Question about Sony DVDirect VRD-MC3 DVD Recorder
Waiting for input signal
After i connected my camcorder to the dvd recorder and everything is on, the screen on the dvd recorder says waiting for signal input. why is this? can anyone help me? also, there is not number to call if you are having problems. i just bought this product and it does not work. please help!! thank you in advance!
  • 7 more comments
  • Anonymous Jan 25, 2008
    I also get the No Input Signal message. I emailed SONY through their customer service site but have not gotten an answer yet. It has been 4 business days. When you email, they tell you that they will respond within one business day. At another place on their site, it says 5 business days so I don't know whether I should have gotten an answer by now. I don't know what other options I have to get the problem solved. This was supposed to be so simple to operate but it hasn't been for me.
  • libsy Feb 18, 2008
    I also get waiting for input signal when I connect my 8mm camcorder to the sony DVDirst vrd-mc3. help. thought this would easily solve my problem of getting my 8mm tapes on dvd. not so.
  • frie03 Mar 25, 2008
    Yes, the same thing happens when I hook up my Sharp VL A-10. If I keep going on the burner, it does burn the video, but no audio.
  • Anonymous Jul 15, 2008
    I receive the waiting for input signal on all inputs. What will happen is I put in a DVD, hook up the input, see the input on the 2.5" screen, press record, it will record for 3-5 seconds then click off record and then the "waiting for input signal" appears on the screen. Once I press stop then the 2.5" shows the input clearly. Press record and get the "waiting for input signal" again. After the first time attempt from power-on it will not record at all it just shows the phrase.
  • wiljoycem Jul 23, 2008
    For the Sony Multi-Function DVD Recorder VRD-MC5
    With everything setup to record a movie from a DVR,
    including the video TV video display also displaying on the Sony recorder
    screen, I pressed the RECORD button. Instead of lighting, as it always has
    before, it stayed dark; the Sony recorder screen then displayed “Waiting for
    input signal.” Fiddling with controls, powering down and back up, changing the movie
    for recording, were no help. I could not find any discussion of problem in
    Operating Instructions manual (There is not even a troubleshooting area.). Over
    a three-day period, at different times of day, I tried 15-20 times to connect
    to Sony’s so-called “Live Support [on-line]. I was never successful in getting
    through to anyone.
    I returned the product for a refund; then bought another.
    Same problem.
    A few days later I was able to record two movie. Successfully.
    The next time I tried it went back to the “Waiting for input signal.” problem.
    wiljoycem@yahoo.com
  • wiljoycem Jul 30, 2008
    July 30, 2008
    I use the Sony Multi-Function DVD Recorder VRD-MC5 to copy
    movies from a DVR to DVDs. Most of them are from the same channel, say C1. A
    few are from another channel, say C2. I had never recorded a DVD from my DVR
    that had come from channel C3. I set up to record movie M1 from C3. With
    everything setup to record, including the video TV video display also
    displaying on the Sony recorder screen, I pressed the RECORD button. Instead of
    lighting, as it always has before, it stayed dark; the Sony recorder screen
    then displayed “Waiting for input signal.” Fiddling with controls, powering
    down and back up, changing the movie for recording (without powering down after
    trying movie M1), were no help. I could not find any discussion of problem in
    Operating Instructions manual. Over a
    three-day period, at different times of day, I tried 15-20 times to connect to
    through to anyone.
    Same problem with movie M1, and with other movies without powering down after
    trying M1.
    After several days of the VRD-MC5’s sitting idle, I powered
    it up and tried to record a different movie from channel C1. No problem with
    that movie or any other for 10-15 recordings, all from channel C1. Then I tried
    a second movie from channel C3. Back to the dead record button and “Waiting for
    input signal.”. I powered down and back up; and tried to record a movie from
    channel C1. No problem.
    It would appear that channel C3 has some sort of
    copy-blocking device that blocks copying by the VRD-MC5, not only from its
    movies, but all other movies that follow it, until one powers down and back up.
  • dtnggreen Jan 03, 2009
    Same thing happens to me -- and it doesn't have to do with protected video. I was recording from a DVR, which worked fine for one program. I changed to another channel, and received the "waiting for input" message. I then went back to the previous channel that the recorder originally worked on, and it did not work again.
  • cervs Feb 03, 2009
    same problem as all have described. "waiting for input signal" I'm on my second sony dvdirect vrd-mc3. I wished I would have read this before returning mine to the store. I was able to speak to a CS rep from Sony who told me that the reason it was doing that was because the channels are copy right protected and there is nothing we can do about it. I advised her that it works sometimes, for a while then kicks the product off and she told me that it is because the DVR's and even some channels through digital cable sporatically send out the copy right signal.
    Looks like I'm gonna have to try a regular old DVD-R with VHS combo. I hope that works.
  • Anonymous Feb 13, 2009
    I have the same problem..
    I can't record from TV..
It's a protected video. The VRD-MC5 will not burn a VHS or input that has been protected.
Posted on Sep 13, 2008
    New Friend:
    Problem Solver:
I'm experiencing the same problem you are. My company purchased this (before I worked here). The product says it's designed to copy home VHS videos to DVD. I have an old recording that does not have any copy protection because it was a home video-type recording and even though the image is almost perfect, every time you hit record the image cuts out and it says waiting for input signal.
So basically the way SONY marketed this product is incorrect. It would have been better if we had purchased one of the low-tech DVD recorders at WalMart for this, they don't wait for a perfectly clean analog signal before recording to DVD.
The device is useless to us.
Posted on Dec 17, 2014
From Amazon: Sima GoDVD! Model CT-2
Product Description Sima's GoDVD! Model: CT2 makes copying between VHS and DVD formats a snap. This single unit will copy DVD to VHS, VHS to DVD and DVD to DVD. Both NTSC and PAL conversions are included for videos recorded or viewed overseas. The GoDVD! digitizes the video signal to reduce sync noise and features 4 output settings to improve image quality. * Easy connection to any DVD recorder * Stabilizes video signals for crisp copies * Digital technology reduces noise in video sync * S-VHS, VHS-C, VHS, 8mm and DVD compatible * 4 output signal enhancement modes- normal, enhanced, darker and black/white * Supports NTSC and PAL formats * Makes perfect copies of any video automatically. Notice: Use of this product for unauthorized duplication of copyrighted material from DVD, VHS or other media is prohibited under federal copyright laws unless the copy qualifies as a fair use under the Copyright Laws.
Posted on Oct 14, 2009
  • laz13 Jul 13, 2011
    Same problem was happenning to me so left unit on and unplugged Video plug for about 25-30 mins. then plugged video cable back and was able to record agaIn. Hope this helps. Laz
Manual for sharp camcorder model VL-E760U.
I HAVE A PROBLEM WITH THIS CAMCORDER, WHEN I CONNECT TO VIDEO INPUT OF MODERN DVD RECORDER TO RECORD FROM 8 mm T6APE TO DVD DISC THE PICTURE THOSE NOT SHOW PROPERLY IT SHOWS QUARTER OF THE PICTURE . WHEN I CONNECT DIRECT TO TV COLOUR TO PICTURE SHOWS IN ALL SCREEN, CAN YOU SUDJEST SOMETHING FOR THIS PROBLEM?
BEST REGARDS
FRANK PLEVEN.
Feb 12, 2011 | Sharp VL-E760U Camcorder
I'm getting a message "Camcorder not connected. I can't program any recordings
When this recorder reads 'not connected to camcorder' you are simply accessing the recorder's 'DV' input on the front panel of recorder. This 'DV' input is used with DV Camcorders, thus the message.
Simply hit the 'AUX' button on the remote control to access the recorders other inputs. It will cycle between-TUNER>>AV1>>AV2>>DV.
Depending on what you want to access or view and where they are hooked up to the recorder. The "Tuner" will access either your over the air digital channels or your basic cable channels when hooked up through the 'UHF/VHF' input on the rear panel.AV1 is input 1 on the back of the recorder. AV2 is the input on the front of the recorder. DV allows for a Digital Video Camcorder to be hooked up to recorder using a 'Firewire'.
Oct 29, 2009 | JVC DR-MV100B DVD Recorder/VCR
DVDirect recorder. waiting for input signal? It shows the video on the screen but i push the record button and it stops and says waiting for input signal?! help!!!!
HAD the same problem! Called sony and it was fixed for me. I had a/v wires hooked up from my camcorder and from my vhs. I could see the video on the DVDirect screen. I would hit record and screen would go black and say "waiting on input signal". The fix: 1. turn the unit on. 2. Hold the on/off button for 30 SECONDS. (YEP, believe it or not) When I hooked the wires back up and did the same thing I had been doing. IT WORKED!!!! Hope it works for you!
Sep 22, 2009 | Sony DVDirect VRD-MC3 DVD Recorder
How do I work my camcorder
What brand of DVD recorder? On my Panasonic, I use RCA cables to connect my camcorder to the yellow and white inputs on the front of the DVR. I have to press "input select" on the remote a few times until I get to L2, I think. This is a "line in" sort of setting and it directs the DVR to get its input from the RCA-style cables. Have your camcorder playing something you've recorded in its Video mode. If your TV is on the correct input (mine is called "Video 2", I think), you should see the camcorder image on your TV screen. Now, just rewind to the beginning of your camcorder tape. Insert a DVD-R disk (that's what mine takes) in your DVR. Hit Play on your camcorder and quickly press REC on the DVR remote. Let me know if this doesn't work.
Apr 03, 2009 | Canon ES400V Camcorder
Sony hi8 video cam trying to record onto cd's through Sony dvd pl
Yellow connection for camcorder is your video output, the other one is for audio. If your DVD recorder does not have composite video inputs you will have to get an adapter to attach to your yellow wire and the other end of adapter will go to your recorder. OK?
Sep 01, 2017 | Sony CCD-TRV238 Camcorder
Sony rdr-hxd710 dvd/hdd recorder stuck on welcome.
Set your Television to the corresponding input line. If you have the DVD recorder connected to your television input 1 line. Set your television to input 1 line. The recorder is just waiting for your command to set your time and area ...etc.
Nov 12, 2008 | Televison & Video
Copying 8mm tapes to dvd
try taking your audio and video cables from the camcorder and plugging them into the line 1 inputs of the dvd recorder try playing the camcorder and if you can see the video from the camcorder on your tv when it's plugged into the line1 of your burner then hit the record and make sure teh dvd burner is set to accept a signel form the line 1 inputs then it should record. but remembermust selsct the line 1 inputs before you start to record, by defualt they are set to tv/cable.
Dec 27, 2007 | iLO DVDRH04 DVD Recorder
Record dvd
1. Make sure the dv-camcorder is properly connected
2. Press INPUT repeatedly to select the external
input to record from.
• AV1: Audio/Video Input mounted on back
panel.
• AV2: Audio/Video Input mounted on front
panel.
3. Load a recordable disc.
4. Set a recording mode as necessary by pressing
REC MODE repeatedly.
DVD: XP, SP, LP or EP.
5. Press the REC button once to start recording.
The REC indicator lights in the display window.
6. Press STOP (x) to stop recording.
Nov 14, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Dvdirect signal missing
In my case...DVDirect may have been detecting some sort of copyguard (copy protection) ....not sure.
Sep 04, 2007 | Sony DVDirect VRD-MC3 DVD Recorder
Open Questions:
See all Sony DVDirect VRD-MC3 DVD Recorder Questions
Sony DVDirect  VRD-MC3 DVD Recorder Logo
4,768 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
