My Humax PVR9200T has recently become very slow responding to remote commands. The proccessor seems to be unable to keep up with the commands. This is a general fault with the unit as 2 other family members also bought the units (on my recommend) which have also developed the same fault.
  • Anonymous Mar 27, 2014
    Family member sat on the control fault on screen movement v101. It there some type of lock.
Yes. I have exactly the same with my PVR9200T. Humax are now putting out software updatess for their other boxes and have promised a fix for the 9200 soon. I contacted them a month ago, and at the time the update was due in 2 weeks but haven't seen anything yet. My guess, and it is a guess, is that the programme guide format has changed during the recent switchover and is screwing up their internal firmware hence the slow response etc..
Posted on Apr 20, 2010
Mine has done the same over the last few weeks - no solution I know of - would assume it's a firmware problem - either a new version downloaded or something to do with the date in the firmware?
Posted on Nov 22, 2009
Why is my Humax 4000 very slow, freezing and scrambled saying bad signal.
Check the signal level and quality. Reseat all aerial connections.
Jun 18, 2016 | Humax Televison & Video
After switching off and on last night the volume and mute on stopped responding on Humax remote. IT is PVR9150T and remote RT531B. TV Remote works fine with volume. Humax remote works fine on all exce
Note that this type of device is designed to be left on at all times, so should not be switched off each night. I suspect that it has some slight corruption in the user-settings, so a factory reset may be required.
Apr 03, 2014 | Humax Televison & Video
Receiver doesn't respond to any commands from the remote. Batteries in remote are fresh.
Over time the remote can become dirty from spills or potato chip debris.... This can cause the carbon pads to be on and the remote is giving a continuous command, effectively stopping it from working. Take it apart and clean carefully with rubbing alcohol and swab sparingly....
Nov 28, 2010 | Kenwood VR-406 Receiver
My Humax Duovisio PVR-9200T often freezes completely and has to be switched off at mains for a few seconds. Or commands from remote (eg subtitles, menu, channel change) take minutes to respond. Or...
Remove the Aerial.
Switch on or if it's frozen switch off at the mains and on again.
Press Menu
Installation and enter password - 0000
Select 'Default Setting' and OK
Select 'YES' and OK to restore all settings to factory default.
Confirm again to start loading, enter the password again and it will start scanning for channels but won't find any.
Replace the aerial and press OK to rescan and now it will find channels. On completion press SAVE then EXIT on your keypad.
You won't lose any saved programmes but you will have to re-schedule your recordings.
May 03, 2010 | Humax DRT400 DVD Recorder w/ 40 hr Tivo
Its slow to command,when your typing your commands onthe phone, it slow to respond to the command.it does not keep battery charge for long
go to performance and maintenece center . - > choose options to enhance Battery Life - > (disable Areo Effects , Etc) This should enhance Battery Life
Mar 21, 2010 | Microsoft Windows Vista Ultimate Edition
Connection to Bose V30 System
check hdmi setting from ur tv and ur dvd connection
Nov 08, 2009 | Bose Lifestyle V30 Home Theater System -...
PVR9200T very slow to react to remote control
I have 5 customers machines doing the same. rang Humax today. They are working on the fix..and hope to have an OTA update at the end of the month....keep you fingers crossed eh?
Oct 11, 2009 | Humax Televison & Video
How to download recordings from humax pvr9200t to pc
Hello liardet,
you could of course use the manufacturers supplied utility !
However, a lot of independent work has been done to produce a whole range of highly effective tools described on http://humaxdisk.wikispaces.com/
See also http://www.hummy.org.uk/forums/showthread.php?t=2009
JamesT
Oct 25, 2008 | Televison & Video
Humax 9200t PVR freezing every ten minutes after turning on and off again.
Try a rescan with the aeral out and then reconnect the aerial and rescan again.This should cure the problem.
May 31, 2008 | Televison & Video
Televison & Video Logo
573 people viewed this question
Top Televison & Video Experts
Electro Med Services...
