Question about Philips GoGear SA178 MP3 Player
No funciona mi mp3 Philips GoGear SA178
Bueno yo tengo uno se esos mp3 philips gogear sa178 y cuando lo conecto al acomputadora reconoce el mp3 pero cuando lo saco para escuchar musica dice "philips"por un largo rato y no dice "go gear" despues como debe ser
y no lo puedo apagar.tengo que meterle una aguja en reset ,lo vuelvo a poner ydice"philips " y no se apaga .porfavor necesito ayuda urgente .gracias
  • 1 more comment
  • Anonymous Mar 19, 2014
    LO ENCIENDO PERO SE QUEDA CONGELADO EN GOGEAR Y NI SIQUIERA LO RECONOCE EL PC
    mp3 gogear 4gb se apago y priende como aser para poder restableserlo otra bes
  • Anonymous Mar 23, 2014
    quiero que se le kite esa mansanita enn forma de calaverita para que regre pork solo me sale eso
  • 8,596 Answers
Go to: (Va a:)
www.usasupport.philips.com - click on Espanol
Enter your model number (Entra su numero de modelo)
On the next page, click on your exact model number without the "B" on the end
On the next page, click on "User's Manuals" - look for "Repair"
En Ingles:
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Posted on Feb 11, 2008
Tengo un mp3 gogear sa 1945/55 y no prende ,cuanod lo onecto al ordenador la pantalla se pixela y no lo reconoce use el philip desvice manager y ahora no prende , no lo reconoce , y cunaod lo conecto usb...
yo tenia el mismo mp3. es un problema de los phillips. no ay mucha solucion para esto. trate de apretarle el reset button si esto no funciona trate de llamar a la compania. alomejor el device se le cayo y por eso no funciona
May 03, 2011 | Philips GOGEAR SA6045 MP3 Player
Como puedo arreglar el audio de mi compuntadora
mi pc es ACER ASPIRE T160, no puedo escuchar el sonido, el problema es desde el comienzo no da sonido ni al prender
Sep 05, 2009 | ZT Group CISNET A7022 PC Desktop
NO HE PODIDO METER VIDEOS AMP4 GoGear SA32XX QUE NESECITO PARA METERLOS VIDEOS Y SE REPRODUSCAN
tienes que convertilos en swv formato y necsitas el convertidor que vino con el mp3 player es facil.
Jun 16, 2009 | Philips GoGear SA3245/37 Digital Media...
Tengo una DN hd2500 y se bloquea
bueno, la cosa esta asi, basado en lo que a mi me ha sucedido, yo uso la dn2500 y  le doy mucho uso, a mi me *** ese mensaje varias veces, db save ng! , cant acces, eso es cuando tu disco duro esta fallando o ya murio o no lo puede encontrar, pero cada ves que me paso eso fue llegando al lugar de trabajo, me volvi loco , desconecte el teclado y la volvi a prender y se solucionaba hasta que un dia no arranco mas, entonces saque el disco duro interno y lo quise poner en una caja para copiar la musica a otro disco duro, hecho esto volvi a poner el hd en su lugar y funciono, yo creo que es un tema de los conectores, pero tambien podes ir a utilidades y probar hacer una base de datos nueva. lo importante es sacar la musica que tenes ahi, despues te compras otro disco duro($40) y lo cambias por el que esta ahi adentro o lo usas por usb externo, recuerda que el usb externo tiene que estar formateado en fat 32. aca esta mi email por si necesitas algo matosfilms@gmail.com
May 04, 2009 | Denon DN-HD2500 MP3 Player
Gigabyte GA-K8N Pro-SLI won't boot and no beep codes
hi kathy,
there are a few things you can try, reseting the cmos, with the jumper usually located near the battery. if you cant find that, try removing the battery for 30 mins and then popping it back in. if no luck from there, you could try another cpu, if that dont work then it may just be the mobo! good luck!
hope it helps!
Feb 11, 2009 | Gigabyte GA-K8N Pro-SLI Motherboard
Mp3 no lo lee mi compu
Firmware upgrade needed - RCA website - select "Spanish" for language
May 12, 2008 | RCA TH1101 MP3 Player
Por favor nesecito su ayuda por favor PHILIPS GoGear SA6045
Yo tube el mismo problema y lo repare, ingresa a la pagina oficial de phillips y es acutalizar el DEVICE MANAGER ( http://www.support.philips.com/support/downloads.jsp?userLanguage=es&userCountry=ar ), luego ingresa en la pagina de INFORMACION DE CONTACTO Y ASISTENCIA, ingresa el modelo de tu equipo que en este caso seria SA6045/85 y luego en la siguiente opcion "como se reinicia el reproductor si se bloquea o se detiene", sigue bien las indicaciones y te resultara. yo lo hice de esta manera, abri el Divice manager actualizado, presione el signo + del reproductor y sin soltar lo conecte al pc y presione en el programa reparar. En este paso el reproductor no se enciende pero dejalo presionado como 5 minutos y el programa te indicara que esta listo. Luego desconectalo y trata de prenderlo, quesas no se prenda por falta de bateria a si que conectarlo al pc y veras. Ojala les resulte. (http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=CL&slg=ESP&cat=MP3_PLAYERS_CA&sct=SU00304_SU&grp=PORTABLE_ENTERTAINMENT_GR&ctn=SA6045/85&mid=Link_FAQs&session=20090825220818_200.111.181.38&hlt=Link_FAQs# )
Saludos
marcelo (barracuda)
chile
Apr 24, 2008 | Philips GOGEAR SA6045 MP3 Player
No se ve el video en mi TV
yo tambien quisiera los codigos me harian un mega favor, les dejo mi correo manuelgutierreznevarez@hotmail.com de ante mano gracias
Nov 24, 2006 | Yahoo YHT-650 System
Philips GoGear SA178 MP3 Player Logo
721 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
