Question about Sony Xplod Car Audio Amplifier XM-DS1300P5 - 800 Watts Mono Amplifier Car Audio Amplifier
Why would my amp be making a squeking sound while its on?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sony Master
  • 2,226 Answers
You may have a bad ground on the rca's. try running a wire from ground to the shielding if the rca's and see if it goes away. if it does, either take the amp apart and repair the ground trace, or run a wire from ground to the rca shield permantly.
Posted on Nov 16, 2009
Just bought a 2013 kia optima (33,000 miles) and its making a squeking sounds which sounds like the rear suspension or shocks. Any suggestions?
Hi, you can find forums with people having the same problem, try here:
https://www.reddit.com/r/MechanicAdvice/comments/2izmxr/09_kia_optima_makes_an_occasional_chirpy/
or here http://www.optimaforums.com/forum/5-optima-general-discussion/1165-strange-squeaking-noise.html
Mar 14, 2016 | 2013 Kia Optima
Yazzy is making squeking sound when in motion.
resolve the coding..there may be problem in it..
Jun 27, 2011 | Computers & Internet
My maytag dryer is making a very load squeking noise as it tumbles.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up
May 20, 2010 | Dryers
Hi. I am having problems with my car. It makes a
Have your front bearings checked along with your brakes. Also CV axels.
Apr 16, 2010 | 1997 Honda Civic
The washing machine makes a high-pitched squeking
No, not if the noise is only when rinsing, if it makes the noise when spinning generally then possibly but if only noisy when rinsing sounds like a filter blockage on the waste pipe. clean out the filter behind the flap on the bottom of the front panel
Aug 21, 2009 | Maytag Bravos MTW6600T Top Load Washer
My steering column is make loud squeking noises.
The rubber "boot" at the firewall is chafing on the steering shaft. Spray shaft with silicone lube, then turn the steering wheel back & forth to work lube in. May require occasional re application.
Jun 21, 2009 | 1991 Buick Skylark
Back wheel coil spring sqeuking
there should be a shock running in the middle od the spring this is what is squeking not your spring
Dec 05, 2008 | 1989 Mercedes-Benz 190
Why is my maytag dyer has a squeking sound
your roller wheels may be going bad. The drum rides on them and they have bearings in the middle that eventually wear out and make quite a racket. OR: your belt around the drum is getting old and will eventually break.
Jul 16, 2008 | Dryers
Sony Xplod Car Audio Amplifier XM-DS1300P5 - 800 Watts Mono Amplifier Car Audio Amplifier Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
