Question about D-Link DES 1008D (DES-1008D) 8x10/100 Mbps Networking Switch
I have some problem with my D-link Des-1008D switch.I used it to connect 2 computer in my home and one cable form Internet shop.At that time, that Internet shop used manual IP to connect PC.And then That shop close and I get new from other shop.But there problem, I can't connect with the cable that acquire from new shop with my switch.So I can Only use one pc to connect to internet. And there That shop use auto detest proxy.My friend told me that I need driver for switch to clean that Ip store in switch.Please Help me how to do......please sent your answer to jj6487@gmail.com. Thank Alot
    Brigadier General:
  • 10,406 Answers
Does your ISP supply _one_ or _two_ IP-addresses per account?
On each computer:
Click Start
Click Run
Type CMD and press ENTER
Type IPCONFIG and press ENTER
What "IP-address" and "gateway" do you get for each computer?
No, a "driver" for the switch is not necessary, and will not help.
Instead, buy a "router" (with or without wireless capability), and rewire your network:
Cable-modem -> Ethernet-cable -> WAN-port on router
LAN-port-#1 on router -> Ethernet-cable -> Computer #1
LAN-port-#2 on router -> Ethernet-cable -> Computer #2
Turn the cable-modem off.
Turn the cable-modem on.
Turn the router on, to get one IP-address from your ISP.
Restart each computer, to get new IP-addresses for each computer.
Within the web-browser on each computer, disable "auto detect proxy".
Posted on Nov 16, 2009
How to setup my des 1008d in my computer
The DES 1008D is an unmanaged switch. therefore there is nothing to set up. Just plug it in and connect to your computer via a cat 5 cable. Here are the manuals
Link DES 1008D
May 06, 2014 | D-Link DES-1008D 8-Port Ethernet Switch...
I brought a des 1008d swtich i want internet sharing with swtich .i connect all pc with this switch
You have to connect all the computers you have to the switch and connect your DSL or cable modem also to the switch and enable DHCP in it. Configure all your computers to obtain IP address automatically. This should work and you should be able to share the internet across the network
Dec 21, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
Why i cannot connect broadband connection through switch more than one computer at same time? But only one computer can connect.
Internet through your broadband connection is normally setup for single user.
If you need to use multiple systems to be connected to internet then you need NAT (Network Address Translation) to be enabled.
But unfortunately the D-Link DES-1008D doesnt support that.
Dec 02, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
How can I install or connect my d link to the internet line and my computer
I assume you have a broadband connection which you are directly to your computer.
In that case please connect the broadband ethernet cable to one of your switch port.
Get a new CAT5 or CAT6 ethernet straight cable and connect one end to any free port of the DES-1008D 8-Port Ethernet Switch and other end to your Computer.
No configuration needed to be done on DES-1008D 8-Port Ethernet Switch
Best Regards
Nov 20, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
How to connecte d-link switch model-DES-1008D two same switch pls urgent
Sometimes we need to connect 2 switches, which can be done by using Ethernet Cable (CAT5 or 6). Just connect the cable to the LAN ports from one switch to another. Let me know the purpose of doing so that i may guide you better.
Hope this helps!
CreativeTECH
Nov 16, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
When i get connected to d-link des 1008d switch port the computer will get automatically configured 255.255.0.0 to subnet mask therefore i have class c ip address and i dont have internet connection...
u no need to worry about the subnet mask 255.255.0.0
just do the following connections
  1. connect a utp cable from modem/router to dlink switch.
  2. connect a utp cable from switch to ur pc
Assign ur pc manually with following configuration
ip: 192.168.100.5
subnet: 255.255.255.0
gateway: 192.168.100.1
and your router with ip: 192.168.100.1 And enable pppoe in ur router.
Thats it you are connected to internet. No need to enable ics etc.
Jul 05, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
I need to ask about my problem. I just bought a D-Link DES-1008D and a D-Link DIR-300 Wireless-G Router my problem is after I attach 7 computers on my switch hub. I only have limited local network...
Make sure you're using a crossover ethernet cable to connect the router to the switch. Also make sure that the router has it's DHCP server up and running.
Nov 03, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
Two pc connection by dlink switch
connect the router to the switch using any port-it does not matter which port you use. Connect each computer to any port on the switch-it matters not. The router will assign IP address to the computer as they are added.
DONE!!!
Good Luck
Sep 28, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
DES-1008D connectivity issues.
Is the modem a DSL or cable model?
Does the router have one ethernet port and a WAN port?
Normally the broadband modem is connected to the WAN port on the router and the ethernet port on the router is then connected to the hub/switch and the computers are then connected to the hub/switch.
The modem gets an unique IP address from your Internet Service Provider and then the router then issues Class "C" IP addresses to each computer that is connected to the switch/hub.
Jul 31, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
D-Link DES 1008D (DES-1008D) 8x10/100 Mbps Networking Switch Logo
313 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
