Question about Whirlpool Duet GHW9150P Front Load Washer
Water doesnt drain,It keeps giving an error, and it makes a strange humming sound.
    Scholar:
  • 62 Answers
Hi.
Sounds like your drain pump has seized.
Ensure all water is drained from machine. This is not as easy as it sounds if full!!!
You may have to open door and bail most of it out. When this is done, pull out machine (two people needed) then tip the machine up 45 degrees. have a bowl and plenty of towels handy. Slowly open the drain pump filter, located behind the front plynth, and catch as much water as you can in a bowl. When water flow has stopped fully open the filer body and you will probably find a coin lodged in the pump impeller blades.
Hope this helps
Aardvark Repairs
Posted on Nov 16, 2009
My electrolux washing machine displayed E1 error and no water will go in? what to do with this?
Is the pump making a humming sound? If you can answer yes, than it could be just a restriction in the drain line. If you do not hear a humming sound you may have a bad pump or timer. If all of these suggestions pan out and the problem still persists, think about what may have happened prior to this occurrence. For instance, did you notice any error codes, odors, or other strange functions prior to this issue?
Jan 25, 2017 | Electrolux Washing Machines
What does code E1 mean?
Hi Alan, I understand that your washer is not draining. Is the pump making a humming sound? If you can answer yes, than it could be just a restriction in the drain line. If you do not hear a humming sound you may have a bad pump or timer. If all of these suggestions pan out and the problem still persists, think about what may have happened prior to this occurrence. For instance, did you notice any error codes, odors, or other strange functions prior to this issue? If you are still having these issues and can think of anything in particular, please feel free to reconnect. Hope this helps! -JK
Oct 20, 2015 | Electrolux Washing Machines
What is code E1?
Hi Alan, I understand that your washer is not draining. Is the pump making a humming sound? If you can answer yes, than it could be just a restriction in the drain line. If you do not hear a humming sound you may have a bad pump or timer. If all of these suggestions pan out and the problem still persists, think about what may have happened prior to this occurrence. For instance, did you notice any error codes, odors, or other strange functions prior to this issue? If you are still having these issues and can think of anything in particular, please feel free to reconnect. Hope this helps!-JK
Washer machine wont drain
Good Afternoon Danny, this is JK. I understand that your washer is not draining. Is the pump making a humming sound? Yes, than it could be just a restriction in the drain line. If you do not hear a humming sound you might have a bad pump or timer. If all of these suggestions pan out and the problem still persists, think about what may have happened prior to this occurrence. For instance, did you notice any error codes, odors, or other strange functions prior to this issue? If you are still having these issues and can think of anything in particular, please feel free to reconnect. Hope this helps!
Mar 18, 2014 | Frigidaire Washing Machines
A few days ago our sink/garbage disposal was plugged up - plunged it and opened drain BUT dishwasher started humming and wouldn't fill up with water. Bosch Model SHU43C06UC Tried pushing on/off...
Check the drain pump it is located in the front of you unit .Disconnect power or flip breaker .Remove the front kick plate then there is a metal plate above that is held on with 4 screws remove that and reach in and press lever on pump and turn counter clockwise it will come right out .Then check for items in the pump area could be glass. Hope it is helpfull
Sep 18, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
My washer fills with water, then when its about time to start agitating, it just makes a humming noise, and doesnt agitate
You may just simply need a new belt. If not there could be 2 other issues, like something being stuck in the drain pump, or possibly a bad motor. Does it have any strange smell coming from underneath?
Dec 01, 2010 | Maytag PAV2300 Top Load Washer
Our washer wont spin fast and shuts off saying ND code. what does that mean
ND means that it is Not Draining. Does it make the same water-pump sounds that it used to make at that point in the cycle? In my machine, it sounds like a low-pitched loud hum when it's working.
It might be that your water pump needs replacing. If there is any strange sound (such as grinding) then there might be a coin or something stuck in the pump.
Sep 29, 2009 | Samsung WF337AA Front Load Washer
My washing machine wont drain the water
if its making a humming sound the pump may be blocked turn the pump fan by hand to see if its free,
Mar 14, 2008 | Fisher and Paykel IWL12 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
161 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
