Question about Vivitek V37835 46 in. LCD Television
Remote control stopped working. no signal - Vivitek V37835 46 in. LCD Television
    Scholar:
  • 63 Answers
I apologize if I am stating the obvious. Replace the batteries with NEW ones and be sure they are installed with the correct polarity. Also, assuming this is a multi function remote, press the TV function button on the remote. Often a remote gets inadvertently set for dvd, or tuner control and then will not control the TV. My Samsung remote for example can control a stereo, vcr, cable box, and dvd plater in addition to the TV. If none of these simple fixes solve the problem you will most likely need to replace the remote. Try partstore.com
Posted on Nov 16, 2009
Testimonial: "Battery's were replaced, but the inadvertently information was very helpful. I will try that and if it does not work, then will buy another remote."
Remote control stopped working changed batteries and still not working
Here are a few suggestions to help you with this problem:
It is possible that the battery contacts are corroded so you might try expecting the contacts and cleaning them. Since you cannot see if the IR signal is being sent, you can use another IR remote that you know works and see if you can Jam the signal of the working remote with your Hql-260wr remote. To do this, push the volume up button on the TV remote and hold it down while at the same time using the known working remote to control its companion product. If the working unit stops responding correctly when the volume button is pressed, it is transmitting an IR signal.
In this case, since you confirmed that the remote is transmitting, you can make sure that you are on the correct device settings for the remote. If you select the TV setting for instance, see if the remote now can control the TV. The main functions to try first are volume and channel buttons.
If this does not work, you will need to find out where the IR receiver is on the TV and make sure that the receiver lens is not blocked by something such as another device like a video console, etc.
Apr 03, 2015 | Televison & Video
My tv won't revice signal from remote control
go and download from www.remotecodelist.com and download the code
the instr. manual from www. retrevo.com
God bless you
Oct 01, 2012 | Televison & Video
Hi I have a vizio tv control with the key board and it all just stopped working so I thought it was the batteries changed them still not working ????? Help Please
Test ur tv remote control first see,if it is working,malfuctions or completely dead?U have a Digital Camer wright?Yes.Digital Camera can read Infer Red signal Output by the tv remote.Yes?Turn the Digital Camera on and take the tv remote point it at the Digital camer and pushes all the remote buttons the Infer Red signal will read all buttons Infer Red signal flashes u can see on Digital Camer viewing screen.Pushes all remote buttons see flashes of white lights.Mean the tv remote control it it good or not.Take some cottons ball soak it with some rubbing alchachol clean the tv Infered Red sensor on the tv frame near the power LED incation light.Might be dirty,Still not reading the Infer Red signal.If 100% it is the tv remote control is the cause,it CPU is dead.Try website like Remotes.com to buy another the tv original remote.
Jul 29, 2011 | Vizio VO47L 47 in. LCD TV
My remote just suddenly stopped working. All the displays work and buttons are responsive, but there is no signal to the TV. I used a camera to check if there was any signal being sent, and I didn't see...
Change the batteries for new ones. Being able to see Remote Control signals is an urban legend, it does't work.
Also fully turn off the television for 30 minutes by removing the wall plug.
Dec 19, 2017 | Monster Cable MCC AVL300-S Remote Control
Remote stopped working Got new remote and it
It can be the IR remote receiver board inside the TV. Is the new remote setup for VIZIO TV?
Old VIZIO remote is bad for sure?
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera's Lens (Digital Camera can detect IR), you should see flashing light on the camera's screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
Dec 03, 2010 | Vizio L32 32 in. LCD HDTV
My remote stopped working... I tried to reprogram my ATT universal remote then tried the remote that came with the tv. Neither is working.
The IR receiver in the TV may have gone out, but check the remote signal first.
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera’s Lens (Digital Camera can detect IR), you should see flashing light on the camera’s screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
www.remotes.com
Jul 15, 2010 | LG 32LC7D Television
The remote control stopped working after loading new batteries
It could be the remote sensor within the TV. Does the remote work with other TVs?
Jul 03, 2010 | Vizio VW42LF 42 in. LCD HDTV
Remotes stopped working
try another remote control, check the battery of your remote control. You can use AM radio to test the remote control press the remote button the radio will receive the signal.
Jun 28, 2009 | Televison & Video
Vivitek V37835 46 in. LCD Television Logo
215 people viewed this question
Top Vivitek Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
matt martin
matt martin
Are you a Vivitek Televison and Video Expert? Answer questions, earn points and help others
