Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Dryer not drying cloths even though it does the full cycle? hotpoint wd63
  • Hotpoint Master
  • 3,463 Answers
There are several reasons for this to happen.
  1. Heater element faulty.
  2. Thermostat faulty.
  3. Heater relay faulty.
  4. Blocked condenser.
  5. No cold water going in on drying cycle.
You really need a meter to test the components with, to get the bottom of the problem.
Please rate my solution.
Thanks.
Posted on Nov 16, 2009
Testimonial: "gave me a good idea of where to start looking"
    President:
  • 1,149 Answers
Hi:
Another thing to try, if your dryer vent hose checks out ok, is to wash your lint catching screen with some dish soap and water. If you use dryer sheets, they can actually cause the lint screen to be waterproof, and hamper your drying. You can tell if it needs scrubbed if you pour a little water on it,and it beads up, instead of running thru...try this, it is a cheap fix that helps your clothes dry!
  • 71 Answers
In my experience with a Kenmore electric dryer, excess lint caused poor airflow & clothes don't dry.
If you are using corrugated plastic or metal duct, replace it with smooth metal duct which doesn't collect lint as readily. If this is the type you already have, clean it by pulling a towel through it.
If this solves the problem, great. If not, unplug the dryer, open the back & vacuum inside & inside the vent outlet. If you can take the this apart it makes cleaning inside much easier.
This worked for me, and seems like a reasonable first step before paying someone to clean your dryer.
Hotpoint Aquarius WD440 Washer/Dryer. After a cycle clothes still smell as if there is stagnant water underlying somewhere yet machine has been looked at - nothing wrong. Still working in excellent order...
You can buy a liquid product (I got ours in Lidl) that flushes out and cleans the machine. If one application doesn't work try it again. It's just like cleaning out the dishwasher. Worked for us and it was really smelling!
Aug 24, 2011 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD63 not spinning correctly
Two things to check.
Remove rear cover.
Remove large black hose onto drum
Remove and clean filter inside hose.
Next--remove top cover and check the brushes in the motor, if they are less than 3 or 4 mm long, then replace them.
Thanks.
Nov 24, 2009 | Hotpoint Aquarius WD63 Front Load...
We have the hotpoint washer/dryer wdl540 but cannot get the dryer to work, all the clothes come out steamed! we'r not overloading the machine and have tried different combinations but still it wont dry -...
The first problem is that you, like myself, bought this piece of trash. The best way to resolve this problem is not sell it on ebay and never even think about buying Hotpoint again.
Oct 29, 2009 | Hotpoint Aquarius WD63 Front Load...
Drum makes loud noise as rotates clockwise
put few clothes in it drum to switch on its ball in there
Oct 06, 2009 | Hotpoint Aquarius WD63 Front Load...
Door Locked. Cannot open. Washine inside.
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Mar 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Dryer problrm
The sympoms are typical of a couple of reasons.
  1. Blocked condenser.
  2. faulty cold inlet valve, not letting water in to condense steam back to water.
When it is on the drying cycle, see if you can see water pumping out of the drain at. a slow rate.
If you can see no water at all coming from outlet hose, then chances are it is a faulty valve, and you will have replace same.
Plz rate my solution.
Thanks.
Jan 06, 2009 | Hotpoint Aquarius WD63 Front Load...
Dryer
FIRST - UNPLUG IT!
First check the one shot thermostat - thete are 2 stats on the top of the heater box - it's the one with the staggered connector terminals - then let me know
Mar 21, 2008 | Hotpoint Aquarius WD63 Front Load...
Dryer keeps stopping
Plugged filter or exhaust hose to outside could be clogged...Have someone turn the unit on and go out to see how much air is coming out of the vent. Should be a bunch. I'm guessing you have a blockage somewhere causing the unit to shut down and not catch on fire.
Jan 09, 2008 | Hotpoint Aquarius WD63 Front Load...
Not draining after cycle
try checking the filture on the front at the bottom of the machine they some times get full of muck
Jan 08, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
259 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
