Question about Garmin 12CX GPS Receiver
Garmin streetpilot c340
Unit will not charge up
  • 83 Answers
It sounds as if the battery may be defective. I would contact Garmin and they can assist you in getting a new battery installed.
Posted on Aug 15, 2009
SOURCE: My Garmin Streetpilot c340 is locked up.
The reset button on my Garmin c340 is behind the plastic trim around the front. You will see a small indent for a fingernail or something like that along the inside at the top lift up at that point and it should come off no problem
Posted on Jun 13, 2007
SOURCE: Garmin GPS touchscreen is damaged - what can I do?
Overlay is dented.
Posted on Sep 13, 2008
SOURCE: update 2009 maps into c340 how to
The Garmin Streetpilot C340 is discontinued, so there isn't much support for it. You can find some updates at
https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00401-20&cID=164&pID=290
But no free map updates.
Posted on May 13, 2009
SOURCE: My Garmin StreetPilot c340 is frozen.
No.......the C340 STREET PILOT has a hidden reset button. Put your fingernail in the slot just under the GARMIN name on the front face plate. Gently pull the face plate outward. Don't take it all the way off. The reset button is on the right side of the front screen just under this plate. Use a pointed object and hold the button IN for 3 seconds and unit will turn off. When you power it back up it will REBOOT.
Posted on Jun 10, 2009
  • 5 Answers
SOURCE: My Garmin c340 has won't turn on, screen is
Some garmin gps units some times have a reset buttom on the bottom under the serial number if not. The internal battery is bad. These units have e rechargable lithium battery once that goes bad, your unit wont turn on even if its fully charge. If you still have warranty on the product i recommend you replace it
Posted on Aug 10, 2009
Garmin Street pilot C340 has always worked. This morning it did not turn on. I relpaced the fuse in cord. Any other ideas?
Try charging it from the WALL charger. The battery inside the unit may not be too great. Try it - over night from the WALL charge -not the PC charger. 8de415c.jpg
May 04, 2010 | Garmin StreetPilot c340 GPS Receiver
Why does my c340 keep losing satellite reception
Hello there:
please follow these instruction and this should help if not let me know and i willcontinue to get you more information for you
nstructions
  1. Step 1 Calibrate the screen of the Garmin StreetPilot C340. If the touch screen does not seem to respond when you hit it with your finger or a stylus, you may need to calibrate it. To do this, turn the unit off and then hold down the "Power" key for approximately one minute. You will see a calibration screen come up that will recalibrate the GPS2_bing.gif unit.
  2. Step 2 Reset the Garmin StreetPilot C340. If your GPS unit is not responding or is stuck on a particular screen, it may need to be reset in order to operate. To reset, remove the face plate of the unit by gently prying it off. Locate the "Reset" button under the face plate and press down in order to restart the device.
  3. Step 3 Change the fuse of the Garmin StreetPilot C340. If the fuse blows on the GPS, you will need to make a replacement using an ACG/3AG 2 amp fuse. Unscrew the adapter cord at the end and remove the fuse found there. Put in the new fuse to see if this returns function to the unit.
  4. Step 4 Update the software for your Garmin StreetPilot C340. If the GPS is not providing you with correct directional information, you may need to update the software or download new maps onto the device. Connect the Garmin StreetPilot C340 with the USB cord to your PC and log on the Garmin website for available updates.
Jan 15, 2010 | Garmin StreetPilot c340 GPS Receiver
My Garmin c340 has won't turn on, screen is completly dark unit is charged
I has the same problem with a streetpilot 540.. It wouldn't turn on, even once charged. There was no reset button under the serial number. However, prise off the grey plastic square plate on the front panel which goes around the screen. ( there's even a little space for your fingernail under the Garmin logo). The reset button is under that plate. Press that with a screwdriver then turn on. My unit turned on once reset.
Aug 10, 2009 | Garmin StreetPilot c340 GPS Receiver
GPS StreetPilot c340 quit working
Plug charger in, and then reset it. Let it charge for awhile before tryng to use it though. It sounds like the battery is very very low. When it is plugged in it still will not operate unless the battery has some charge in it. I hope this helps.
Apr 18, 2009 | Garmin StreetPilot c340 GPS Receiver
StreetPilot c340 will not power on - even with soft reset
well after being on hold with garmin for 32 minutes they told me to send them the unit back and will repair at no cost.
My unit was purchased on may 27th 2007.
Jul 26, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin Streetpilot c340 arrived dead
The battery symbol would show the charge, somethign doesn't pop up.
May 08, 2008 | Garmin StreetPilot c340 GPS Receiver
Dead Garmin StreetPilot c340
The battery usually has a small charge when arriving from the factory, but it can die before it is received. You should charge this by plugging it into the car or the computer.
Charging unit with AC adapter
I have a 100v A/C power / charger unit for my garmin C340 GPS that I use to charge my Garmin's battery every day. I can use thj adapter to run the GPS, or just turn it off and let it charge the GPS. But it connects dirctly to the Garmin GPS unit, not to the cradle like the Cigarrette lighter unit does. .
Mar 18, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin 12CX GPS Receiver Logo
21 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
