Kenmore Elite Washer Does Not Spin
Kenmore Elite washer (110.20992991) drains without spinning until cycle knob is pushed/pulled. Replaced clutch, but problem still exists.
Washer does not begin spinning prior to rinse/drain cycle. However, pushing/pulling (stopping/starting) the cycle knob without turning the knob creates 'knock' sound and allows the spin to begin. Seems that pushing/pulling the cycle knob releases the brake so the spin can occur. Is the brake released electronically or mechanically?
    President:
  • 1,937 Answers
This a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20992991
and you'll see a list of major sub-components with diagrams and parts.
The brake on these washers is driven by the clutch on top of the transmission.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
This is a Whirlpool PDF on how these washers operate. It has a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
If the washer drains the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again or stopping and starting the cycle knob, and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Apparently, by opening and closing the lid, or stopping and starting the washer torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Nov 16, 2009
  • 68 Answers
The brake is released mechanically. The knock you're hearing is the brake releasing.
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Loses power in spin cycle
First lid must be down before washer start spinning. Remove any obstructions in drain hose and or straighten drain hose to remove kinks. Lid or other object hit timer knob and turned the washer off - Make sure the Timer knob is pulled out.
If the lid was opened with too much force when adding clothes, it may have hit the timer knob, pushing the knob in.
If a laundry basket or other object hit the Timer knob, the Timer knob may have been pushed in shutting the washer off.
Washer lid is not locked (Not on All Washers) - The lid must be closed and locked for the washer to operate. Once the lid is closed, make sure the desired cycle is still selected and then press the Start button and listen for the lid to lock.
Make sure there are no loose metal objects such as coins and paper clips in the lid opening area. Metal objects can prevent magnetic switches from reacting correctly when the lid is closed.
If the washer has not drained, it will not go into spin.
Use a flashlight to inspect the holes in tub for foreign objects like screws, nails, bra wires, etc. and remove if present.
Apr 03, 2010 | Kenmore HE2 Plus Front Load Washer
Noise during spin after changing clutch / kenmore elite washer
The clutch is likely failed again - or the coupling this time.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 27, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Series 80 Washer Won't Spin
Your timer has failed to initiate a pause for the transmission to lock in.
Replace your timer. Solve your problem.
Feb 21, 2009 | Kenmore 22422 Top Load Washer
Kenmore Elite spin cycle squeals
The clutch/transmission has failed.
Jan 14, 2009 | Kenmore 24032\24036 Top Load Washer
90 series washer spin
Replace the timer.
Jan 10, 2009 | Kenmore 24032\24036 Top Load Washer
I have a kenmore elite washing machine and the spin cycle will not work.it both fills up and drains water but it wont spin.
I have a kenmore elite washer. whwn on spin cycle it does not spin and als o will no agitate. There is a loud noise wen on spin cycle. Please help
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
Washer does not spin and drain water. (Kenmore Elite Heavy Duty)
it seems to me ur washer transmission is going out or already there
Nov 26, 2008 | Kenmore 24032\24036 Top Load Washer
Washer not spinning - not timer
I have a Kenmore 80 series mode #2289400. It will wash but will not drain and spin. I have turned the knob to a different spin cycle put it won't spin. I have drained the water out of the tub thru the drain pipe so it's not plugged. When it's ready to spin and it making no noice. Any help would be great.
Sep 20, 2008 | Kenmore 24032\24036 Top Load Washer
Washer will not Spin during SPIN CYCLES
check the lid switch on the washer its below where the tab on the washer lid that goes down in the body of the washer there two screws at the base of the control panel back these out and raise the panel you will see a connector coming from the washer disconnect it and put a jumper wire where it goes to the control panel turn it to spin pull out the knob if it spins replace the switch if it doesn't reply to me and we will go from there
Jan 30, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
389 people viewed this question
Top Washing Machines Experts
