Question about Alesis M1-Active-MK2 Powered Studio Monitors -Pair System
Alessis 620 monitors, only the base end coming out of the speakers does anyone know why?
  • k_visions Nov 16, 2009
    Kool where is it located please i'm not good with electronics
  • 11,361 Answers
Check for the fuse in the high frequency amplifier.
Posted on Nov 16, 2009
  • Bud Martin
    Bud Martin Nov 16, 2009
    There should be a big metal plate on the back that the amplifer and power supply are mounted on, you should be able to see some fuses there. Pictures? budmrtn@aol.com.
I installed the following graphics card in to my Dell Optiplex 620 desk top after connecting the computer back together i was given the following error "READON X600 SE P/N 620 113-a26044-108 BIOS". I was...
Enter the bios by pressing F2 during the first seconds of the boot. Then look for "restore to factory settings".
If that doesn't work the look for the graphic/monitor settings and try to change settings.
Good luck and let me know how it goes
Oct 18, 2013 | Dell Computers & Internet
I cant connect regular headphones to the casio AP620 piano, it seems to have a bigger connection on the piano. Does anyone knows what it is?
A headphone jack converter is available from internet or local electronics store from as little as 99p plug your 2.5mm jack in one end and the other into the piano which will be the 3.5mm or bigger.
Hope this helps.
Sep 22, 2012 | Casio Celviano AP-620 88-Key Digital Piano...
Alesis M1 active 620 woofer problem
There clearly is a fault in the sub's amp section. It's probably the main part that does most of the work. It will need to be replaced.
Mar 07, 2017 | Alesis M1-Active MkII Main / Stereo...
Alesis M1 Active 620 studio monitor cutting out
I see from the manual there are several controls on the speaker that could affect the sound in the way you describe (gain, hi- and mid-boost, acoustic space). Why don't you compare the actions of each control with the working speaker as the standard and a test tone or FM noise as the source? It might help you to identify a specific internal function that has changed. After that, someone's going to have to crack it open and do surgery.
You might also try using the opposite input (TRS vs XLR) than the one you're using. It might reveal something.
Mar 13, 2010 | Alesis M1-Active-MK2 Powered Studio...
Speaker connection for LG W2053TX monitor
This model of monitor does not come with speakers. In fact very monitors have speakers. You will need separate speakers for sound. Some monitors do come with external speakers which hook onto the monitor at the sides but they are still connected to the PC via a lead with a 2.5mm stereo plug into the sound output..
Dec 12, 2009 | Computers & Internet
How do you make the sound work ? Hannspree Monitor HF237
When you have a monitor that has built-in speakers, you must hook that monitor to your computer with a cable--the type of sound cable any other speakers have. It has a male jack on each end. One end goes into the little sound in hole in the back of the monitor. The other goes into the green hole on your sound card (either the built-in card or an add-on card).
Another thing to check is to see that the sound drivers are working. You know they are if the computer had sound that played through other speakers. If you hook it all up and there is no sound, then you most likely have a sound driver problem (or your sound is muted!)
If this explanation helps, be sure to rate the answer, please.
Mar 30, 2009 | Computers & Internet
I need a replacement glass carafe for the alessi 9094/8 coffee press. Wher can I find one and how much should it cost? Thank you.
You can get a new carafe for the alessi 9094/8 and other 8 cup alessi coffee presses from Speranza Design Gallery www.speranzaonline.com . Search for 8003299015146 or go to this link: https://www.speranzaonline.com/store/prodView.asp?idproduct=2074 The cost is $24 plus shipping. It is genuine Alessi and it fits perfectly! I was very happy with my transaction with them -- easy web transaction, good communication, quick shipment, excellent packing of the fragile item. Comes in original Alessi box. It is listed as Alessi French Coffee Press Replacement Glass 8 cup .
Mar 02, 2009 | Alessi 9094/8 Coffee Maker
ALESIS M1 ACTIVE MK2 CONE VIBRATION!
Hello!
my speaker Alessis M1 Active 620, with a roar is very strong in the speaker, the potentiometer does not attenuate, change the volume. Ja switched capacitor C8, based on my research of other users, but got no result. When you press the power button, the LED lights in blue, and even change the color to red, producing a noise (snoring) very strong.
help!
Please help me!
Mar 17, 2008 | Alesis M1-Active-MK2 Powered Studio...
Need help with logitech x-620
This is a common complaint with systems like this, unfortunately it is to do with its design rather than a specific fault. If you are using your speakers with a PC you can go into your soundcard settings (normally an icon in the dock) and adjust the Equaliser. Bring down the bass end and add a boost around 1-2kHz where vocals normally live.
If you don't have an EQ available you can try altering the positions of your satelite speakers. The ideal listening position is all your horizontal plane speakers to be at the same height as your ears and you sub tucked away on the floor. I think logitech usually have a separate bass control on the back of the sub in systems like this so turn this all the way down also.
Jan 28, 2008 | Logitech X-620 System
Is it safe or unsafe to try to repair on your own?
You have 6 screws 4 hold the base on and 2 on the backside of speakers. From their you can open it.
If you still have the monitor that is.
Oct 24, 2007 | HP vs15 15"LCD Flat Panel Monitor
Open Questions:
111 people viewed this question
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
shaqsatin
Level 1 Expert
Ben Armstrong
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
