Question about RTO 50cc Moped Scooter
What type gearbox oil would i use for a moto roma roadrunner 50?
  • 43 Answers
Amsoil gear box oil
Posted on Dec 31, 2009
How to change gearbox oil for CF Moto V5
Most modern motorcycles don't have separate gearbox oil.
The gearbox is lubricated by the engine oil hence the reason for regular oil and filter changes to be made following the manufacturers recommendations.
May 12, 2014 | 2008 Qlink Legacy 250
WHERE IS THE TANK FOR TRANSMISSION FLUID
it has a transmission oil pan you check the level underneath on the side of the gearbox rh 8mm allen socket needed the oil temp must be between 50-80 degrees c jag diagnostic equipment is supposed to used for this ie. ids dattalogger but you can guess it it is a wide temp range or use temp probe on the gearbox oil pan get someone with engine running and brake applied to go through all the gears a few times ending up in park from under the vehicle you really need a hoist for this remove the pre loosened level plug transmission fluid should dribble out if the level is correct add oil if needed its special not ordinary atf refit plug
Mar 25, 2013 | 2000 Jaguar S-Type
Where is the gearbox oil located on a 1999 yamaha r6
Hi, Anonymous engine and tranny lubed by the same oil no seperate compartment for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r6-forum.com/forums/105-oil-lubrication/93368-changing-gearbox-oil.html
How to change oil on 1999 to 2002 Yamaha R6
1999 2002 Yamaha YZF R6 Service Manual R6 Moto Data Project
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Dec 02, 2012 | 2003 Yamaha YZF-R6
2010 Touran 1.4 how often change the oil for the gearbox and what type and quantity of oil
VW 1.4i with manual gearbox 5 speed transmission:
1. Oil type: VW G50 & G51, full synthetic oil SAE 75 W 90
2. Gearbox refill = 1,9 litres
3. Filling plug location: Side of transmission
Nov 07, 2012 | Volkswagen Cars & Trucks
How Much Gearbox Oil Does 2009 CPI SM 50 Hold?
you have this or it got posted in the laptop area--repost in area related to this product.
Apr 15, 2012 | Computers & Internet
Moto guzzi 650 gt -gearbox whine in 5th gear at 50-60 mph any previous?regards
Guzzi is one great bike shy the gear box whine, I've worked on a handful of Guzzi and almost all of them have it. It does seem to get louder as the bike gets older. Keep a GOOD oil in it and shouldnt have any problems. Amsoil makes some of the best motorcycle oil i have found and that would be what i would run in it. During your next oil change check out the gears while you have the pan off to change your oil filter. Everything is easy to see and look at. If there is anything else i can help with or if you have any more questions please feel free to contact me
M. Woodring
Apr 18, 2011 | 1991 Moto Guzzi NTX 650
L have a 2000 vw 4motion need to change automatic gearbox oil how do l put in new oil and how many liters does it take
How to check & change oil in automatic transmission on 2000 VW Passat 4Motion:
At the bottom of the automatic gearbox (tiptronic) you will find 2 threaded plugs on below surface. First (in front of the car) is for emptying, and second is for filling up. Tightening torque is 24 Nm.
Automatic Transmission Fluid (ATF) checking:
1. Requirements for check:
1.1. Vehicle standing on level surface.
1.2. Transmission must not be in fail-safe mode.
1.3. Shift lever in "P" position, parking brake applied.
1.4. Engine idling.
1.5. Air Conditioner and heater OFF.
1.6. ATF temperature must not exceed 104 Fahrenheit degree (40 Celsius degree) at start of test.
1.7. Only ATF with designation ESSO LT 71 141 may be used. Do not use any lubricant additives.
1.8. Automatic Transmission Fluid ATF - part number: G 052 162 A2 (1 liter wrapping)
1.9. An ATF level check when transmission oil temperature is too low results in overfilling, when too high results in underfilling.
2. CAUTION: Too much or too little ATF will affect the operation of the transmission. The ATF level must be checked at regular intervals.
3. The oil level is correct if a slight amount of oil runs out when ATF temperature is between 86 Fahrenheit degree (30 Celsius degree) and 113 F deg (45 C deg) (caused by increase of oil level when heated). For warmer climates, 122 F deg (50 C deg).
4. Hang filled ATF reservoir VAG 1924 as high as possible.
5. Shift lever in "P" position, engine running at idle.
6. Place oil drip pan under transmission oil pan.
7. Remove ATF filler plug (at the bottom of the automatic gearbox you will find 2 threaded plugs on below surface. First (in front of the car) is for emptying, and second is for filling up.
8. With ATF temperature between 86 Fahrenheit degree (30 Celsius degree) and 113 F deg (45 C deg), for warmer climates, 122 F deg (50 C deg), a slight amount of oil will flow from filler hole when ATF level is correct.
9. If necessary drain or top off ATF to attain correct oil level. Top ATF with filler hook from VAG 1924 ATF reservoir. Insert VAG 1924 (tool) ATF reservoir filler hook into filler hole and top off until a slight amount of oil flows from filler hole.
NOTE: Fit filler hook into one of the oil deflector cap slots placed on the filler opening.
CAUTION: Do not press filler hook upward or oil deflector cap can be pushed off.
10. Reinstall ATF filler plug. Tightening torque is 24 Nm.
The automatic gearbox oil capacity (drain & refill) is 2,6 ... 3,0 litres.
The front differential oil capacity is 0,75 litres. Oil type: SAE 75 W / 90 Synthetic.
The rear differential oil capacity is 1,5 litres. Oil type: SAE 90.
Another automatic gearbox type for 2.5 TDI engine:
Front differential versions:
Rear differential versions:
Please do rate my response. Thanks!
Feb 19, 2011 | 2000 Volkswagen Passat 4Motion
What type of fluid do i put in my 87 doge ram 50.. tranny fluid needs to be changed it is a 5 speed manual
most manual gearboxes on cars of this age use ep90 gearbox oil.(NOT AUTO TRANS FLUID)
Jan 10, 2011 | 1987 Dodge Ram 50
How much oil does a 2002 yamaha wild star 1600cc take and what type is reccomended
Buy 4 quarts of motorcycle oil. Motul, Maxima,etc. Oil filter and a crush washer, 14mm. 10/40, or 15/50 is ok. Chaz Moto DC
Jan 21, 2010 | 2002 Yamaha XV 1600 Wild Star
What type of gearbox oil do i use?
hello and welcome
honda reccomends their GN4. this is their motorcycle blend 10w40. but other aftermarket brands can be used as well. as long as it is a motorcycle blend, and 10w40. thank you.
Mar 21, 2009 | 1983 Honda GL 1100 Aspencade Gold Wing
RTO 50cc Moped Scooter Logo
163 people viewed this question
Top RTO Toys Experts
Timllfixit
scrivener
Are you a RTO Toy Expert? Answer questions, earn points and help others
