Question about Nokia N73 Cellular Phone
Need to send n73 data to e71, both nokia.pls assist
Remove the unlock code nokia n73
hi are you in need to unlock your nokia n73 from network then visit mobileunlocksolutions.com here they ask you the network name to which your mobile is locked then the imei number of your mobile .finally they send you codes to unlock your mobile .then visit mobileunlockguide.com here they provide you free instruction guide about how to use codes in your mobile.
Jun 19, 2012 | Nokia E71 Smartphone
I WANT POWER MOVIE REGISTRATION KEY MY NOKIA N73 IMEI NO 355718029271242
i want power movie reg key my nokia c5 imei no 353792840727864
Feb 01, 2011 | Nokia Cell Phones
My N73 takes at least 5 minutes to send one text message. When I press send, the "Sending Text message" with progress bar appears and stays there for at least 5 minutes. Any solution?
i forget the my N73 lock code.how i find the lock  code.pls i need help.this is my imei no 353548022973912.this is my moblie model v 4.0736.3.2.104-09-2007RM-133@nokia n73(12) pls help me pls help mesent the master code act.actor@gmail.com ormobile no 9698866851
Oct 19, 2010 | Nokia N73 Cellular Phone
""china mobile"" E71
pls enter 1122 to reset the code in china mobile or 0000
Jul 10, 2009 | Nokia N73 Cellular Phone
Ive got the same problem
hi
the problem here as i see it is that the you are storing your messaes and your photos n songs on the phone, i mean your gallery primary is your phone and you are not able to load data to it anymore
make the default location for storing your photos on the memory cards
as well set ur msg settings to store msgs on the memory card
there by try freeing up as much space on the phone as possible
this not only lets you send data to your phone it also improves the performance of teh phone and gets more responsive
cheers
pls rate if it was any help, thanks
Jun 30, 2009 | Nokia E71 Smartphone
Memory low delete some data
pls send solution this problem
thanks...............
Jun 27, 2009 | Nokia N73 Cellular Phone
Delete Data
It's a software fault, doesn't matter how much 'stiff; you delete.
go to: http://www.nokia.co.uk/A4222213#
and you can upgrade your phone software
(you will need to download the updater and back up your data first)
Hope this helps! (If it does pls rate me) :-)
Sep 28, 2008 | Nokia N73 Cellular Phone
Hoe to unlock n73 code
sir use this master code is 7541315267... then go to the sttings and change the security code... hope it will be helpful.. dont forget to rate me.. thank u
May 05, 2008 | Nokia N73 Cellular Phone
Reset master code for Nokia N73
unlock ur phone by by any nokia competable box & then reset it by typing code *#7370#
Jan 09, 2008 | Nokia N73 Cellular Phone
Nokia N73 Cellular Phone Logo
16 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
