Question about Brother IntelliFAX 4100 Laser Fax
Brother Intellifax 1" black line on right in send & copy modes
1" black line running down right side of page in copy and send fax modes. Receive faxes are ok.
  • wbrown305 Nov 16, 2009
    Thanks for the suggestion. I cleaned the laser scanner window per the manufacturer's instructions, with no change in the original problem.
    I can view that the scanner lens is not obstructed.
    When I copy, I can peer up at the laser light area and notice that the laser is not emitting light at its right end, coincident with the 1.3" heavy dark line on the paper copy.
  • 105 Answers
Lift up your document feeder and check for something on the **** glass
Posted on Nov 16, 2009
Testimonial: "Good call! The laser light bar does not light up all the way across its length. Looks like a service call. Thanks for the assistance."
  • Edward Nov 16, 2009
    you might have a led light out on the scanner lamp
  • 1,959 Answers
The most common cause of your problem is debris in the paper feeder. To fix this, lift up the feeder panel and clean out the feeder channel. Sometimes loose dirt or a scrap of paper will find its way in front of the scanner lens. A can of compressed air will usually do the trick here unless it's a smudge of some sort in which case it will need to be cleaned directly with a soft cloth.
Vertical Lines through incoming faxes and copies.
Sometimes you may see vertical streaks/black lines
on the faxes you receive. Either your FAX/MFC's
primary corona wire for printing may be dirty, or
the sending party's fax scanner may be dirty. Clean
your primary corona wire (see pages 13-18), or ask
the sender to make a copy to see if the problem is
with the sending machine.
Cleaning the Drum Unit
We recommend you place the drum unit on a drop cloth or large piece of
disposable paper to avoid spilling and scattering toner.
1 Carefully turn the drum unit upside down.
2 Clean the primary corona wire inside the drum unit by gently sliding the tab
from right to left several times.
3 Return the tab to the Home
position (  ) before
reinstalling the drum unit.
Jan 31, 2011 | Brother IntelliFax-2920 Plain Paper Fax,...
The ride side of my faxes and copies are black, any ideas?
Sometimes you may see vertical streaks/black lines on the faxes you receive. Either your machine's
primary corona wire for printing may be dirty, or the sending party's fax scanner may be dirty. Clean
your primary corona wire. I recommend placing the drum unit on a drop cloth or large disposable paper
1. Clean the primary corona wire inside the drum unit by gently sliding the tab from right to left several times.
2. Return the tab and snap it into the Home position, (Caution: If the tab is not at the Home position, printed pages may have vertical stripes).
3. Reinstall the drum unit into the machine.
4. Close the front cover.
5. Plug in the power cord first, and then plug in the telephone cord.
or ask the sender to make a copy to see if the problem is with the sending machine.
Try receiving from another fax machine.
If the problem continues, call Brother Customer
Service at: 1-800-284-4329 (in USA) or 1-877-BROTHER (in Canada).
Dec 31, 2010 | Brother IntelliFax-4100e Fax
My brother fax machine - only receives black pages
do a quick check on 2 things.
- Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
- check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
Hope this will put your Brother on the track
Jul 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Using MagicJack for faxing; however, Brother MFC 290C is stating poor line condition - why? Also say's low ink Magenta - would that create this problem?
I had the same problem trying to send out faxes out using my Brother MFC 7340. I use a magic jack phone line. Page 106 of the user manual says if sending via VOIP phone line, you should press menu, then 2, 0, 1 to select "Basic (for VOIP) mode. Then press ok. Then press stop/exit. This cuts the modem speed down to 9600 bps and turns ECM off. Then retry to send the fax. I did that and can now send and receive faxes.
Jun 06, 2009 | Brother MFC 420CN All-In-One InkJet...
Black border down the right side of the page, which blocks info
either you neede a new drum or this is problem in the fuser section. may be baf heater roller. try cleaning the grid on the drum cartridge with a soft bristel pauint brush good luck brother sr tech
Jan 23, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
2 inch vertical solid band on right side when making a copy
There is probably dirt or ink on the scanner glass, this would affect both copying and sending faxes.
Here is a link to the manual and a description on page 74 showing how to clean the glass.
http://www.brother.ca/en/products/pdf/manuals/FAX1270-UG.pdf
Jan 21, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Black page when copying and sending faxes.
You most likely have a bad SCANNER BLOCK. Not good!
Dec 23, 2008 | Brother IntelliFAX 4100 Laser Fax
Able to receive fax but cant send
sleep mode is just a status of the machine when it is in idle mode.you cannot turn this off however you can delay the time before the unit goes into a sleep mode.it has nothing to do when you are sending out faxes.so here are a few things you need to check when sending a fax (1)dial tone by pressing hook/hold button (2) insert the doc into the adf, make sure it will change to "enter fax # and start,or copy press copy (3) dial the number (4) wait for fax tones of the receiving unit before you press start. now if you can hear an operator on the line,that has to be verified with your phone company since brother machine does not restrict incoming and outgoing faxes UNLESS that is restricted from your phone line.
Nov 18, 2008 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
663 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
