
Restore to that point, and restart.
Jul 17, 2010 | Dell Inspiron 1525 Notebook
BLANK SCREEN ON MY hp compaq nx9420. my laptop was working fine and then when restarted I got a blank screen. The power LED and cahrging LED both light up but screen remains blank. have changed the video...
Did it display any video at all with boot options or HP logo? Any POST test or beeps after you started the laptop?
Try removing the power ac adapter and battery. then only boot it up with just the AC adapter (no battery).
Good Luck, JAJ
Mar 30, 2010 | HP Compaq nx9420 Notebook
To stop acer logo before starting windows xp
Well, Firstly this might be a extreme case but is to reformat your hard drive removing any manufactures partition, and reinstalling the Operating System, but what i would do first is the go to start---run---(type this command and hit enter)"msconfig" the system configuration window should pop up. Go to the boot tab and place check mark in the box which says "No GUI boot" you mat also change the timeout seconds there too. hit apply then OK and reboot your system.
hope this works for you. let met know.
Oct 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
Hp pavillion hdmi output was working fine and not the tv is dark. It shows a picture when booting up but once booted, the tv goes blank. Can you offer any solutions?
I had the same problem. The first time I used the HDMI port, it showed up perfectly on my TV.
But, next day I get a blank screen. When I rebooted the laptop it would show the windows splash screen and go blank.
I won't tell you how many things I tried that didn't work.
What you have to do is stupidly simple. Right click on the ATI logo in the systray, and then left click on catalyst control center. Run the basic wizard. I'm not sure which screen it is on but choose "clone". Suddenly, a miracle happens, and it works.
I don't know what kind of genius decided to make a second display not work at all unless you ran a wizard. But thats what I did to fix it.
Jul 07, 2009 | HP Pavilion dv7-1130us laptop
Screen wont light up, cannot see the screen.
press f8 after boot up ,then select option enable vga,then when it start go to control panel,
un-install the display drivers,restart and reinstall them.
Feb 06, 2009 | HP Pavilion dv7-1130us laptop
Hp Pavillion 5000 notebook
Bad day, huh? Here area couple of quick and easy things to try that may fix your problem. Then again, they may not,but it never hurts to try!
Step1
1) Take out your laptop battery.
2) Remove your AC power cord, that's the wall power, removeit.
3) Now hold down your poser button for at least 30 seconds.
That will drain any static electricity that has builtup on your laptop system board and many times fixes the problem of ablack screen. After the 30 seconds re-connect your laptop to the wall power andhit the power button normally and see if the laptop comes back up. Reinsertyour battery.
If that doesn't resolve the situation try step 2
Step 2 Bad memory Your memory (RAM) may need to be removed, andthen put back in (reseated). The videoshares the system's memory, and will not function if there is a problem.
1) Reseatmodule(s).
2) Swapmodule, preferably with known good.
Hope this helps the situation and makes your day go better!
Ron
Dec 16, 2008 | Computers & Internet
HP Pavilion Laptop Logo
114 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
