Readyboost Windows 7
OK.I bit the bullet and got Win7 ultimate..
Ready boost is a feature that seems to work noticeably with multimedia etc. BUT, how can I get it to remain on, on boot up? It's not PC specific as this happens on all my PC's with W7U.
I've searched copious amounts of sites, even those (nearly all) that avoid any real answer by asking the user about his breakfast and a lot of other derailed sidetracking garbage.
Microsoft was utterly useless, as were the help files in W7U.
OK. I can't afford to pay for help, so I suppose I won't get an answer here, but it would be nice, and for millions of others.
  • Scoee Scoffer Nov 17, 2009
    Thanks Dwane4444. That is the recommended and is included in the help files, but that's about all the help you get from Microsoft. Needless to say, I have tried all the obvious except NTFS Format sticks (too expensive for me at this moment for 16GB or bigger).
    I used FAT32 and EXFAT format with same results. 16Gb and 4 Gb sticks. 4 different PC's and a laptop. Windows Ultimate Activated, Unactivated, the trial versions and several re-installations to see if I did something wrong. I'm sure it's something simple, but I am flummoxed.
    Regards
    Scoffer
    Sergeant:
    Champion:
  • 219 Answers
Not really sure of your problem - I use ReadyBoost all the time - I have a 2Gb usb key connected all the time (not though a hub!). Went to Computer - "USBKey" - Properties - ReadyBoost - and selected dedicate this device to ReadyBoost - OK. It all worked and remains working through all shutdowns and startups.
Posted on Nov 16, 2009
  • dwane4444
    dwane4444 Nov 17, 2009
    Here are the requirements for a readyboost key drive:
  • The device must be at least 64 MB
  • The device must be USB 2.0
  • It has to be able to read at 3.5 MB/s
  • It has to be able to write at 2.5 MB/s
  • If all these are OK, then the problem must lie with the the item common to all your tests - the key drive. Mine is formatted as FAT, but I can't help but think the problem may be with the read-write speeds.
Does windows7 ultimate runs smoothly in 1Gb RAM
The answer is yes! Even on a sized 512MB RAM you would still run smoothly[Windows 7 Ultimate M3 v6801-0-080913-2030]
Hope this helps.Thanks!
Please rate this answer.
Nov 07, 2011 | Microsoft Computers & Internet
Tip
How to speed up Windows Vista or 7 responsiveness with your USB / Thumb Drive in...
A great feature that isn't commonly known is ReadyBoost. It was introduced in Vista and is available in Windows 7 as well. Basically it increases the amount of memory you have by using your memory stick. You can use more then one usb/thumb drive and the bigger they are the better.
Step 1: Just insert your USB drive into a usb port.
Step 2: Click Start > Computer
Step 3: Right click the USB memory stick you plugged in and choose Properties. Click the ReadyBoost tab then choose Use this device. Choose how much space you would like to allocate and that's it!
Enjoy the boost!
-LeeTheDeuce
on Jan 22, 2010 | Computers & Internet
Tip
What is ReadyBoost
Windows Vista has introduced a clever new caching system that can take advantage of your existing high-speed storage devices (such as USB Drives and Memory Cards). This should boost performance when performing disk intensive tasks. Some flash memory devices are up to 100x faster than a standard hard disk, so it makes sense to use these to cache common files.
ReadyBoost works with SuperFetch to store information that can be accessed quickly from the cache on startup, rather than relying on slower reading from the hard disk.
There are several requirements that your flash memory device must meet to be used as a ReadyBoost device:
  • At least 256 MB in size
  • Access time of < 1ms
  • Capable of 2.5 MB/s read speeds for 4 KB random reads spread uniformly across the entire device and 1.75 MB/s write speeds for 512 KB random writes spread uniformly across the device
  • At least 235 MB of free space.
It is recommended that you have between 1-3 times the amount of ReadyBoost cache as physical RAM. However, ReadyBoost devices are limited to 4GB max.
Assuming you meed the minimum requirements, plug your device in to a USB 2.0 port and wait for a Windows Autoplay dialog box to pop up. Select the Speed up my PC option from this menu.
You can then set the amount of space on the device that you wish to allocate to ReadyBoost (you may as well use the maximum possible, up to the 3x RAM recommendation). If your device is not compatible or is too slow, you will be informed of the reasons at this point.
Users with low amounts of system RAM (512MB - 1GB) will notice the biggest performance increase, and those with 2GB or more may only notice marginal gains.
on Mar 18, 2009 | Microsoft Windows Vista Ultimate Edition
What are the pros and cons of upgrading your OS from win7 starter to windows 7 ultimate? Given that the processor is N450 on a netbook.
There are basically no con's to upgrading. You will gain some features when you upgrade. You may have to install new device drivers for some devices like mouse, external hard drive to work properly, but this is unlikely.
Windows 7 Starter does not include:
* Aero Glass, meaning you can only use the Windows Basic or other opaque themes. It also means you do not get Taskbar Previews or Aero Peek.
* Personalization features for changing desktop backgrounds, window colors, or sound schemes.
* The ability to switch between users without having to log off.
* 64 bit version
* Multi-monitor support.
* DVD playback.
* Windows Media Center for watching recorded TV or other media.
* Remote Media Streaming for streaming your music, videos, and recorded TV from your home computer.
* Domain support for business customers.
* XP Mode for those that want the ability to run older Windows XP programs on Windows 7.
So, you can gain some additional features when you upgrade!
-G33k
May 23, 2011 | Microsoft Windows 7 Ultimate for PC
My sony vaio vgn-cr220E was uprraded from vista to windows 7..why does the biult in motion eye camera doesnt work..
You need the Win7 camera driver, check sony support at:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNCR220E&SelectOS=44
just enter your Win7 operating system (there are 9 versions of Win7), and select the downloads (2)
for your computer camera driver.
Versions of microsoft Win7 - determine which yours is by (these instructions are for WinXP);
START > Control Panel > System > General (tab)
Windows 7 Home Basic 32-bit
Windows 7 Home Basic 64-bit
Windows 7 Home Premium 32-bit
Windows 7 Home Premium 64-bit
Windows 7 Professional 32-bit
Windows 7 Professional 64-bit
Windows 7 Starter 32-bit
Windows 7 Ultimate 32-bit
Windows 7 Ultimate 64-bit
May 14, 2011 | Sony VAIO VGN-CR220E/P Notebook
Will Pinnacle Studio 12 Ultimate run on Windows 7
According to Microsoft, YES IT WILL. Pinnacle Studio 12 appears to be completely compatible with Win7. Below is the link to the Microsoft page.
http://www.microsoft.com/windows/compatibility/windows-7/en-us/Details.aspx?type=Software&p=Pinnacle%20Studio&v=Pinnacle&uid=12&pf=0&pi=1&c=Photo%20%26%20Video&sc=Other&os=64-bit
I have to add that I've never tried to run Pinnacle Studio 12 on Win7.
Jul 14, 2010 | Pinnacle Studio Ultimate 12 for PC
Intel Turbo Memory Readyboost keeps reverting back to "disabled"
Hi, sometimes when changing, or upgrading Programs or Software (Systems Configuration) will set to a (Default) service state automatically. To be certain that the changes to the (Applications) take place; be sure to make the change correctly by doing the following. 1. Enable Ready Boost. 2. Remember to always, click Apply! 3. Click (OK) 4. Restart your computer; this will help to identify, and configure the changes made to the system, on your computer. Thanks paul7of9
Jan 06, 2010 | Computers & Internet
I just bought a new computer that has Windows 7. I try to download my Creatacard Gold3 and am told it is not compatable with a 64 bit driver. Do I throw it out or is there another way to install it?
Two options. Try Googling. Maybe the Creatacard software provider has a 64 bit version of the program available as an upgrade. Many Vista 64 bit programs work OK with Win7.
If this doesn't work and you REALLY need to use THIS program, you can install a 32 bit version of another operating system as a dual-boot. Either XP or Win7 would work. Or run a 32 bit operating system on a virtual machine and run the program on the virtual. That's rather high tech just to run a card maker. So if they don't have a 64 bit version of the program, look for another supplier who does.
64 bit provides faster operations, but it does render a lot of older programs unworkable.
Nov 12, 2009 | Microsoft Windows Vista Ultimate Edition
Pen drive as ram
it will not work with xp or any other version of windows except vista, and it has to be a readyboot compatible flash drive to work.
Mar 25, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
213 people viewed this question
David Payne
David Payne
