Question about Elkay ADA Wall Hung Water Cooler 4 Gallons Per Hour
I have an elkay wall hung fountain with electric switches.Model-EZFS8. I have replaced the solenoid valve because once it was used the water would not stop flowing. That fixed that issue but now it makes a chattering noise and cuts in and out when being used. sometimes it doesn't even come on. It pulses while making a chattering noise very quickly everytime any of the buttons are depressed. It is an older fountain maybe ten years old or so. Thank you very much for your time, Vince. 267-278-7501
3 Suggested Answers
  • 127 Answers
SOURCE: water pressure is low on the elkay fountain
if you mean the amount of water that comes out of the bubbler head....you can adjust that by accessing the push button cartridge and turning it to adjust how far it is pushed.
Posted on Oct 18, 2009
  • 126 Answers
SOURCE: i have a elkay double level water fountain and the
is there power to the unit.could be selinoid problem
Posted on Sep 25, 2011
My Elkay water fountain is clogged up, water does not drain properly, how do I unclog
To unclog the elkay water fountain just look out for push button catridge and and turning it to adjust how far it is pushed or you can even try with chemical drain cleaners like draino or liquid plumber or CLR(Calcium,Lime and Rust Remover) & if still the problem hire plumbing repair services.
All Plumbing Repairs
Apr 29, 2015 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
Water from Elkay wall mount water cooler is coming out cloudy. I know it has air in system and i let water run for over 5 mins but water remains cloudy. Looing for solution
  • Check the water shut off valve is not open all of the way if not open shut off valve all of the way.
  • Check to see if the regulator / control valve is restricted with debris or not working properly. If so clean debris or replace the control valve.
  • Check the water inlet screen is for debris, clean or replace screen
  • If there is an external water filter, check to make sure it is not clogged.Check the income water line, if flexible, to make sure it is not kinked, is it is rework it to remove the kink.
    Dec 06, 2012 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
    Elkay drinking fountain M#erpb28c continuously runs, having problems getting mounting nut back onto bubbler, seems basin should come off for access, however needind a reapir manual or access instructions...
    The Elkay fountains are turned on by a solenoid powered valve. There is a rubber grommet in that valve assembly that gets holes in it and then water gets behind it, causing the valve to stick on. To test that it is a solenoid problem, turn the water on and then unplug the power to the fountain--if the water continues to run you have a solenoid problem. You'll need to replace the solenoid and I've detailed how to do it with all the steps and lots of pictures on my blog: http://johnfixesstuff.blogspot.com/2014/10/how-to-fix-elkay-model-ezfs81b-replace-solenoid-35981c.html John Fixes Stuff How To Fix an Elkay Model EZFS8 1B Drinking Fountain...
    Feb 22, 2011 | Vacuums
    I have power and water to the fountain, but fail to get the water to pump to the fountain head
    The water pressure get the water to the spout it is not pumped there. You have a valve in the off position some where. http://www.elkayusa.com/cps/rde/xbcr/elkay/12-23D_EZ_EZS_EZSD_EZD.pdf this link shows an electric solenoid valve and also a manual valve.
    Feb 18, 2011 | Elkay EZS8-L Single-Level Wall Mount Water...
    HOW DO YOU GET THE EKLAY WATER FOUNTAIN APART TO REPLACE SOLENOID SWITCH
    I have written up the entire process with all the steps and lots of pictures on my blog at: http://johnfixesstuff.blogspot.com/2014/10/how-to-fix-elkay-model-ezfs81b-replace-solenoid-35981c.html
    Sep 16, 2010 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
    How can adjust the volume of water coming from the drinking spout on my Elkay water fountain?
    On our Elkay drinking fountain there is a set screw underneath that you can turn to adjust the flow rate. I have detailed how to adjust the flow along with how to replace the solenoid on my blog at: http://johnfixesstuff.blogspot.com/2014/10/how-to-fix-elkay-model-ezfs81b-replace-solenoid-35981c.html John Fixes Stuff How To Fix an Elkay Model EZFS8 1B Drinking Fountain...
    Mar 19, 2010 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
    Water pressure is low on the elkay fountain
    Oct 18, 2009 | Elkay EZS8-L Single-Level Wall Mount Water...
    Elkay ADA Wall Hung Water Cooler 4 Gallons Per Hour Logo
    159 people viewed this question
    Top Elkay Plumbing Experts
    jdthefixer
    rdjagger
    Are you an Elkay Plumbing Expert? Answer questions, earn points and help others
