Question about Samsung Rugby SGH-a837 Cell Phone
Muffled reception to and from the phone. The
I get muffled reception to and from the phone. The battery has to be charged every night and I have only had it for 1 month. Since it is just out of the 30 day period I get a used replacement.
The battery doesn;t last long. i charged it twice yesterday, and the battery was low by night time, and i hardly used it. been trying to charge it for the past 1 hour, but there;s no difference. and it...
Try to check if there's an application running in your phone, like games etc. Because in these case your battery will easily worn out. What you must do, restart your phone. Or check the unit from where the battery is connected, many cases like these, we found out that there's a short circuit connected to your battery. My advice is, since you can't fix it, just ask assistant to the phone technician. I'm sure this way can help you out to solve your problem. Thanks
Jan 08, 2011 | Nokia 6210 Navigator Cell Phone
Samsung u900 limited service
Is the battery fully charged now???
Limited service, is when your not getting any reception, Samsungs usually always get low reception or no reception at all if the battery is low or dying... Remove the sim card, reinsert it into the handset, charge the phone and try again...
If it still doesnt work and the sim card does work in other handsets, its still covered under the Samsung warranty if its less than 12 months old.
May 14, 2009 | Samsung U900 Soul Cellular Phone
HTC TOUCH HD charging problem
Well hope so you didn't damaged the sensors! try this : use the phone until battery is empty and switches off. then put it on the charger for 4 hours. If no joy,try different battery to make sure that device is not damaged and get a new battery.
May 12, 2009 | HTC Touch HD Smartphone
Battery life
I have the same problem. Replacing the battery solves it, but for about 6 months, then the new battery holds less and less charge.
Apr 20, 2009 | Uniden TRU8866 Cordless Phone
Can't charge my enV2
The issue is the charger port on the ENV2 breaks fairly easily.Thefirst step is to contact your carrier to see if it is coveredunderwarranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3.You can get an external battery charger to charger the batteryseparatefrom phone. cost about 25 dollars. Check out the following linkforones that are available on ebay. A extra battery is a good idea aswell so you can have one charging at all times.
LG VX9100 ENV2 External Battery Chargers
Hope that helps
Mar 07, 2009 | Verizon Communications enV2 Cellular Phone
Vtech cordless model cs5121
Make sure the battery is charged. If the battery is low either because it is old and doesn't hold a charge or needs to be charged, the audio will sound like your talking from the bottom of a swimming pool.
Jul 04, 2008 | Vtech 9009111 Cordless Phone
My phone wont turn on!!!
Your battery might be dead. How long have u had the phone?? i had mine for 1 year and like 2 months b4 i had to buy a new one because it wouldnt hold a charge
Apr 07, 2008 | T-Mobile Dash Smartphone
Charging receptical has broken off inside the phone
you both will need to take the phones in to a mobile service center and have them replaced the charging ports.
Feb 25, 2008 | LG CHOCOLATE VX8500 Cellular Phone
My battery swell
Hi, Battery is calculated in Cycles and One Cycle is One charging & discharging. In ur case probly u might have used ur 300 Cycles. Most of the people do a mistake of keeping charging for whole of Night but when u talk about the cell phone if u keep in charging for the whole night unnessary Cycles are getting wasted. Mobile charge has a funda like it charges and over a time automatically it discharges as well. so don't keep it in Over night charging. U need to replace the battery. Else u will not get a perfect back up. Madhu AVN
Jan 28, 2008 | Sony Ericsson K310i Cellular Phone
Samsung Rugby SGH-a837 Cell Phone Logo
110 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
