Question about Shure SLX1 Body-Pack Transmitter for Existing SLX Systems Microphone
Remote microphone shure slx1 can't get enough volume I have control board maxed and I barely hear myself on speakers. the problem not in speakers or the sound board.the first time when I started getting very low level of sound I changed the battery thinking that was the problem,but it wasn't
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
1) Make certain the switch on the side of the SLX1 is set to "mic".
2) Make certain the output of the SLX4 receiver plugged into a microphone input, not a line input on your mixer.
Posted on Nov 18, 2009
Shure slx1 bodypack won't turn off
The Shure body packs will only last so long before needing repair. You can contact Shure and have them refurbished for about 90 dollars a piece. It will take about a week once they receive it. I am very familiar with Shure as they are my go to brand for all of my installs. If you would like assistance, information or pricing on replacements let me know. These can be fixed though.
Mar 27, 2014 | Shure SLX1 Body-Pack Transmitter for...
Mic is faint
Turn up the volume on the mixer.
Mar 13, 2014 | Shure SLX1 Body-Pack Transmitter for...
Increase volume
The only gain adjustment is the 3 position switch on the side of the bodypack. Flkip that to MIC. Then, turn up the mixer channel to get it loud enough.
Nov 27, 2013 | Shure Audio Players & Recorders
Shure slx1 won't shut off
You have probably locked the controls.
http://shure.custhelp.com/app/answers/detail/a_id/3192
Jan 26, 2012 | Shure SLX1 Body-Pack Transmitter for...
Have a Shure SLX Wireless System. The only way the microphone SLX1 or SLX2 is if they are right up to your mouth. If you put the lapel mic on a persons tie you can't hear them. The transmitter is set to...
The Shure SLX2 hand-held microphone has similar performance characteristics to the much-loved (cabled) Shure SM58 vocal microphone. It has a 'cardoid pick-up pattern' intended for close work - being spoken / sung straight into the top of the capsule at no more than about 8 inches from the mouth of the user- to minimise feedback and extraneous noise. If you double the distance between the mouth and microphone the sound level will drop four-fold so distance really matters.
The SLX1 lapel/ lavalier is a semi 'omni-directiona'l pick up pattern microphone, which should work satisfactorily up to 12 inches from the speakers mouth, but closer is better. Always try to get your users to hang it about 6 inches below their chin, at most, and preferably with the top of the microphone capsule pointed upwards towards the mouth.
Here are a few other things for you to try:
  1. There is a volume (gain) knob on the back panel of the SLX receiver unit. Try turning this up to maximum (needs a small screwdriver)
  2. Make sure that both aerials on the receiver are fully extended at different angles to each other and in a clear 'line-of'sight' with the transmitter pack, with no large bits of metal in between which could block the signal. Ideally the receiver should not be more than 25metres from the transmitter. If distance is a problem locate the receiver near to the transmitter and run a balanced (xlr) cable to your mixer/ amplifier.
  3. The angle that the receiver aerials are at should be broadly similar to the angle that the transmitter antenna is at to optimise signal reception.
  4. Make sure the receiver is not located too close to other electrical equipment which may be interfering with the signal (especially voltage transformers, CD or DVD players and hearing loop induction amplifiers which have a strong magnetic field)
  5. Always use good quality batteries - Duracell Ultra or equivalent ( do not use rechargeable batteries as they seldom achieve optimum voltage)
  6. Check that the antenna is tightly screwed into the SLX1 transmitter pack and not damaged.
  7. The SLX2 hand-held microphone has an adjustable level switch inside the body - unscrew the top of the microphone to access it - switch to maximum.
  8. Another possible cause could be an impedance mis-match between the SLX receiver and your amplifier or mixer. There are two outputs on the rear panel of the receiver. One is an XLR (large 3 pin socket) this is LOW impedance and needs connecting to a low impedance input on your mixer/amplifier. You should normally be using this output even if your amplifier has a jack-socket input (use a proper balanced XLR to 6mm trs jack cable rather than a adapter plug). The other output on the receiver unit is a 6mm HIGH impedance, unbalanced, standard jack socket (labelled 'line in'). This would normally be to connect to a guitar amplifier which has a high impedance 'line level' input socket. If you are using this output you may need to use a pre-amplifier to get a big enough signal for a microphone.
You can find the Shure SLX user manual here http://www.shure.com/idc/groups/public/documents/webcontent/us_pro_slx_en_ug.pdf
Jan 27, 2011 | Shure SLX1 Body-Pack Transmitter for...
I'm useing the SLX1/SLX4 cordless combo with a Crown headworn mic (CM 311/E SH). Sometimes the sound cuts off ! I'm based in NYC. where can I go for repair? Thanks
If the problem is with the Shure wireless, you'll need to send it back to Shure (www.shure.com/service). If the problem is with the Crown headset, you'll need to send that back to Crown.
Oct 28, 2010 | Shure SLX1 Body-Pack Transmitter for...
Pin configuration for a shure slx1 transmitter
Pin 1: Shield
Pin 2: 5 volts bias
Pin 3: audio
Pin 4: Loading resistor (connect pins 3 and 4 together when using a condenser microphone.)
Sep 16, 2010 | Shure SLX1 Body-Pack Transmitter for...
WON'T CHANGE CHANNELS ADJUST VOLUME OR SHUT OFF
If the volume buttons work when using the Radio, then the buttons on the Remote are fine.
Now if the volume on your TV is set to MAX and you can barely hear it.
The issue lies with your TV.. ()
Now if I understand correctly or if I am to assume you are using a Reviever.
If the reciever is used for all volumes... If this is the case.
I also assume the volume on the TV Speakers is set to off
Therefore when you use the Radio/DVD the volume control is using the Reciever volume.
and when you switch to TV it uses the TV volume thus the TV volume is not gonna work as well.
2 scenarios
1 The TV volume even at max is not giving you enough power to get the low receiver volume
2 the Receiver volume is at max and barely audible.. if this is the case just manualy adjust your TV volume to get it to a decent sound level.
Hard to explain but I know the 2 issues can be fixed.
Apr 21, 2008 | Logitech Harmony 550 Remote Control
172 people viewed this question
Top Shure Audio Players & Recorders Experts
Ben Armstrong
Vito Vacirca Jr.
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
