Question about HP Officejet 9110 All-In-One InkJet Printer
Fax report stuck in queue
Tried to send a fax yesterday, fax failed and report wont print. Screen says "printing fax report one fax queued" When I bring up the printer and fax ques on my PC nothing shows. Tried turning off both computer and printer. No response to anything. Help
  • 4,402 Answers
Try unpluging the power from the fax machine/
Posted on Jan 09, 2008
First You Need to Open the Print Queue, follow the below steps on how to open a Print queue
  • Windows 98 - click Start, Settings, Printers
  • Windows XP - click Start, Printers and Faxes
    or click Start, Control Panel, Printers and Faxes
  • Windows Vista - Start, Control Panel, Hardware and Sound, Printers
Double click on the appropriate printer to open up the Print queue,Check whether you have any pending or the queued jobs, try to cancel the jobs by following the below steps.
To cancel one or more print jobs, follow these steps.
1. Click Start, and then click Run.
2. In the Open box, type control printers, and then click OK.
3. Right-click the icon for your printer, and then click Open.
• To cancel individual print jobs, right-click the print job that you want to cancel, and then click Cancel.
• To cancel all print jobs, click Cancel All Documents on the Printer menu.
If you are using an HP printer and a windows vista operating system then you are lucky to automaticlly fix the issue with the HP Print Diagnostic UtilityClick Here For How to cancel printing or to delete a print job that is stuck in the print queue in Windows XP.
Alternatively You can check the below steps.
Delete Pending Jobs
How To Restart Spooler restart In Windows Vista
Click the Start button.
Click Control Panel.
Click System and Maintenance.
NOTE: This step is not required when using Classic view in Windows Vista.
Click Administrative Tools.
Double-click Services.
On the User Account Control window, click Continue.
Click Print Spooler.
Click Stop to stop the Print Spooler.
Click Start to restart the Print Spooler. Then click Restart
Click OK
Hope this helps!
Thanks!! - See more at:
Jul 01, 2014 | HP LaserJet 4200 Printer
Hp deskjet can't delete alignment doc from queue
Logon to
select support and enter the Deskjet model number.
run diagnostics
wait for report
follow instructions
hopeful that will fix it.
Jan 19, 2018 | HP Deskjet 2360 InkJet Printer
Does my printer give a confirmation after faxing is completed?
Normally if i fax is sent, it will just give a message as Fax sent or it wont give any error.
But if you want to get a confirmation whether the fax is sent or not, you can print a fax confirmation page on ever fax sent or received or both.
Press the SETUP button ( menu )
Scroll till you find Print Report - Press OK
Scroll till you find Automatic Reports Setup - Press OK
Choose Send Only - Press ok
Mar 23, 2011 | HP OfficeJet 6110 All-In-One InkJet...
How can I print a transaction report for faxed items
select Admin Password and enter the password as "admin" and OK on both screens
Select IMAGE SENDING ACTIVITY REPORT and select FAX. This will print out the log up to a maximum of 200 events ( Tx, Rx and failed sendings)
If you want a transaction report printed for each individual transmission:
Enter Admin mode as above
Press OK then CA to exit
Feb 18, 2010 | Sharp MX-2700N Color Copier
I am trying to print from my netbook using an hp printer. i am getting an error message saying that the print queue is full.
Yes, printer won't print if print queue is full. The fact is you are lucky your printer is giving you this message. Most printers, when queue is full, will just remain silent and leave you wandering what in the world has gone wrong.
Solution is to clear the print queue. See, when you send to print and you send another when the previous hasn't printed, they queue up. Now if for any reason the first fails to print, all others will just remain queued up but will not print until you clear the print jobs queued up.
To do, this go to start/control panel/printers. Right click on printer icon and select open. The respective print queue box appears. It should have all of the print jobs listed there in the box. On the menu bar click on printer and select "Cancel all documents." A box appears asking you to confirm if you want to cancel, answer yes. Then try to print again. If it still fails to print restart your PC and try to print again.
Dec 06, 2009 | Office Equipment & Supplies
Trying to set up fax to print when sending fax
Setting print times for the fax call report
You can set the all-in-one to print a fax call report after any of the following events:
● Every fax error (the factory-set default)
● Send fax error
● Receive fax error
● Every fax
● Send fax only
● Never
NOTE If you select Never, you will have no indication that a fax failed to be transmitted
unless you print a fax activity log.
To set the print times for the fax call report
Use the following steps to set when the fax call report is printed:
1. On the all-in-one control panel, press Menu.
2. Use the < or the > button to select Reports, and then press .
3. Use the < or the > button to select Fax Call report, and then press .
4. Press the > button once to select Print report, and then press .
5. Use the < or the > button to select the option for when you want the fax call reports to be printed.
6. Press to save your selection.
Sep 24, 2009 | HP LaserJet 3390 All-In-One Printer
EPSON POS PRINTER does not print receipt
Try to clear your printer's queues up messages of all print commands that failed to print. See, what happens it when you send a document to printer, if it fails to print, and you send another, it queues up behind the first that failed to print. So instead of printing the second document it prints what you are seing, special characters etc.
Go to start/priners and faxes and right click on your printer and select open. You will all the documents for print so far queued up. select and delete them. Restart your system and the printing should be Ok.
Sep 17, 2009 | POS X POS-X XR210 Thermal Printer
Hi how do I turn of tx and rx reports on faxcentre F110/
The machine can print a transmission (confirmation) report after each transmitted fax. This report indicates whether or not the fax has reached the intended recipient. Four different settings are available for the transmission report:
  • With: a report is printed when the fax transmission was successfully sent or when it is completely abandoned. There is only one report for each fax sent.
  • Without: no transmission report is automatically printed, however, the machine will save all fax transmissions that took place in memory. The faxes sent can be viewed by printing out a transmission log (report).
  • Always: a report is printed after each successful or interrupted transmission.
  • On Error: a report is printed only if the transmission failed or is abandoned.
NOTE: With each transmission report from memory, a reduced version of the first page is automatically reproduced.
To modify the report type setting:
  1. Press the [OK] button directly below the Display Screen. '1 Installation' and '2 Fax' will be displayed.
  2. Press [2], [5] on the numeric keypad. ‘25 >Send Report’ will be displayed.
  3. Press [OK]. The transmission report screen will be displayed.
  4. Press the up or down arrow button directly below the Display Screen to select a transmission report setting, then press [OK]. ‘25 Send Report’ will be displayed.
    NOTE: As the up and down arrow buttons are pressed, the menu will scroll through the available choices and move the greater than symbol (>). Stop when the greater symbol is in front of the appropriate selection.
  5. Press the [Stop] button on the Control Panel. The 'Date / Time' screen will be displayed
Dec 11, 2008 | Xerox FaxCentre F110 Plain Paper Laser
Hi, I have a HP Photosmart C6180 and am trying to send a fax. Have tried fax test - everything seems OK. But when trying to send a fax direct from desktop from Word - it just sits in the print queue...
I not sure I get it???
are you printing or faxing???
if faxing from word ibeleive you need to choose fax then a screen comes up to type in info of phone number, name , etc....
if printing click on print choose the model and it should print.
Aug 11, 2008 | HP Office Equipment & Supplies
HP Officejet 9110 All-In-One InkJet Printer Logo
99 people viewed this question
Ben Johnson
