Question about Whirlpool Duet GHW9150P Front Load Washer
Motor problems on whirlpool duet
The drive motor is locked up . The unit is only about 2years old. My question is ? previous to the motor going out, there was a metallic scraping noise that could be heard when the tub was on the spin cycle. It didn't happen every wash load, but would happen just every now and then. Could something else have caused the premature motor failure?(such as an unballanced tub or other component). Are these motors proned to fail early?
thanks in advance
mike model :WFW9200SQ00
s/n CSU1309182
  • mwerner460 Nov 16, 2009
    I may need to clarify a few things.
    First, I removed the belt and tried to turn motor pulley by hand. It took a pair of pliers with some umph to get motor to turn. scraping noises came from motor as I turned the shaft. I was able to get the large drum pully to turn with little effort, therefore I think the motor is the culprit.
    second, I would like to order and replace the motor myself, but I don't want to put in a new motor if there is possibly some other problem that will only cause the 2nd motor to fail prematurely. What do you think?
    Thanks again
    Mike
    Genius:
  • Whirlpool Master
  • 1,466 Answers
Any motor can go anytime, grinding sounds like some thing stuck in drum putting stress on the motor it may well be its just the belt thats gone here you need to check further/ Make sure drum runs on own with no noise pull mains plug 1st disconnect m otor belt/ dru m should be smooth if not something could be stuck here ie Sock.....
Posted on Nov 16, 2009
  • Gerry Harvey
    Gerry Harvey Nov 17, 2009
    Ok ..Sounds like the motor bearing has packed in resulting in the Jam,now did anything else cause the motor to go? perhaps the drum pulley too tight due to something in it?Also you need to be sure the faulty motor has not burned out the Electronic Speed module/this drives the motor!..I think if the drum is tight I would give the whole thing a miss as by the time you fix drum/ replace motor and possibly replace module, repair would outweigh replacement machine..Try taking it up with Whirlpool head office, you may end up paying for labour only, or free repair as goodwill gesture...
My whirlpool duet washer stops towards the end of the cycle and flashes 6 then F. The door stays locked and the washer beeps. It has happened before, the machine is about 6 years old, how can I fix
F/06
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Feb 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Problem with whirlpool w/m adp4737
Whirlpool Duet & Duet HT & Kenmore w/110 model prefix Frontload Washer Error Codes-OLDER
  • F/H--No water detected entering machine or Pressure switch trip not detected
  • F/02--Long Drain
  • F/05--Water Temperature Sensor Error
  • F/06--Drive Motor Tachometer Error
  • F/07--Motor Control Unit Error
  • F/09--Overflow Condition
  • F/10--Motor Control Unit (MCU) Heat Sink Thermal Trip
  • F/11--Serial Communication Error
  • F/13--Dispenser Circuit Error
  • F/14--EEPROM Error
  • F/15--Motor Control Unit (MCU) Error
  • Sud--SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
  • F/dL--Door Lock Error
  • F/dU--Door Unlock Error
Jan 01, 2012 | Washing Machines
My whirlpool duet spin cycle problem
Check the MCU
Feb 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does the code F11 mean?!
This information is taken directly from the Whirlpool trouble shooting guide we found on our Duet Sport. I quote: "The motor control unit has internal failure; repeating under or over voltage, or over current conditions." Possible Causes/Procedures 1. Unplug washer or disconnect power. 2. Check wire harness connections between the drive motor and the motor control unit. And between the motor control unit and the central control unit. Check the motor and do a continuity test. 3. Plug in washer or reconnect power. 4. Check the motor control unit by by looking for operations of the drive motor. 5. Check the drive motor for powered rotations. 6. Replace the motor control unit.
As previously stated, this is quoted directly from the guide. Hope that helps.
Feb 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Flashing f11
Hi
F11 is a Serial Communication Error i.e. communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly. You need to
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
  • Please do rate the solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 26, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
    Whirlpool ht duet washer throwing codes. f11,f dl, f0
    Serial Communication ErrorSerial Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)Check the Drive system for any worn or failed componenCheck Wire HarnessCheck MCUCheck CCU Check MotorCheck Wire Harness good luck
    shaun
    Mar 26, 2009 | Whirlpool GHW9400 Duet Washer
    Whirlpool washer
    F/11
    Check Wire Harness connectors to the MCU, the motor, and-
    Check MCU
    Check CCU
    Check Motor
    Check Wire Harness
    F/dL
    Door Lock Error
    A Door Lock Error occurs if the door cannot be unlocked.
    It will try to lock it 6 times before displaying the error.
    Door Lock Mechanism broken or removed from the Door
    Check Door Lock/Switch Assembly
    Check the wire harness connections to the Door Lock/Switch-
    Assembly and Central Control Unit (CCU)
    Door Lock/Switch Assembly Failure
    Feb 23, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
    Whirlpool frontload duet washer F 6 problem
    hello cjkcp
    Welcome to Fixya
    You said, your washer (now 4 yrs old) occasionally stops mid cycle flashing F 6 code. Is this something we can fix or do I have to call a repair man?
    F/06 Drive Motor Tachometer Error
    • Check the MCU
    I believe this needs a hands on tech to daignose this. Unless you feel you undrstand the problem your self?
    Thank you for using our service for advice.
    Please remember to leave a rating!
    Huuum
    Oct 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool duet washer
    YA, I HAVE A PROBLEM SAME AS THE OTHERS. AND JUST LIKE THE MANUAL SAYS, YOU ARE SAYING TO CHECK EVERYTHING, BUT YOU WILL NOT TELL US HOW TO CHECK IT, WHAT IT IS SUPPOSE TO SOUND AND LOOK LIKE, WHAT IS NORMAL. SO WE CAN TELL WHAT IS WRONG WITH IT. I DON'T HAVE ALL THIS MONEY TO SPEND ON REPAIR MEN WHO DON'T KNOW WHAT THEY ARE DOING. SO WHAT SHOULD I DO. OH AND P.S. F-28 DOES SHOW UP ON THE WASHER SO IT REALLY IS A ERROR CODE.
    Feb 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    211 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
