Question about Sony Playstation 3 (PS3) Console
Changed hdmi lead on ps3 and have sound but no picture
I changed my hdmi lead and now i haven sound but no picture on my ps3
3 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: ps3- hdmi to av
unless there is a switch on the ps3 itself to change to normal tv, you may have to reconnect the ps3 via HDMI and change the screen resolution back to 480p or change the settings in the setup from hdmi to av.
Posted on Aug 24, 2007
  • 51 Answers
SOURCE: CD SOUND QUALITY ON PS3
r video and audio set to HDMI
or try playing with the audio settings the ps3 might not be set to play the audio format
Posted on Nov 21, 2007
I am unable to get a picture on hdmi when i connect my ps3, but am able to get sound when i use ps3 controller. any ideas ?
Steps
  1. Step 1 Check for an HDMI port Check the back of your television for an HDMI port and refer to your owner's manual for your television's resolution. A resolution of 1080p offers the highest quality.
  2. Most PS3 systems support 1.3 HDMI, but older systems may need a software update from the 1.1 or 1.2 version.
  3. Step 2 Disconnect cables Disconnect all the cables and adapters from the back of your PS3, and then unplug your TV to reduce the risk of shock as you work.
  4. Step 3 Connect HDMI cable Connect the HDMI cable. Reconnect the power cables on both the TV and the PS3 system.
  5. Step 4 Hold power button Hold down the power button until the PS3 beeps and continue holding it for an additional five seconds until the system makes a second beep.
  6. The Playstation 3 should detect the high definition cable and automatically adjust the settings to give you the best picture and sound possible.
  7. Step 5 Test the connection Test the connection. If the HDMI cable isn't working, turn everything off and reconnect the original cables to manually change the settings.
  8. Step 6 Adjust the settings Turn the system back on, select Settings, Display Settings, Video Output Settings, and then HDMI. Repeat the process for your Audio Settings. You can now experience your games with the highest video and audio quality available.
Dec 01, 2014 | Sony KDF-E50A12U 50" LCD HDTV
After cutting off ps3 an then to switch back to tv there is no sound coming out .
it can happen if you have the ps3 on HDMI lead. some times the ps3 can still be sending a signal and the HDMI side of the tv is still open on sound. up date the ps3 firmware. should sort it out. if it has been updated change the HDMI lead. should sort it out.
Sep 21, 2013 | Televison & Video
Only sound comes when i connect HDMI cable to my TV for the ps3
you need to select High definition output on the PS3. Connect it via hdmi and via standard lead switch the tv to standard so you can see the picture then select high definition output. Switch over to hdmi and you should see a picture
Mar 01, 2011 | Video Game Consoles & Games
I have an Onkyo TX-SR605 , I have my ps3 connected via hdmi and from the amp to a 3d tv via hdmi . when i am connecting through the amp the PS3 does not recognise i have a 3d TV and will not play 3d Movies...
No but you may be able to help me. I have the same amp and ps3. I have HDMI leads from both but cannot get sound or picture. I do get the set up menu which means it recognises the HDMI lead. How is yours set up ?
Jan 25, 2011 | Onkyo TX-SR605 Receiver
Ps3 gets sound but no picture when using hdmi cord
you need an optical lead for the sound and hdmi for the picture
Dec 29, 2008 | Philips 23PF4321 23 in. HD-Ready LCD...
JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
Dec 17, 2008 | JVC LT-32X575 32 in. HD-Ready LCD...
No sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Oct 19, 2008 | Televison & Video
PS3 hook up to sony reciever
its in the sound settings on your ps3, change to hdmi out put, this should sort it, if not you can use your scart lead for the sound, just use red and white lead straight into your sound system or sony reciever. but you will need to set it up in the sound settings in your ps3. hope this helps
Feb 11, 2008 | Sony Playstation 3 (PS3) Console
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
All picture and no sound
Silly question, but have you gone into the setup for the AUDIO and chosen the correct signal connection i.e. Audio via HDMI, AV or something else?
Oct 21, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
126 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
