I do have a coin washing machine which the cold
I do have a coin washing machine which the select cycle selector stopped working at the cold water position and now it works with hot water only...What could be the problem.
    Top Expert:
  • Washing Mach... Master
  • 76,848 Answers
The most common cause of this problem is that the electric solenoid activated cold water inlet valve is defective, the valve is located at the back of the machine where the cold wtaer hose hooks up, it is very easy to replace and cheap to buy.
Posted on Nov 16, 2009
Maytag Coin Washer can't select Cycle after putting in coins
check the coin mech
If it is turning on properly
check the selector itself.possibly the switch
Mar 18, 2015 | Maytag MAH21PDD Commercial Front-Load...
My Whirpool Duet front loader will begin a wash cycle, but stops when cycle switches to rinse with water in the drum. Door remains locked & light by the 'wash' flashes 9 times...
when the machine is stopped can you empty the residue water that remains by the programme selector? if not check for blockage in the pump(coin), the hose internal blockage ,or at the outlet under sink. I hope this help
Jan 15, 2015 | Whirlpool duet Washing Machines
My Zanussi WJD 1257 washer/dryer's drying cycle has started finishing early. No error codes. The wash cycle works fine but the drying cycle is simply stopping prematurely. You can set it to dry for 45...
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Zanussi Washing Machines
On my Maytag Washing Machine...Sometimes my water selector works... sometimes it doesnt. Sometime hot will come out when set on cold and sometimes cold will come out when set on hot.. Sometimes it works...
Hi and welcome to FixYa, I am Kelly. Just reading this it sounds like the water temp selector switch is acting up. You did not provide a model number so this is just an outright guess to help you. Try this if you have the button type start mashing the buttons several times between temps. Do it with conviction. Your cycling the switch to unstick or clean off the contacts in the switch. If the cycle temp switch fails while doing this; changing the switch was the next recomendation to correct the temp problem. You should cycle the switch at least 30 times methodically. Press, change temp, press repeatedly. Then check your cycle water temps for hot and cold as selected. Depending upon model you could have a problem with the water inlet valve. I will wait for a response before commenting on that.
If you need specific model information I need your Model number.
Thanks for choosing FixYa,
Kelly
Nov 14, 2010 | Washing Machines
Baumatic BK6EL washing machine will not fill with water, it only lets a cup full in, shuts the water off and starts washing. Any ideas? Thanks, Mandy
One of the most common problems encountered with washing machines that need repairs, including Baumatic machines, is no water coming into the machine or the soap not being taken from the soap dispenser box. There are two main reasons why this could happen, 1. because the water has been turned off inadvertently from somewhere, or 2. because the water inlet valve as become faulty or blocked.
If your appliance is not taking in water the first thing you need to know is if the problem is with the hot or cold supply, to find out you can put your appliance onto a white wash cycle and start the machine this should bring hot water into the machine and you will know within a few minutes if the hot water supply is working or not, and to find out if the cold supply is working or not select stop/reset and then select the drain or spin cycle and this will empty the machine of any water, now select the rinse cycle and this should bring cold water into the machine and you will know within a few minutes if the cold water supply is working or not, once you are sure of the results select stop/reset and then select drain or spin again to empty any water that may have entered the appliance.
At this stage you should know whether the hot or cold supply is at fault, the next thing you need to check is that the water as not been turned off inadvertently, check both the stop **** and the washing machine connector valve/s, to see if you can tell if it as been turned off or not, if you think it as, turn it back on and do the hot and cold cycle test above for the cycle that failed, if the water is still not coming into the appliance you know need to turn the water off from the washing machine inlet valve/s one at a time and slowly disconnect the the inlet pipe/s from the washing machine side and point the washing machine inlet pipe it into a bucket and then turn the water back on, you should be checking to see that the water is on and also that the water pressure is OK.
There is a good chance your appliance could be working OK now, but If the test above shows the water is on and the pressure is OK but the washing machine is still not taking in water, you will need to have t the water inlet valve and or the water pressure switch and water pressure chamber tested, the diagnosis procedure covered here will work for Baumatic washing machines that need repairs, it will also work for most other makes.hope this helps
Aug 11, 2010 | Washing Machines
The washing machine won't start if "cold water" only is selected. It will only work when "warm water" or "hot water" is selected (and even then there is only hot water filling the machine, the cold water...
Check the cold water solenoid. If a meter is not available you can swap the hot and cold wires and see if the symptom changes to hot water when cold is selected. If so the mixing valve needs replaced. If no then further testing of the wire harness and timer circuit are needed.
Eric
Apr 13, 2010 | Kenmore 13202 Top Load Washer
Electrolux washer stopped in mid cycle with clothes in will not empty water out. What do I check. Brian
Most likely something caught in the pump. Coins and balls of lint are real common.
Sep 17, 2009 | Washing Machines
Why did my LSE7806ACE WASHER STOP FILLING
Hi…
If I get you correct, the hot water is not coming into the machine or it is not working at all.
Let me know
Thanks
Smith
Aug 13, 2009 | Maytag LSE7806A Top Load Stacked...
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
