Question about RCA F32650 32" TV
Tv about 10 years old tried to turn it on and it clicks like its coming on and then it clicks itself off. In a few seconds it tries to turn it self back on several times. Does this sound like an expensive problem
    Genius:
  • 1,044 Answers
The pwer switch has worn out
Posted on Nov 16, 2009
MY 35IN COME ON PICTURE AND EVERYTHING WAIT 10 SECONDS AND GOES OFF 35IN TUBE ABOUT 15 YEARS OLD
There is likely something wrong with the tube itself. It could be a short that is only there when the line warms up (10 seconds is plenty considering the amount of power that runs through it) or the CRT has a crack.
If you want to continue with this type of TV there are quite a few reliable TV repair companies in almost every mid to large town around the US. If you don't want to invest in repairing a 15 year old TV (not a bad life span for electronics by the way) then you could very likely find a 32"-37" LCD TV at your local electronic store that is reasonably priced.
May 23, 2011 | RCA Televison & Video
Set is 7 years old - it turns off intermintently
Ours used to do that - and then we moved it to another state with us. Since the move it doesn't shut itself off anymore. I suspect that the problem was dirt and dust inside which got knocked loose in the move and the shutdown was due to thermal limits being exceeded. You may want to try vacuuming or blowing out the dust inside if you feel comfortable opening up the unit.
Feb 15, 2010 | RCA D52W135D 52 in. TV/DVD Combo
TV will not turn on
you either have leaky capacitors near the voltage regulators, cooling fluid leaking on the boards, and/or bad solder connections on the yoke plugs. this model is known for all 3 problems, but you probably need a qualified tv repairman to fix this right.
Sep 17, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Turns off on its own after a few second clicks on and off for about 5 sec. until it turns itself off but the power light is still on
This is point to a fly back issue and a flyback fr this would run you $95 plus labor good luck with your TV
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 23, 2009 | Philips Magnavox MS3652S 36" TV
TV wont turn on.
Hi
This case needs to diagnose by a qualified technician
Thanks
Nov 28, 2008 | Mitsubishi Televison & Video
Mitsubishi ws-55819
Code 22 indicates that your set is in shut down due to what is called Short Protect. The most likely cause is the Converge Ic's drawing too much current and opening one or 2 fuses. Normal repair cost varies by area and servicer. Expect 250 to 350 plus the service call. I normally do this on site.
Nov 16, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Pioneer PDP 436XDE
hi there, you have to send if for repair, tech people knows the prob., there a defective part to replaced. do some test and check up at the horizontal and power supply section. ty
Feb 18, 2008 | Pioneer PureVision PDP-4300 43 in. Plasma...
Tv wont turn on
You probably have a bad flyback transformer (high voltage). You might want to get an estimate to find out if it is worth repairing. Stargazer
Jan 20, 2007 | Sanyo DS31590 31" TV
RCA F32650 32" TV Logo
176 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
