Question about Ryobi Garden
Ryobi 40cc chainsaw chain oiler function not working
  • 486 Answers
1) check oil supply holes in the bar
2) With the bar removed, run the engine for 30 seconds, does oil come out of the side of the saw.
3) If no oil on the side of the saw, inspect the clutch drive spring and worm gear on oil pump shaft
Outboard drums (drums on the outside of the clutch) are held on by a nut or e-clip.
Inboard drums are held on by the clutch which is threaded onto the crankshaft. And there is the challange.
***NOTE all chain saw clutches have LEFT hand threads, so, rightey loosey, lefty tightey. (just backwards from everything else)
*** NOTE #2: DO NOT USE AN IMPACT GUN
this will most certainly shear the flywheel key or damage the flywheel !!!!! (after 35 years, you can ask me how I know that, LOL)
1) Use a piston stop to hold piston from moving: THIS IS A MUST !!!
Ok, so you do not have one, let's make one.
a) remove the spark plug
b) insert a piece of recoil rope into the cylinder hole, leaving a tail to remove it by. (rope, large shoe string, anything that is soft, that is aprox 1/4 to 5/16 in diameter to place into the spark plug hole to help the piston to stop it's travel by filling up the empty space. Just make sure you can remove it later)
c) secure the saw (extra set of hands may be needed) and with a suitable wrench on the clutch center, rotate the clutch to the right until piston comes to a stop. With a hammer, tap the wrench to aid in rotation. This can be very difficult, and may take several taps.
d) after removed, inspect and grease the drum bearing before re-assemlby.
e) upon re-assembly of clutch, tighten by hand only, NO hammer required. The force of the chain will tighten the clutch.
f) remove the rope, and re-install the spark plug.
Posted on Nov 16, 2009
    President:
  • 2,220 Answers
Rwvanlue - I think your inboard and outboard clutch descriptions are reversed. Inboard clutch (drum) uses e-clip; outboard clutch (drum) threaded to shaft and they rarely have any nuts. The centrifugal clutch portion of both types is threaded to the crankshaft.
Your description except for being reverse is clear and concise. good job. Lou
What happens when the recoil rope falls through the exhaust port?
Oiler mechanism to bar of ryobi 40cc 10532 18 inch
I get asked this question a lot , im gonna have to make a video on this subject someday .
but here:
1st ck your oil viscosity/SAE it should be 30 and say bar/chain oil
next dump out entire oil tank and wash out with kerosene (you'd be surprised what I seen come out)
then remove bar and chain , locate oil outlet it's in body of saw near adjustment screw , use a small can of air to blow in this port softly , use a touch more of kero to clean this all out , refill tank with proper oil !!!! and run saw (no need to put bar/chain back on yet ) might take several minutes but oil should start to flow out hole !! stop saw and reinstall bar/chain then run again .. fixed !! if no oil comes out ever your oil pump is gonna need some fixing
for a low cost oil I use filtered used motor oil cut down with a dab of kerosene
Jul 07, 2014 | Ryobi Factory Reconditioned 18" 40cc...
How much slack should be in the chain
If you tug on the chain in the middle of the guide, the guide teeth should come out of the guide bar groove with a gap of about 1 - 2 mm (about 1/16 inch). This is from the Ryobi Users Instruction Sheet, please rate this response.
May 21, 2011 | Ryobi Factory Reconditioned 18" 40cc...
Chain oiler not working
replace the oiler assembly
nylon gear frequently strips gears
replacements only cost around $10.00
Sep 10, 2010 | Poulan P4018WT Wild Thing 18Inch 40cc...
Hi there,i m looking for 16"chain ryobi 40cc chain saw
Take your saw or old chain to a shop that works on small motors and they can make one . Take it to lowes and try one of theirs. They have them to fit any brand saw. Sears, Home Depot or a small hardware store.
Apr 20, 2010 | Ryobi Factory Reconditioned 18" 40cc...
Have The split cylinders in the Ryobi RY10532 40cc chainsaws caused grinding problems?
check chain sprocket take a rag over chain and pull it around should be smooth rolling also check nose of bar there are rollers check them out lota sawdust can build up behind clutch/sprocket
Apr 08, 2010 | Ryobi Factory Reconditioned 18" 40cc...
Oiler not working
Had you provided the model number we could have provided a more complete answer. What little oil system routing detial there is resides on the IPL. It can be found here:
Homelite/Ryobi.com
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use don't match the numbers everyone posts. A careful inspection of your saw should find something that matches.
Oil System Plugged.
Remove the clutch cover, bar and chain. Clean the oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at connections. If equipped with an oil pump it is usually behind the clutch (probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Sep 30, 2009 | Ryobi Factory Reconditioned 18" 40cc...
I am having a problem with the oiler,getting oil to the bar&chain.
pump is probably gunked up! pour a dab of oil on it between cuts if you really have a task you need to finish up! then crack the case to the saw open and take a looksee
May 26, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Ryobi 40 cc bar oiler not working
hi customweldi
check the oil filter,the oil line ,the oiler and the worm gear.Clean the bar and the oil hose.
the best savumihai71
Nov 30, 2008 | Ryobi Factory Reconditioned 18" 40cc...
Garden Logo
435 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
