Question about Dynex 4-Port Ethernet Broadband Router (DX-E402)
In your answer about the verizon dsl and the dynex dx-e402 router you state you have a guide to set the modem and router up how do i get those?
  • 591 Answers
When i connect my modem directly to my computer i get internet access. when i connect to my dynex router, i get no access on my computer or xbox
You can go here and download the quick setup guide and manual for your router http://www.dynexproducts.com/products/computers/DX-E402.html which will walk you through the setup.
The most common reason it won't connect is that you must have the router's IP number (the one listed as default IP in the manual) set as the GATEWAY address on your computer network settings and your xbox settings, otherwise they can not talk to the router.
Feb 18, 2011 | Dynex DX-E402 Router
I'm trying to get a dynex DX-E402 to join my airport express
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Jul 01, 2010 | Dynex DX-E402 Router
Verizon modem to dynex router to hook up sprint airave.. and nothing is working I did all the set up but cant type in ip address with no internet.. HELP!
Have you tried typing in 192.168.0.1? Or 192,168.1.1?
If so, what happens when you do? One of those addresses should take you to the configuration screen for your router, at which point you should be able to configure your router and go from there.
-a.
Jun 02, 2010 | Dynex 4-Port Ethernet Broadband Router...
Do not have cd to set up model no.dx-e402
You can set it up with the manual:
http://www.dynexproducts.com/t-product_documentation.aspx
Mar 27, 2010 | Dynex 4-Port Ethernet Broadband Router...
I didnt get an installation disk what can i do
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Jan 06, 2010 | Dynex 4-Port Ethernet Broadband Router...
How do i set upa dynex dx-e402 i have a verizon dsl and an xp based computer
There are a few things you can do to help reliability
You should first make sure that the modem and router are individually
set up correctly.
I do have a guide for that.
Once that is done you should consider giving out proper IP addresses
Big business does this for security and reliability and it is no different for home users except maybe easier
Read the guide for router and modem first and if any of it may apply to you then try and do it.
The second part deals with IP addresses and this may well help you
I have a selection of computers laptops servers at home on a small network
It is quite some time since I last had to do any sort of system wide shutdown
Try the following procedure and write down anything you change so that if you need to go back you know what was changed.
Connect ONLY the MODEM to a pc and nothing else
Go to the start menu and select RUN
In the box type "cmd"
Now in the black screen that has come up type "ipconfig /all"
Take note of the numbers that are in 4 groups e.g. 192.168.1.1
Also take note of the name in front of those numbers !
Take note of the DEFAULT GATEWAY
Now do the same thing with your ROUTER
If that too has the same IP as your modem in "default gateway" then you need to fix that issue as that is probably a part of your problems.
The fix for router modem conflict is to set the router to use a different IP range.
Nov 16, 2009 | Dynex 4-Port Ethernet Broadband Router...
Dynex-e402 change nat settings to access x-box live
Dynex DX-E402 router, changing NAT settings(UPnP) to access x-box live. go to router settings web page for router, http://192.168.1.1/, enter user name and password to access settings page. user id is usually admin this also for password. under advanced settings click on forwarding. In listed sub-catagories click on UPnp. click enable. this should solve any NAT issues with X-box 360 signing onto x-box live. dynex dx-e402 was very easy to setup.
Mar 24, 2009 | Dynex DX-E401 Router
My Dynex 4 port router will not communicate with my DSL modem
Have your router clone the MAC Address of your computer. The MAC address is a hardware address on your network card and DSL providers seem to like to bind it to account. What is probably happening is when the router connects to your ISP and asks for an IP address, it looks up your account info and and decides - nope, wrong device. Cloning the MAC address will make them happy. If you are not able to clone the address, call your provider's tech support and ask them to clear the MAC address from your account. Make sure you have the router plugged into the modem and not the computer or you are back to where you started.
Jan 05, 2009 | Dynex 4-Port Ethernet Broadband Router...
Dynex 4-Port Ethernet Broadband Router (DX-E402) Logo
125 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
