Question about GE Dishwashers
I have a GE GSD4108 S/N DT608019A dishwasher that is no longer doing a proper clean of the top rack items, which are mostly cups and glasses.
  • 641 Answers
SOURCE: dishwasher leaves residue in top rack only
Most cleaning problems are caused by the dishwasher not getting enough water. It could be cause of the switch level, which control water level in the tub. The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine, but if you will open the rear panel you will find it easily. Be aware you should discoonect the power cable !!! Clear the tube (attached between the switch and the bottom of the washer's outer tub) from any obstruction.In case it will not solve the problem, you should replace the switch. Good luck !
Posted on Jun 01, 2006
SOURCE: Kenmore Dishwasher leaving SAND behind
1. Remove the top rack and lower rack.
2. Remove the lower spray arm by holding the top of the center hub and rotating spray arm counter clockwise.
3. Remove water tube feed from the back wall of the dishwasher by unclipping at top and back. Pull towards you and lift tab at the bottom on the big tube to remove the plastic clip from main water feed.
4. Remove the main water tube by turning quarter turn clockwise, then lift off. Keep the center hub from falling out so you don't lose the plastic washer.
5. Using a star tip screw driver; remove the four screws and lift off the filter cap assembly. The assembly consists of the screen filter and the food trap grate (The outer edges look gear like).
6. Look down inside this area and clean out anything foreign. usually there will be seeds, paper, and other gook. I used tweezers, toothpicks, and needlenose pliers. I remove from my dishwaser quite a bit of paper, two wooden match sticks, lots of undissolved soap etc.
7. When you have removed as much as you can, put everything back together in the order you removed it.
8. When you run the next cycle, you should immediatly hear more noise to indicate that you have cleared the pathway that allows water to flow at its intended pressure.
Posted on Nov 13, 2008
  • 338 Answers
SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Posted on Nov 25, 2008
larryyb
  • 291 Answers
replace the top spray arm and it should work ok again
Posted on Nov 27, 2008
kram26
  • 544 Answers
SOURCE: My dishwasher is not washing dishes on the top rack...
HI,
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary . If the motor gear is broken, replace the sump and motor assembly . Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
thanks,
Posted on Mar 18, 2009
Kenmore dishwasher ultrawash debris on glasses
Fill the soap cup with vinagar and run it while its empty.
Mar 09, 2012 | Kenmore Dishwashers
Glasses and frying pans not clean at end of cycle. Residue on glasses and cups,food particles on frying pans.
it's generally not a good idea to put really greasy items in a dishwasher along with relatively clean items such as glassware and plates and cutlery, as most recent good quality dishwashers come with a soil sensor that ends the wash cycle once the dishes appear clean, and all the grease from your frying pan will cause the soil sensor to take longer to detect clean water.
Jun 29, 2011 | Dishwashers
Always little crumbs in glasses on top rack
Cleaning screens is part of regular use of the dishwasher and how to should be included in the user guide. If you don't have one look for it on the internet by searching for user manual for your model number which can be usually found on the side of the door or frame where the door closes. Good luck.
Feb 13, 2018 | GE Nautilus 24" Built-in Dishwasher
Recently glasses started to finish foggy and
MOST OF THE TIME "FOGGY GLASS" IS A RESULT OF SOAP BUILD UO IN THE DISHWASHER. IF YOU HAVE A WATER SOFTENER AND FILL THE SOAP CUP ALL THE WAY THEN THIS IS THE CASE. FILL A COFFEE CUP WITH WHITE VINEGAR AND PLACE IT ON THE UPPER RACK, RUN AN EMPTY LOAD ON HEAVY DUTY WASH, THIS WILL STOP THE PROBLEM, YOU MIGHT NEED TO REPEAT IT 2-3 TIMES BUT IT WILL WORK, AFTER THAT JUST USE AS LITTLE SOAP AS YOU CAN, IN MY GE I USE POWDERED CASCADE BUT ONLY FILL THE SOAP CUO TO THE BOTTOM LINE, WORKS GREAT. GOOD LUCK
Jun 10, 2010 | GE Nautilus 24" Built-in Dishwasher
Cleaned plastic cups and bowls have a greasy film on them
water heater temp to low maybe new elements clean internal unit screens cascade complete jel
Feb 04, 2010 | KitchenAid Dishwashers
GE Profile dishwasher makes a humming noise
I had the same problem. The issue is due to the top rack water inlet not properly seating against the water line in the rear of the washer. I fixed it by placing heavier items (bowls, glass cups) on the rear of the rack and lighter items (plastic cups) near the front of the rack. As long as I arrange items on the top rack in this way the washer runs silently.
Oct 08, 2009 | GE GSD3800G - Multiple Color Built-in...
TOP RACK DOESN'T RINSE
I would suggest you buy some CLR and run it through a full heavy cycle with the washer empty. Be sure to put it in all dispenser areas and sprinkle about 1/4 cup into the washer before starting.
Feb 16, 2009 | GE 24 in. Profile PDW7800 Built-in...
Top shelf items dirtier after cleaning
After some experience with our own fdw60 with the same problem, we now put all pots and pans on the top rack. Putting them on the bottm appears to stop the clean water rinse reaching the top rack. All washes since have been ok.
Sep 23, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Only some cups on top rack are getting cleaned
It sounds as if you have some rollers missing on the bottom rack which lets the rack sit on the sprayer therefore not letting it spin. You should have 4 rollers on front and 2 on back of rack. If you are missing two on one side, take one from the other side until you can get some more. Just make sure you have a roller on all four sides of the rack
Jul 18, 2008 | GE 24 in. GSD4030Z Built-in Dishwasher
Dishwashers Logo
115 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
