Question about Sony Ericsson w580i Cellular Phone
My phone Sony Ericsson w580i display is not coming. Remainder ,Music are working.
Decreased phone memory without any downloads phone hangs (sony ericsson w580i)
if you text alot delete all your text drafts saved sent and inbox delete un-needed pics and videos apps notes music
May 30, 2009 | Sony Ericsson w580i Cellular Phone
Tip
How to Put a DVD movie On Your Sony Ericsson w580i on Mac OS X
I just purchased the Sony Ericsson w580i; I want to convert a few DVDs so I can watch them on my phone. The problem is that I don't know the first thing about doing it. What format will I need to convert the DVD?
-- from U.K Pinky
The Sony Ericsson w580i is one of Sony Ericsson's lines of Walkman-branded handsets. These music focused phones are popular globally, but few of them have made it to the United States. The W580i is one of the few that has, carried by AT&T. And it's a good pick for the carrier.
The sound quality through the included stereo earbud headphones is superb and if you turn on the MegaBass boost feature in the Walkman player, the phone outputs full and powerful sound that booms. The W580i also has support for A2DP which allows the phone to play music via Bluetooth to stereo headphones. Like other Walkman phones, the W580i supports music files in the MP3/AAC/AAC+/e-AAC+) formats and you can rip music CDs using the included Disc2Phone software for Windows or using Sony Ericsson DVD Ripper for Mac.
Want to watch DVD Movie on Sony Ericsson w580i The Sony Ericsson W580i has a 2 QVGA display that's capable of displaying 262K colors. Pictures, videos and music visualizations look good and the screen is amazingly usable outdoors even in direct sunlight. Have you ever tried to upload DVD to Sony Ericsson w580i? The following tips will be your Sony Ericsson w580i's assistant to help you get more fun to watch DVD movies on your Sony Ericsson w580i for Mac user.
Before converting DVD to Sony Ericsson w580i, you should get to know about what kinds of formats are supported by our Sony Ericsson w580i phone. Here I list all the supported video /audio formats playable on Sony Ericsson w580i Smartphone.
Video/audio formats supported by Sony Ericsson w580i: * Video clips in MP4 (generally MP4 is preferable with better picture quality), 3GP
* Music/audio files in MP3, MP4, AAC, WMA, WAV, AMR act.
Below is the detailed tutorial about how to Convert DVD to Sony Ericsson w580i on Mac. Step1. Download and install DVD Ripping software Mac running it and then load the DVD movie from your Mac Step2. Select Output Setting Select "MPEG-4 Movie (*.mp4)" from the output format list in "Format" drop-down list. Step3. Convert DVD to Sony Ericsson w580i on Mac When the settings are done, click the "Start" button to start conversion. And then the program will automatically start to convert DVD to Sony Ericsson w580i. That's all. When the conversion is finished, you can click “Open” to locate the file in your hard drive.
Finally, just put the converted DVD to Sony Ericsson w580i, and now you can enjoy DVD movies on your Sony Ericsson w580i phones anytime and anyplace. You can also convert some part of the DVD to Sony Ericsson w580i or convert DVD to the other portable player compatible formats.
on Jun 02, 2010 | Cell Phones
My Sony Ericsson W580 just shows a white sceen an i cant go to anything else
More than likely you will need to replace the display screen but before you do take the screen out and reseat the LCD connector. This will sometimes fix a white screen.
If not, a new LCD screen runs about 15 dollars shipped from eBay and is pretty easy to replace.
Check out the following link for instructions on replacing the LCD display and links to buy the screen.
Sony Ericsson W580i LCD Display Replacement
I hope that helps you out
Mar 22, 2009 | Sony Ericsson w580i Cellular Phone
W580i no sound
you have to take it to you carrier an let them know your problem bepending on how long you had the phone they might replace it
Jan 08, 2009 | Sony Ericsson w580i Cellular Phone
SONY ERICSSON W580I DISPLAY PROBLEM.....
More than likely you will need to reseat the lcd connector.
Worst case is you need to replace the lcd screen.
A new LCD screen runs about 15 dollars shipped from ebay2.gif.
The W580i LCD is easy, easy to replace. Probably one of the easiest I have ever done.
Jan 07, 2009 | Sony Ericsson w580i Cellular Phone
Display problem, unable to see the contacts
i have w580i ,some times display is off,but sound is coming & some time display is ok,sound is not coming,after switch off & on,then only  phone is working properly
Dec 30, 2008 | Sony Ericsson w580i Cellular Phone
Phone problem?
Hi there!
Sony w580i has only 12MB of built-in memory so you definitely need a memory stick to save music files on your phone.
Cheers!
Dec 29, 2008 | Sony Ericsson w580i Cellular Phone
Sony ericsson w580i blank screen
More than likely you will need to replace the LCD screen. The backlight may have burned out making it blank or it the LCD connector may have come loose.
The W580i LCD is very easy to replace.
Sony Ericsson W580i LCD Screen Replacement
Dec 09, 2008 | Sony Ericsson w580i Cellular Phone
Sony w580i Screen Issue
Your lcd cable is probably loose or damaged. I would take it aprt and reseat the cable first.
If you still have the issue, it is probably a bad cable. A new LCD screen and cable run about 15 dollars shipped from ebay2.gif..
Check out the following link for instructions on reseating the LCD display and links to buy the screen if that is needed
Sony W580i LCD Replacement
Nov 24, 2008 | Sony Ericsson w580i Cellular Phone
Sony Ericsson W580i
The red light is display comes whenever there cell phone battery is weak... try changing the battery!!!
Good Luck
FixYa
Aug 28, 2008 | Sony Ericsson w580i Cellular Phone
Sony Ericsson w580i Cellular Phone Logo
200 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
